Tip & How-To about Audio Players & Recorders
How to rip DVD to Apple TV with proper settings on Mac?
This guide is to show you how to rip DVD for enjoying on widescreen TV via Apple TV with Pavtube DVD to Apple TV Converter. The converter, which is one of best DVD to Apple TV transcoding tool, is very easy of use. Follow this guide and you will learn how to proceed the conversion with simply a few clicks. Now let’s step through the conversion.
Step One. Run DVD to Apple TV Converter and load DVD.
Launch Pavtube DVD to Apple TV Converter for Mac and the interface below will pop up. The source DVD movie could be loaded either directly from the disc or ISO image file. Click ‘DVD Folder’ to import movie from DVD. All the chapters are listed in the file list area and checked by default. You could double-click on a chapter if you would like to preview it. Right below the file list area there are ‘Subtitle’ and ‘Audio’ option where you can specify subtitle and audio track. (Note that some chapters have no subtitle or audio). Make sure all your desired chapters are checked. Also, you may uncheck those unwanted chapters like titles and menus.
Step 2: Set Output format.
Click on “Format” bar to specify output format. Follow ‘Apple TV’ and select a proper format from the list. Here you will find MPEG-4 512*384(*.mp4), MPEG-4 720*432(*.mp4), H.264 720*480 AAC (*.mp4), H.264 AAC 1280*720(*.mp4). Typically I would recommend you to choose H.264 AAC 1280*720(*.mp4) for your HD TV so as to save space and fit for the screen.
If you’d like to further customize video and audio parameters, please click “Settings” button. Here you could adjust video codec, audio codec, frame rate, bit rate, video size, audio channels. For instance, you can change the video bit rate to 5000kbps, audio bit rate 160kbps for better output quality, or input 960*540 as video size. Do not forget to click on “OK” to confirm your settings.
In ‘Export to’ box you could specify destination for the converted file.
Step 3: Start ripping DVD to Apple TV.
Click on “Convert” button to start ripping DVD to Apple TV friendly format. The converter will generate files with admirable video quality. After conversion you can click ‘Open’ button to locate the converted files. Sync them to Apple TV with iTunes and then you can enjoy the ripped movies on HDTV freely.
Small Tips:
1.Thumbnail- click ‘Snapshoot’ button when previewing the video. Click ‘Option’ to set the image format of screenshots.
2.Deinterlace- click ‘Editor’, switch to ‘Effect’ tab, find ‘Deinterlacing’ box, and check it to eliminate interlacing lines.
3.Combine files together- check the files to be merged in file list and check ‘Merge into one’ box beside ‘Settings’ button.
4.Trim a section of the movie- click ‘Editor’, switch to ‘Trim’ tab, and input time point in start and end box.
5.The higher quality you set, the longer time it costs. The resolution 1920*1080 is for HD DVD and Blu-ray disc ripping, the best resolution for standard DVD ripping is 1280*720.
hi i have a 2000 chevy blaser 4wd and i had to replace the catylaic converter but its a piece that connects to the hot heater hose i guess to keep it cool has been lost and im trying to find out whats the name of that piece
There is no part of the catalytic converter that connects to any part of a heater hose.I don`t know who told you this but they are incorrect.The converter is part of the exhaust and no heater hose should be hooked up to it.If you got an after market converter then this could be your problem.What you need to do is get a direct fit catalytic converter.The only thing you need to install is the old o2 sensors on the new converter.Let me know if you have any more questions.Good luck.
Nov 07, 2010 | 2000 Chevrolet Blazer
How do you transfer dvd movies to your psp please
Try to use Leawo DVD to PSP Converter.
It enables you to convert DVD to PSP to extend the fun of your game console! With this DVD to PSP free converter, you can convert DVD to PSP friendly video files and audio in MP3, M4A, and then transfer DVD to PSP.
May 11, 2010 | Sony PlayStation Portable (PSP) Console
How to rip Blu-ray movies to iPod, iPhone, Apple TV, PSP,PS3,Xbox360, GPhone with perfect sound, high speed and quality? Share your Blu-Ray and general DVD on more mobile devices, as iPod, iPhone, Apple TV, PSP, PS3, PDA, Xbox360, GPhone, Zune, Cell phone, Blue ray to MP4 ripper is your best choice. BestHD Blu-Ray to MP4 Converter can help you share your Blu-Ray on more devices, as iPod, iPhone, Apple TV, PSP, PS3, PDA, XBOX360, GPhone, Zune, Cell phone. supported: iPod, iPod nano, iPod classic, iPod shuffle, iPod touch, etc. There is a small Free Blu-ray player built in Blu-ray to mp4 converter and so you set start-time and end-time just when you Watching the Blu-ray Moive.Convert with perfect sound and converting speed . Preview your movies.Select windows mode you like after conversion from output settings. Capture beautiful pictures in your preview. ? Now You can find below a step-by-step guide for directly convert Blu-Ray to MP4: User Guide: Interface In this interface you can conduct a variety of operations such as setting the begin and end time for the conversion through the preview window ,capture the beuatilful pictures of movie, setting the output parameter and more. Now ,let us explain step-by-step. Step 1: Import Blu-Ray or general DVD Click File->Add Blu-Ray/DVD or directly Click "Add Blu-ray " button to load Blu-Ray/ DVD into Blu-ray To MP4 Converter, the file titles would be shown in the information list. Add Blu-ray Step 2: Select output format Click "Profile" drop-down list to choose output format . Select output format Step 3: Adjust video settings Switch to Tools->Settings panel or directly Click "Settings" button , you can adjust the video size, video quality, channel, audio quality, and specify the output path. Click ?OK? to confirm the settings. Adjust video settings Step 4: Rip Blu-ray DVD Click Action->convert or directly Click "Start" button to start convert you'll see the ripping process of Blu-ray to MP4 with amazing speed. A moment later, you'll get your satisfactory conversion. Rip Blu-ray BestHD Bluray to MP4 Converter FREE Download. YouTube video guide: http://www.youtube.com/watch?v=qQhGKiMaX3Y More Products by BestHDsoft.Blu-Ray DVD Copy, Blu-Ray Ripper, Blue-Ray DVD Ripper , Blu-Ray to iPod Converter , Blu-Ray To AVI Converter.
with Video Download Studio from http://www.downloadvideos-convert.com/download-videos-music
hope it can help you
May 12, 2010 | Ahead Software Nero 6.0 (60045) for PC
How To rip Blu-ray DVD Format? How To Convert Blu-ray To iPod Video?
I think you can try Leawo Blu-ray Ripper, it is an all-inclusive tool for handling both Blu-ray and DVD discs. The ability to decrypt Blu-ray disc with MKB level ranged from 0 - 21 and with AACS and BD+ protection has made it the strongest ever to rip Blu-ray videos.
Here is the full guide to tell you how to rip blu-ray or DVD to iPod video.
Sep 18, 2009 | Apple Audio Players & Recorders
116 people viewed this tip
 Grubhead
Grubhead
