Tip & How-To about Computers & Internet
The Windows Vista password cracker for 5 Minutes
Have you ever tried to log into a Windows computer for a few minutes and you finally realize that you forgot the password? There are some ways to crack the password and it doesn't involve reformatting and reinstalling Windows.
Method 1. Use Windows Vista installation disk
Insert Windows Vista installation disk to the CD-ROM drive, restart your computer. Do the settings under CMOS to boot the computer through CD. When the installation interface appears, click "Repair Your Computer" (repair system) in the subsequent pop-up dialog box, select the "Command Prompt". After the system calls the command prompt windows, enter "mmc.exe" and press " Enter", the tne console will be called. Select the file "Add/Remove Administrative Unit", the system will pop up another dialog windows once adain. In the left side of the dialog windows select "local users and groups", and then click " OK" to complete the adding process. After adding is completed, the system returns to the console interface, click "Local users and Groups" om the left side of the windows, then click "User” and the system will list all the users in the right side of the current window. Right-click the user you are to crack, select "Set Password" in the pop-up "Set Password for Users" dialog box, and click "Continue”. The system pops up a window for you to set a new password. At this point, the Vista system does not require you to enter the previous password, but to set a new password directly. After you enter a new password, click “OK”, and the system will pop up a dialog box, indicating the setting is successful.
Method2. Use software programs to recover the password
Well, I’m a computer fun and very interested in computer. Then the above methods are very suitable for me, after several settings will do the job. However, there are still some friends who are not familiar with computer settings. What I said above just doesn’t make sense to them, does it? Well these friends are recommended to use computer software tools. Then you don’t have to touch those annoying terms but to follow the instructions with mouse clicking and pressing keys will be OK. are highly recommended as they are just of this kind. They can automatically clear the administrator password and easy to operate.
Just take you 5 minutes to solved your problem.
You can view more here:
http://www.lostwindowspassword.com
Hope it can help you, if you still can’t solve your problem, please contact me:
annyyu22@gmail.com
Computers & Internet Logo
forgot my email pasword
Hi!
If you forgot password. You need to go to log in page and then look for lost or forgot password then click forgot password. Then the system will guide you in some ways to recover your lost password.
Sep 10, 2011 | Computers & Internet
I forgot the domain controller password and cannot get past the log in screen do you have a way past it ? Thank you Andy Allen
The best and easiest way to reset the local or domain admin password. Reset domain password with Windows Password Rescuer Advanced. By this small software you can easily reset the domain password without lose anything and do not require any tech operation.
Get to the point, now let us see the step-by-step guide to recover domain password with Windows Password Rescuer Advanced. To recover Windows Server 2000/2003/2008 domain administrator/user password, follow four steps below:
Step 1. Download and install Windows Password Rescuer Advanced and use it to burn a Windows password recovery disk with CD/USB..
Step 2. Set the locked computer to boot from CD/DVD-ROM or USB drive.
Step 3. Boot the locked computer from Windows password recovery disk.
Step 4. Reset Windows 2008/2003/2000 local or domain administrator password by a few clicks.
May 08, 2011 | IBM PC 300GL PC Desktop
i forgot my password on the eee pc 701SD how do i reset it
Forgot Windows 7 Password?
  • What can you do if you forgot Windows 7 login password? Can't remember win7 user passcode? This article helps you to access it.
Jan 10, 2011 | ASUS Eee PC 701 Notebook
i forgot password how can i use
This is hard to answer without knowing what operating system you are referring to.
If you are using windows XP you can try logging on with
Username: Administrator
no password
The go in to the control panel and reset a password for the user you want to log in with.
Log out and log back in.
Dec 06, 2010 | Computers & Internet
loss computer password
Hi.
I will try to help you.
If you mean a Windows Password, for me is imposible to help.
if the password is in the setup, you just have to remove the battery mounted in the mainboard and install it again after few seconds.( with the computer turned off)
Turn your computer on and there is no more password.
I hope this could help.
Jul 11, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
121 people viewed this tip
David Payne
David Payne
