Tip & How-To about Computers & Internet
How to fix -3221 error displays when accessing iTunes Store
Change the permission level for iTunes and iTunesHelper to allow full access.
This should allow iTunes and iTunesHelper to both send and receive data from the iTunes Store.
Additional Information
More information on changing permissions can be found in the McAfee Personal Firewall Plus User's Guide.
Computers & Internet Logo
how to download fexplorer in .jar format
thumbsup.gif FileExplorer v3.0 alpha
[img src="http://handheld.softpedia.com/images/software/screens/FileExplorer-Java-0.jpg" border="0" alt="">
FileExplorer is a program for managing files on the phone and memory card.
Current features include hiding/unhiding of folders and files, password protected access to the program and copying and moving files.
It also features a slideshow viewer and image viewer. Will NOT open other files except jpg and png. This is NOT the final version. Its a pre-release build.
IMPORTANT Settings before running FileExplorer:
After FileExplorer has been installed you'll need to configure the Access Permissions to allow FileExplorer to access the phone local file system and the internet. How this is done depends on your phone. Please read the below section for instructions for your phone type.
Configuring Access Permissions for FileExplorer
Sony Ericsson phones:
Go to either Applications or Games (depending on where you installed FileExplorer). Highlight FileExplorer, but instead of opening it, press More->Permissions.
Select Read User Data and set the access permissions to "Ask once" or "Ask Always". Select Write User Data and set the access permissions to "Ask once" or "Ask Always".
Nokia Series 60 phones:
Go to Tools > Manager > FileExplorer > Options > Suite settings
Select Read User Data and set the access permissions to "Session" or "Ask Always".
Select Write User Data and set the access permissions to "Session" or "Ask Always".
Nokia Series 40 phones:
Go to FileExplorer->Options->Application access->Phone access
Torch Keys:
Left Softkey(Nokia): Change color
Right Softkey(Nokia): Go back
UP/DOWN arrow: Increase/decrease brightness
LEFT/RIGHT arrow: Cycle through preset colours
8 key: Toggle Circle light or Full screen light
0 key: Reset all settings
What's new in this release:
· Shows hidden files and folders with separate icons than the normal ones.
· Improved the support for Sony Ericsson phones. Should work but haven't tested though. Do send feedback
· Added support for zip files and nokia themes but it's under work and will not work.
· Changed the UI a bit adding a shortcut to jump directly to a path
· Added a torch with different colors. The flashlight doesn't work yet.
· Added Nokia Theme creator UI. Still under development.
· Support for zipping files and upzipping them. Working on them. To get torch which remains ON permanently press the UP arrow which changes the brightness level.
http://www.symbianize.com/attachment.php?attachmentid=52054&d=1216885320
Symbianize Forum
Apr 24, 2014 | Nokia ASHA 200 Dual Sim Gsm Unlocked...
nokia s40 nokia 2700
firstly install these applications from Nokia store....third party s/w might not work properly. install application with mmc inserted and use them with mmc inserted............Permissions like always allowed/ask first time are only for network (GPRS) access....Mobyexplorer requires net.........many free applications also require net access as they carry some ads....if these permissions are denied then application closes......but be sure....if u select always allow/ allow first time, data usage charges will be applicable
Mar 13, 2014 | Nokia 2700 Classic
how can i set up network file sharing
First step is to check if the file sharing option is checked in my computer folder options.
Start- My computer- TOOLS - FOLDER OPTIONS- and click on the second tab VIEW- scroll down to the last option which will show as USE SIMPLE FILE SHARING.
Level 1: My Documents (Private) loadTOCNode(3, 'moreinformation'); The owner of the file or folder has read and write permission to the file or folder. Nobody else may read or write to the folder or the files in it. All subfolders that are contained in a folder that is marked as private remain private unless you change the parent folder permissions.
If you are a Computer Administrator and create a user password for your account by using the User Accounts Control Panel tool, you are prompted to make your files and folder private.
Note The option to make a folder private (Level 1) is available only to a user account in its own My Documents folder.
To configure a folder and all the files in it to Level 1, follow these steps:
  1. Right-click the folder, and then click Sharing and Security.
  2. Select the Make this Folder Private check box, and then click OK.
Local NTFS Permissions:
  • Owner: Full Control
  • System: Full Control
Network Share Permissions:
  • Not Shared
Level 2 (Default): My Documents (Default) loadTOCNode(3, 'moreinformation'); The owner of the file or folder and local Computer Administrators have read and write permission to the file or folder. Nobody else may read or write to the folder or the files in it. This is the default setting for all the folders and files in each user's My Documents folder.
To configure a folder and all the files in it to Level 2, follow these steps:
  2. Make sure that both the Make this Folder Private and the Share this folder on the network check boxes are cleared, and then click OK.
  • Administrators: Full Control
  • Not Shared
Level 3: Files in shared documents available to local users loadTOCNode(3, 'moreinformation'); Files are shared with users who log on to the computer locally. Local Computer Administrators can read, write, and delete the files in the Shared Documents folder. Restricted Users can only read the files in the Shared Documents folder. In Windows XP Professional, Power Users may also read, write, or delete any files in the Shared Documents Folder. The Power Users group is available only in Windows XP Professional. Remote users cannot access folders or files at Level 3. To allow remote users to access files, you must share them out on the network (Level 4 or 5).
To configure a file or a folder and all the files in it to Level 3, start Microsoft Windows Explorer, and then copy or move the file or folder to the Shared Documents folder under My Computer.
  • Power Users: Change
  • Restricted Users: Read
  • Not Shared
Level 4: Shared on the Network (Read-Only) loadTOCNode(3, 'moreinformation'); Files are shared for everyone to read on the network. All local users, including the Guest account, can read the files. But they cannot modify the contents. Any user can read and change your files.
To configure a folder and all the files in it to Level 4, follow these steps:
  2. Click to select the Share this folder on the network check box
  3. Click to clear the Allow network users to change my files check box, and then click OK.
  • Everyone: Read
  • Everyone: Read
Level 5: Shared on the network (Read and Write) loadTOCNode(3, 'moreinformation'); This level is the most available and least secure access level. Any user (local or remote) can read, write, change, or delete a file in a folder shared at this access level. We recommend that this level be used only for a closed network that has a firewall configured. All local users including the Guest account can also read and modify the files.
To configure a folder and all the files in it to Level 5, follow these steps:
  2. Click to select the Share this folder on the network check box, and then click OK.
  • Everyone: Change
  • Everyone: Full Control
Note All NTFS permissions that refer to Everyone include the Guest account.
All the levels that this article describes are mutually exclusive. Private folders (Level 1) cannot be shared unless they are no longer private. Shared folders (Level 4 and 5) cannot be made private until they are unshared.
If you create a folder in the Shared Documents folder (Level 3), share it on the network, and then allow network users to change your files (Level 5), the permissions for Level 5 are effective for the folder, the files in that folder, and the subfolders. The other files and folders in the Shared Documents folder remain configured at Level 3.
Jul 20, 2010 | Microsoft Windows Vista Ultimate Edition
I cannot open itunes,a error message reads: itunes library.itl file is locked,on a locked disk,or you do nothave permission for this file
Hi
First You Have To go to my music folder under my documents than
1. right click and select properties
2. selecting the security tab
a. if you don't have the securities tab, you need to go to my computer, tools, folder options, view,and scroll down until you see "Use simple file sharing", then uncheck that box and click ok.
3. next, click the add button under the first box, labeled groups or user names
4. type in your account name, i.e. Jon, and click ok,
5. last, it should bring up a window that asks what permissions you want the person to have, click the first option, full control
6. click apply or ok until all windows are closed. this should allow permissions for the user, therefore allowing iTunes to access it.
If it doesnt work you can check link below
http://support.apple.com/kb/HT1866?viewlocale=en_US
Nov 26, 2009 | Apple iTunes
error 3221
This usually happens when someone has Mcaffe security on their computer or someother security. If this happens, change the permission level for iTunes and iTunesHelper to allow full access. This should allow iTunes and iTunesHelper to both send and receive data from the iTunes Store. You should be able to learn how to do this in your user manuel for Mcaffe or your security. I pulled this info from Apples website so if it doesn't work, you can type in the error code on their help section.
Dec 28, 2008 | Apple iPod MA446LL/A MP3 Player
214 people viewed this tip
David Payne
David Payne
