Tip & How-To about Pioneer AVIC-N5 In-Dash DVD Multimedia Navigation Receiver
Pioneer AVIC N5 Installation Manual
Have you misplaced your Pioneer AVIC N5 GPS Multimedia System Installation Manual?
Would you like a digial, searchable, pdf version of the Pioneer AVIC N5 GPS Multimedia System Installation Guide?
Follow this link to download a pdf version of the installation manual.
I hope that helps.
Pioneer AVIC-N5 In-Dash DVD Multimedia Navigation Receiver Logo
can you repair a avic-n2 gps antenna
I must have been misunderstood as i too need the advice to transfere my system to english thanks.
Apr 13, 2012 | Pioneer Avic-n1 Avic-n2 Avic-n3 N4 N5 Gps...
Pointer creeps around until it shows that I;m going backwards down the highway. I go to settings and realign it and after a while it creeps around again. It worked good in my old truck but not in new truck after Pioneer dealer installed it. also won't dim at night.
As far as the pointer goes, check your GPS antenna installation. It might be getting interferance from another antenna. There should be somewhere in the software where you can check the signal strength of your GPS antenna. Make sure you install it where you are getting optimal strength. If you are getting nothing then your GPS antenna might be bad. You can order another one off of ebay for about 20 bucks if that is the case.
Usually when the night time/day time feature of the unit doesn't work the wire in the Avic wiring harness that gets the signal from your car harness isn't installed to the right wire or is loose. There is also a possibility that the aftermarket harness that they put on so they won't mess up your factory harness doesn't have the wire that carries the signal for your light control. Any way you put it, if you really want this fixed you might want to take it back to whoever put it in...
Jan 24, 2010 | Pioneer AVIC-N5 In-Dash DVD Multimedia...
1,789 people viewed this tip
Top Pioneer GPS Experts
David Burbee
David Burbee
Are you a Pioneer GPS Expert? Answer questions, earn points and help others
