Tip & How-To about Computers & Internet
How to Update and Fix Drivers?
Drivers are software used to drive hard ware to function properly. Incorrect operation and virus attacks etc can cause driver errors and affect PC performance. Most of PC users don’t know how to fix strange driver errors and find the compatible driver to update, which causes some inconvenience in their life.
Driver Checker is a powerful drive manager. It provides users with one-click Backup and Restore option. Users can easily backup and restore their drivers. With Driver Checker, uses can fix 98% of device driver errors, such as corrupted drivers, missing drivers and half-installed drivers etc. if you are a game fans, it can greatly improve your graphics card performance to maximum. When some drivers are seldom used, Driver Checker will remove them and save your valuable disk space and keep your device trouble-free. Besides, Driver Checker can detect all out-dated drivers and update them at a high speed.
With a large database, Driver Checker can easily fix and update reader driver, modem driver, game driver, keyboard driver, scanner driver etc. Even it can’t find at the moment, its advanced system can automatically submit the info to technical team and within one day solve user’s device problems.
You can FREE DOWNLOAD it and run a full driver check for..
details and complete graphic guide on the steps continues on http://digitalpowering.blogspot.com/2010/04/how-to-update-and-fix-drivers.html
Computers & Internet Logo
stop:0x0000007b
Hi Jefferson,
  1. Did you just install or make a change to a hard drive controller? If so, there's a good chance that the change you made caused the STOP 0x0000007B error.
    Undo the change and test for the 0x7B blue screen error.
    Depending on what changes you made, some solutions might include:
  2. Verify that the SCSI chain is correctly terminated, assuming you're using SCSI hard drives in your computer. Incorrect SCSI termination has been known to cause STOP 0x0000007B errors.
    Note: Most home computers don't utilize SCSI hard drives.
  3. Verify that the hard drive is properly installed. An improperly installed hard drive could cause STOP 0x0000007B errors and other issues.
  4. Verify that the hard drive is configured properly in BIOS. The STOP 0x0000007B error could occur if the hard drive settings in BIOS are incorrect.
  5. Scan your computer for viruses. Certain viruses that infect the master boot record (MBR) or boot sector can cause STOP 0x0000007B errors.
    Important: Make sure your virus scanning software is updated and configured to scan the MBR and boot sector.
  6. Update the drivers for your hard drive controller. If the drivers to your hard drive controller are outdated, incorrect, or corrupted then the STOP 0x0000007B error will likely occur.
    Note: If the STOP 0x0000007B error occurs during the Windows setup process and you suspect that the reason is driver related, be sure to install the latest hard drive controller driver from the manufacturer for use during the installation of the operating system.
    Note: This is a likely solution if the second hexadecimal number after the STOP code is 0xC0000034.
  7. Change the SATA mode in BIOS to IDE mode. Disabling some of the advanced features of SATA drives in BIOS could stop the STOP 0x0000007B error from showing up, especially if you're seeing it in Windows XP or during a Windows XP installation.
    Note: Depending on your BIOS make and version, SATA mode may be referred to as AHCI mode and IDE mode may be referred to as either Legacy, ATA, or Compatibility Mode.
    Note: While not a common solution, you may also want to try the reverse - see if IDE mode is selected in BIOS and if so change it to AHCI, especially if you see the STOP 0x0000007B error in Windows 8, Windows 7, or Windows Vista.
  8. Run chkdsk on your hard drive. If the boot volume is corrupted, the chkdsk command might repair the corruption.
    Important: You'll likely have to run chkdsk from the Recovery Console.
    Note: This will likely be the solution if the second hexadecimal number after the STOP code is 0xC0000032.
  9. Perform an extensive test of your hard drive. If your hard drive has a physical problem, one very likely situation is the STOP 0x0000007B error you're seeing.
    Replace the hard drive if the diagnostics you complete suggest that there is a hardware problem with the drive.
  10. Run the fixmbr command to create a new master boot record. A corrupted master boot record might be causing your STOP 0x0000007B error.
    Note: This will likely be the solution if the second hexadecimal number after the STOP code is 0xC000000E.
  11. Clear the CMOS. Sometimes the STOP 0x0000007B error is caused by a BIOS memory issue. Clearing the CMOS could solve that problem.
  12. Update your BIOS. In some situations, an outdated BIOS could cause a STOP 0x0000007B error due to incompatibilities with a hard drive controller.
  13. Update the hard drive controller's firmware if possible. Just as with the BIOS in the previous step, an incompatibility could be causing the 0x7B error and a firmware update from the manufacturer may correct the problem.
  14. Repair your Windows installation. If you've just replaced the motherboard in a computer without reinstalling Windows then this will likely fix your problem.
    Note: Sometimes a Windows repair will not fix a STOP 0x0000007B error. In those cases, a clean installation of Windows should do the trick.
    If you haven't just replaced your motherboard, a Windows reinstall probably will not fix your STOP 0x7B issue.
Hope this helps,
If you need further assistance please get back in touch and i'll see what else we can do.
Thanks,
Gary
Oct 17, 2013 | Toshiba Computers & Internet
Screen says "No bootable device --please restart system
The "no bootable devices found" error can create headaches, as well as occasional heartache if you're a laptop user.
This error appears when your computer is unable to find a device or file required for normal operation. It could indicate one of three issues: hard drive failure, software error or motherboard malfunction.
Any of these potential problems can render your laptop useless.
Hard drive failure or software errors can lead to data loss, which can cause anguish and catastrophe, depending on the files business information, family photos, student projects at risk.
Hard Drive Failure
The interior of a hard drive is akin to a turntable.
Most hard drives contain two to three discs, known as platters, which are similar to records. These platters are read and written on by a tiny needle called the read/write head, similar to the arm and needle on a turntable.
When a hard drive functions properly, the platters spin and the read/write head accesses the files necessary to boot your computer.
Improper function of any of these physical pieces can cause a mechanical failure and result in the "no bootable devices" error.
Software Error In rare instances, a software problem more specifically, a particularly nasty virus may cause the "no bootable devices" error. Most often, if a virus attacks and corrupts your system, your computer can still detect the hard drive and operating system, and you'll see some attempt at a normal boot. If a virus attacks certain system and startup files, however, they may not be detectable next time you boot your computer, thus causing you to see "no bootable devices." This may also happen if you are manually deleting files from your computer and accidentally delete system files. Motherboard b> Sometimes individual components of your laptop's motherboard malfunction, which can cause problems ranging from loss of wireless capabilities to inability to detect an external power source. If the components that detect your hard drive fail, your laptop is unable to receive signals from the hard drive and therefore may display the "no bootable devices" error. b> Repair b> Fixing a "no bootable devices" error can prove costly. If motherboard failure caused the error, you're probably better off purchasing a new laptop; unless it's under warranty; the average motherboard replacement costs $250 to $500. You can reinstall your operating system to resolve software errors, which is fairly inexpensive by computer repair standards, costing $80 to $130 dollars, but this step may also overwrite your existing data. In some cases, data may prove so badly corrupted it's not salvageable. If you can recover it, however, that raises your repair costs. additional fee. If hard drive failure caused your "no bootable devices" error, you can replace the drive. If you need to recover data from a malfunctioning hard drive, send it to a clean room for recovery. In a clean room, technicians disassemble your hard drive and image each platter; this kind of data recovery is extremely expensive, costing up to $2000 depending on the work involved. b> Prevention b> There is no way to guarantee you will never receive a "no bootable devices" error, but there are some steps you can take to help prevent it from happening. Keep your laptop on a flat surface when using it, and avoid any bumps that may cause the hard drive's read/write mechanism to lock up. Avoid transporting your laptop while the hard drive is active; turn your computer off while traveling. Additionally, regularly run an anti-malware program to catch and remove viruses or spyware before they cause system problems.
http://www.upgradenrepair.com/Issues/N/nobootabledevicefound.htm
Mar 12, 2013 | Toshiba Satellite S855-S5382 - 15.6 - Core...
Blue Screen windows 7 PC closes with a Blue Screen and Restarts
There are a lot of possible causes for blue screen errors, but most of them relate to the computer hardware. The cause of a BSOD error can be a temperature problem, a timing error, a resource conflict, hardware failure, a corrupt registry, a virus or simply a device incompatibility or driver error.
How to analyze blue screen errors The first thing to do to analyze a blue screen error is to check the meaning of the STOP error code. You need to stop Windows from rebooting when a STOP error is encountered. Once the blue screen of death is shown, you can check the meaning of the STOP error code. Together with the filename of the driver or module, this will give an indication of the error cause.
Another option to analyze the cause of the blue screen error is to look at the Windows system event log or to debug the memory dump (minidump) that Windows created when the error occurred. The event log can be viewed using the event viewer. Right-click Computer in the Start menu, and then select Manage. In the Computer Management window select Event Viewer. The information in the event log can be of great help to isolate the cause of the blue screen error.
Reading the minidump requires a bit more technical knowledge, but Microsoft has tools to read the minidump.
The most common cause of blue screen errors In reality, the most common cause of blue screen errors is a device driver problem. Outdated, incorrect or corrupt drivers can cause the system to encounter a STOP error, resulting in the BSOD.
So the easiest way to try and fix a blue screen error is to reinstall and update your system's device drivers. This will ensure that all driver bugs are fixed and that all hardware has the correct driver.
If you know which device caused the error, you can update or reinstall that driver first. The file name in the blue screen of death can help identify the driver. Look for a file with the .SYS extension and search for that file name.
If you do not have the drivers for all devices, or are not comfortable updating your PC's drivers manually, you can use a driver update tool to find, download and update all device drivers for you. Such tools will accurately identify your computer hardware, including any device causing an error, and automatically install the latest drivers for it.
In most cases updating or reinstalling drivers will solve your blue screen errors.
Other causes of blue screen errors However, if updating device drivers does not fix the blue screen error, there are a number of additional things to try:
  • Load the default BIOS values - resource conflicts and timing issues can be caused by incorrect BIOS settings.
  • Update the BIOS - especially after adding new hardware or installing a Windows service pack this can help fix issues.
  • Update Windows - missing updates, including service packs can be a source of stop errors.
  • Check your system - run a virus scan and spyware scan after updating your definition files.
  • Driver rollback - if you have recently updated a driver, you can use the driver rollback to revert back to the previous driver version.
List of STOP Errors Causing BSOD:
  • Stop 0×00000003 UNSYNCHRONIZED_ACCESS
  • Stop 0x0000000A IRQL_NOT_LESS_OR_EQUAL
  • Stop 0x0000001E KMODE_EXCEPTION_NOT_HANDLED
  • Stop 0×00000023 FAT_FILE_SYSTEM
  • Stop 0×00000024 NTFS_FILE_SYSTEM
  • Stop 0x0000002E DATA_BUS_ERROR
  • Stop 0x0000003F NO_MORE_SYSTEM_PTES
  • Stop 0×00000044 MULTIPLE_IRP_COMPLETE_REQUESTS
Here are 2 solutions:
Solution #1 Scan your registry for errors.
A Registry Cleaner scans your computer for errors in your PC's registry. Your computer's registry contains information about your Windows XP operating system, including driver, printer, software information. Over time, your computer's registry may start to contain obsolete data. A corrupt registry will easily slow down the speed of your computer because applications and drivers are loaded even though they're not in use. Fixing your registry of errors will not only prevent the Windows XP Blue Screen Of Death, it'll allow your computer to boot faster, open up multiple folders quicker. A listing of registry cleaners can be found here.
Solution #2 Process of Elimination
When the CPU calls certain functions from the RAM, or Random Access Memory, and the data rests in a faulty section of the RAM, this will cause the blue screen to appear. I recall a time whenever my computer booted up and started loading the Norton Anti Virus program, the blue screen error message would appear. This happens because the CPU is accessing data from faulty locations within the RAM when loading the anti virus software.
This method involves having 2 sticks of RAM. Remove 1 stick of RAM and wait to see if the blue screen surfaces, do the same for the other.
Through process of elimination, you'll find the cause of the Windows XP blue screen of death error.
Because getting into the hardware can be a little techy for computer hardware "adverse" readers, a simple 2 step plan is to first clear your PC of any registry errors. Then if the blue screen of death goes away, we would have saved ourselves the trouble of having to open up the PC casing and touching the hardware components
Dec 08, 2010 | Computers & Internet
drivers lost for the disc drive. error mssg. in
This is probably something caused by a virus and I suggest to reinstall teh operation system ..This will take care of the disk drivers as well ..cause usually the disk drivers are installed with the operation system,..
I think this is an error caused by a virus that attacks the optical drive driver and makes it disappear ..reinstalling the OS from a boot-able disk will fix it ..may sure you save all drivers from the support site before ..so that you will have at least the LAN driver to install and be able to connect after this..
if it refers to the raid drivers or so ..but still works ..eitehr disable teh raid in bios ..or reinstall them all
Nov 22, 2009 | Toshiba Satellite M45-S331 Notebook
DRivers appear to be corrupted or missing
Hardly impossible for disc drive's drivers have become corrupted unless you have had a bad attack of Viruses. Check the power and data cable. If needed use a new IDE cable. Clean the contact points of the RAM. Then try to enter the BIOS to see if it has recognized the drive! Physically lay your fingertips on that drive to determine any vibrations which is a indication that power is reaching the device. Then try using this sane drive on another PC to check if its working properly or not. Finally lok for the latest driver depending upon the model & make of your Firmware.....................sodeep
May 02, 2009 | Computers & Internet
234 people viewed this tip
David Payne
David Payne
