Tip & How-To about Cell Phones
Smart phone hanging
If you want your smart phone not to hang or freeze too much, try to close the applications with back button don’t use end key “red button”.
Cell Phones Logo
froze on video and now black screen
Try pressing the back and home keys a few times. Sometimes a program hangs and the input prompts android to display the force close option to end the application.
If that doesn't work, try holding in the power button for about 10 seconds and see if the power down options appear (this might cause the force close to appear too, if so go for that method, if not shut down and power back up).
If none of that helps, you may need to pull your battery and boot it back up.
Please leave feedback if you found this helpful. Thanks.
Mar 31, 2011 | Motorola Mobility MILESTONE XT720 Cell...
battery discharges quickly
Yeah, on Android phones, Smart phones, HTC Phones, and all those "high-tech" phones, the batteries drain easily. Why? Because these phones have addictive applications. On this particular phone, which I also own, the apps don't close just by tapping the back button. At the home screen (or any screen) hold the center button (in-between the answer and hang-up button) and see the open applications. Close the ones that are not in use to save battery space.
Hope I was a help, if I wasn't, that's like Dora not being able to say hola.
Jan 01, 2011 | Nokia 5230 Cell Phone
my phone has frozen
This unit is prone of freezing up due to low memory. Check your free space on your phone,make sure you are cleaning memory,by purging cache memory etc. Also when you leave a program actually select"CLOSE" button.Most people close the applications by pressing the escape or red key. This does not close the application has a CLOSE option. For instance if you are in the calendar hit hit menu key and scroll down to the bottom CLOSE is listed. Go through each application and press close. Go into the cache operations clear all categories and hit escape it will say cleaning memory. Go to options - security - memory cleaning - enable it. Then it will now clean memory when idle for 5 minutes. Hope it may helps,feel free to ask whatever the result.
Regards:
VOTIT
May 22, 2010 | LG Vu CU920 Cellular Phone
My backberry pearl freezes up and when i take the battery out it takes an hour for it to load and freezes more
This unit is prone of freezing up due to low memory. Check your free space on your phone,make sure you are cleaning memory,by purging cache memory etc. Also when you leave a program actually select"CLOSE" button.Most people close the applications by pressing the escape or red key. This does not close the application has a CLOSE option. For instance if you are in the calendar hit hit menu key and scroll down to the bottom CLOSE is listed. Go through each application and press close. Go into the cache operations clear all categories and hit escape it will say cleaning memory. Go to options - security - memory cleaning - enable it. The BB will now clean memory when idle for 5 minutes. Hope it may helps,feel free to ask whatever the result.
Regards:
VOTIT
May 21, 2010 | RIM BlackBerry Pearl 8130 Cellular Phone
i cant send a text message in my N95 8gb phone
THis is beacaus you must have many application in the background....
  • Try closing all the application by clicking and holding the MENU key and knowing the list of all open application....
  • If this step fails try restarting your phone and try sending SMS...
  • even if this step fails, FORMAT you phone by switching on by holding GREEN BUTTON,(*)Star key and 3 button simultaneously...
any of these step should sole tghis problem nothing to deal with operator.. Enjoy
Jun 26, 2009 | Nokia N95 Cellular Phone
105 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
