Tip & How-To about Computers & Internet
How to Fix Registry Errors and Optimize PC?
The Windows registry is a database that stores settings and options for Microsoft Windows operating systems. It contains information and settings for hardware, operating system software, most non-operating system software, and per-user settings. The registry also provides a window into the operation of the kernel, exposing runtime information such as performance counters and currently active hardware. Registry is so important that Microsoft suggest users not to edit it, or it will affect some functions of the system even cause system crash.
The most common registry error is DLL errors. If users frequently install and uninstall software, it can also leave some wrong uninstall entries in the registry. Some anti-virus or anti-spyware will false report and destroy DLL file of some soft ware. Without DLL file, the program will pop up some strange message and can’t run. Also, Control Panel can’t remove DLL files of soft ware. If these DLL files stay in registry, this will cause system errors. Day by day, registry is full of junk files and the computer will run slowly and...
Complete download and guide continues on http://digitalpowering.blogspot.com/2010/04/how-to-fix-registry-errors-and-optimize.html
Computers & Internet Logo
wat does regedit means
regedit is an an inbuilt Microsoft Registry Editor. To start the regedit.exe go to Start>>>Run>>> type regedit and click OK. The Microsoft Registry Editor (regedit.exe) enables you to view, search for, and change settings in your system registry, which contains information about how your computer runs. Although you can use Registry Editor to inspect and modify the registry, doing so is not recommended, because making any incorrect changes can damage your operating system. Please go to http://en.wikipedia.org/wiki/Windows_Registry for more details.
Mar 22, 2012 | Acer Computers & Internet
vhjytry
The Windows Registry is a hierarchical database that stores configuration settings and options on Microsoft windows operating systems. It contains settings for low-level operating system components as well as the applications running on the platform: the kernel, device drivers, services, SAM, user interface and third party applications all make use of the Registry. The registry also provides a means to access counters for profiling system performance.
Sep 29, 2009 | Computers & Internet
Error 1311: source file not found:E\LENOVO3000 Y410 USER GUIDE\VISTA\6.LAN\FILES6~1.cab , Verify that the file exists and that you can access it.
The cause of the error is a problem with the Microsoft® Windows® Installer program used by the software. It produces the error when the registry entry AllocateCDRoms at the following subkey is set to a value of 1.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
Warning!
Problems caused by improperly editing the Windows registry could render your computer operating system unusable. Microsoft has provided a wealth of critical information you need to know about the registry in the Microsoft Knowledge Base at http://support.microsoft.com/support.
Use the Microsoft® Registry Editor only at your own risk and only after backing up the registry as well as the system.dat and user.dat files as outlined in ARTICLE-ID: Q132332 "How to Back Up the Registry" in the Microsoft Knowledge Base. Additional information about the registry is also contained in the Help topics in the Microsoft Registry Editor.
Start the Registry Editor and locate the following subkey:
goto start->run and type regedit to start registry editor
Change the value for the AllocateCDRoms entry to 0.
Exit the Registry Editor.
Dec 28, 2008 | Lenovo 3000 Y410 Laptop
regestry editor
A central hierarchical database used in Microsoft Windows 98, Windows CE, Windows NT, and Windows 2000 used to store information that is necessary to configure the system for one or more users, applications and hardware devices.
The Registry contains information that Windows continually references during operation, such as profiles for each user, the applications installed on the computer and the types of documents that each can create, property sheet settings for folders and application icons, what hardware exists on the system, and the ports that are being used.
The Registry replaces most of the text-based .ini files that are used in Windows 3.x and MS-DOS configuration files, such as the Autoexec.bat and Config.sys. Although the Registry is common to several Windows operating systems, there are some differences among them.A registry hive is a group of keys, subkeys, and values in the registry that has a set of supporting files that contain backups of its data. The supporting files for all hives except HKEY_CURRENT_USER are in the %SystemRoot%\System32\Config folder on Windows NT 4.0, Windows 2000, Windows XP, Windows Server 2003, and Windows Vista. The supporting files for HKEY_CURRENT_USER are in the %SystemRoot%\Profiles\Username folder. The file name extensions of the files in these folders indicate the type of data that they contain. Also, the lack of an extension may sometimes indicate the type of data that they contain.
Jun 20, 2008 | Microsoft Windows Vista Ultimate Edition
139 people viewed this tip
David Payne
David Payne
