Tip & How-To about Cameras
Should we treat a digital camera like an egg?
I wish I had a penny, for each time I read about somebody having a stuck lens problem, or it won't go out, or in, or the zoom doesn't work right. And I know their pain, but we have to learn from that experience so that we don't repeat it. This tip isn't meant to call anyone careless, but rather emphasize why taking care not to damage a digital camera is the difference between enjoying taking pics, or trying to figure out a "free fix" on the internet. I'm not a camera tech, per se, but I've taken a couple of them apart, and I was impressed and amazed by their complexity. Leaving out the main boards and controls, I will concentrate on the composition of the lens assembly. It's a complex assembly consisting of electronic circuit controls, electro-magnetic focusing magnets, 5 very small, plastic gears, and various plastic parts. Imagine the lens is extended. The gears have driven it to the predetermined spot the microprocessor told it to go to. The gears are all engaged, ready to "pull" the lens back in, when the camera is turned off, but alas, Uncle Jack absentmindedly sits on the couch, where, unfortunately, the camera is setting. Something has to give, but it's not Uncle Jack's er, well, you get the message. Sometimes, the gears just jam, sometimes they break.
So back to the original question, and the answer is pretty much yes, inasmuch as possible. When you shoot pictures, wear the wriststrap to help you catch the camera in case it slips, you get bumped, etc. I've dropped my Olympus FE-310 about 3 times from a height of 3 feet, and it's still good to go, so they are tough, to a point. Although some experts in the field criticize hard cases (they claim the fibers can wear in them and get into the lens assembly, jamming it up, and maybe they can), I think it's wise to have one, weighing all circumstances. If you have a soft case, or no case, and it's in a pocket, purse, or coat or backpack, the power button can get accidentally pressed, and any restriction to the opening of the lens can damage the assembly, and render the camera useless. Also, one fair bump on the glass LCD display, and it's broken.
So to sum it up, should we treat a digital camera like an egg? The answer is "inasmuch as we can". Accidents will, unfortunately happen, but limiting them will help ease the burdon they have on our wallets!
Cameras Logo
sanyo vpc-s1213 12 megapixel, 3x optical zoom lens stuck out, won't turn on
Mine did the same thing after I put in a new sd card. Finally after trying everything else, took out the sd card and it worked.
Apr 10, 2012 | Cameras
zoom Lens stuck out, won,t close. Says camera problem #E45
that error code indicates the the Lens of teh camera is already defective., In most cases if the lens is stuckout or stuckin camera will not stay On or It will not Turn On at all. For this case you need to call Tech support to send you camera for repair toll free 1 800 235 6325 extension 12
Nov 12, 2009 | Kodak EasyShare V530 Digital Camera
Zoom is stuck and it wont stay on
Have you tried using a fully charged battery?
also, there could be a dust build up or a sand residue stuck inside the lens that it why its having a hard time coming in or out eventually.
Try to hold your camera, with the lens facing down, from your right hand and while turning it on, hit the camera gently on your left palm. Try this several times.
Sep 04, 2009 | Panasonic Lumix DMC-LZ3 Digital Camera
Zoom ring on 18-55 mm lens is locked/stuck
Are you sure it's the zoom ring that's stuck, and not the focus ring? The focus ring doesn't move when the camera is in autofocus.
If it's indeed the zoom ring that's stuck, you can spend more money than the lens is worth in repairs, or buy a replacement (circa 35 dollars on ebay) for dreadfully cheap. Good luck.
Apr 06, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Zoom error
when the lens comes out, gently pull it as far as it will go, wiggle it a bit and it should right itself. just tried it with mine and it's sorted.
nice
Nov 07, 2007 | Fuji FinePix A600 Digital Camera
212 people viewed this tip
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
