Tip & How-To about Vehicle Parts & Accessories
How to get a Viper alarm out of valet mode
Exiting Valet Mode with Key Fob:
1. Open the entry door.
2. Press the lock button.
3. Press the unlock button.
4. Press the lock button again.
5. Ensure the red LED is a steady glow.
Exiting Valet Mode with Valet Button:
1. Turn the ignition ON.
2. Turn the ignition OFF.
3. Press and hold the Valet/Program button for 10 seconds.
4. Ensure the red LED is a steady glow.
Vehicle Parts & Accessories Logo
programming a honda transponder key
did some quick research for you and found this easy and very clear step by step instructions on how to program your transponder car key to your vehicle.. this works for the following models though :
Accord 2003 to 2006
Civic 1999 to 2006
Element 2003 to 2006
Odyssey 1999 to 2006
Prelude1999 to 2001
Accord SE 1997
CR-V 1998 to 2006
Insight 2000 to 2006
Pilot 2002 to 2006
now here are the steps:
  1. Turn the ignition on
  2. Press Lock/Unlock within 4 seconds
  3. Turn ignition off and hen back on within 8 seconds
  4. Repeat steps 2-3 two times
  5. Press Lock/Unlock again within 4 seconds. The system should now lock and unlock the vehicle to indicate it is in programming mode.
  6. In the next 10 seconds: press Lock/Unlock button allowing the doors to lock/unlock once; then press lock/unlock button of each remaining key, allowing the doors to lock/unlock once.
  7. Switch ignition off and then remove the key
Civic 1996-1998
  1. Turn ignition on
  2. Press and hold the valet button which is situated on the radio within 5 seconds.
  3. System should now lock and unlock the vehicle indicating it is in the programming mode
  4. Within 5 seconds turn ignition OFF and press Lock/unlock on the remote fob to be programmed
  5. Within the next 10 seconds, press Lock or Unlock of any remaining keys, allowing the doors o lock or unlock once.
  6. Release valet key
Radio remotes 2 and 3 button types
  1. Switch ignition on and repeat for 3 times.
  2. Press he lock button, switch the ignition off and back on and then press lock button again.
  3. System should now lock or unlock
  4. Press the lock button of all remotes to be coded. The car should acknowledge this by locking/unlocking each time
  5. Switch ignition off to exit the programming mode.
If you will have any further doubts or question to ask i suggest you to check out the page where i found this which is http://www.carkeyadvice.com/step-by-step-fob-programming-guides/honda :) i hope this was the solution you were looking for mate! happy happy new year!
Dec 30, 2012 | 2007 Honda Pilot
I reeplaced the fuel pump, fuel filter, and fuel pressure regulator. thinking that was the problem! But was told that the alarm might be the problem so i pressed the alarm twic and the truck started but when i turned it off it wont start again. need some help ! Want to disconnect the system !
You must put the alarm on a valet mode to see if the alarm is causing this problem
To enter or exit Valet Mode
2. Turn the ignition off
3. Press and release the valet switch within 10 seconds
The status Led will light solidly if you are entering valet mode, and it will go out if you are exiting valet mode.
To enter or exit Valet Mode using the transmitter:
1. Open any vehicle door.
2. Press and realese lock and unlock buttons at the same time
3. Press and realese Aux button
4. Press and realese the lock and unlock button at the same time again
The status led will light solidly if you are entering Valet Mode and it will go out if you are exiting Valet Mode
Now when in Valet Mode try to start the engine, if the problem persist the alarm has nothing to do with it
Jan 11, 2011 | 350 HV ESP Security System 350HV ESP
HOW TO PROGRAM 2003 TOYOTA CAMRY FACTORY REMOTES
1. Driver door open and unlocked. Key out of the ignition
2. Insert the key and remove 2 times in 5 sec.
3. Close and open driver door 2 times in 40 sec.
4. Insert the key and remove it again from ignition.
5. Close and open driver door 2 times in 40 sec.
6. Insert the key in ignition,
7. Close the door,
8. Turn to on and back to lock in 1 second intervals. 1 time for add, 2 times for rewrite, 3 for confirmation 5 for prohibition. (yes, there is no “4”)
9. Remove the key
10. Power lock will cycle to confirm
11. For add or rewrite mode within 40 sec of the confirmation,
A. press “lock” and “unlock” buttons of the FOB at the same time between 1 and 1.5 seconds.
B. within 3 sec press “Lock” button for more than 1 sec and release.
C. If it’s correct, the power door lock will cycle once. If it’s wrong the door lock will cycle twice.
Sep 17, 2009 | 2003 Toyota Camry
I need to program the key fob
. Enter 5-digit permanent entry code into the keyless entry driver door keypad. 2. Within 5 seconds of pressing last button of code, press the 1/2 button. All doors will lock then
unlock confirming you are in programming mode.
3. Press any button on first Keyless Remote within 5 seconds of pressing the 1/2 button. Locks will
cycle to indicate succesful programming.
4. If you are programming more than one Keyless Remote (Including any exsiting remotes) Press
any button on second keyless remote within 5 seconds of previous remote. Locks will cycle again
to indicate succesfull programming. (If the keypad light goes out before all remotes are
programmed the entire process must be repeated).
5. Press the 7/8 and the 9/0 buttons simultaneously on the keypad to exit program mode.
Jun 29, 2009 | 1997 Mercury Grand Marquis
2,695 people viewed this tip
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
