Tip & How-To about Computers & Internet
Frequent disconnection when using the Belkin Routers
Question:If your router loose the Internet Connection Frequently,Please follow these steps
Step 1: Connect the Modem----->Router------->Computer(Desktop or Laptop)
Step 2: Check whether you are able to see the Wired light in the Router
Step 3: Now Check the Model Number and the Version Number of your Router.
Note: You Can find the Version and the Model Number of the Routers at the underneath of the Device,it Starts with "F5D"
Step 4: Open an Internet Explorer and type www.belkin.com/support
Step 5: Download the Firmware from the above website for the model and the version number given in your Router
Step 6: Open an Internet Explorer and type 192.168.2.1 and click GO
Step 7: Now you will be able to see the belkin router setup page
Step 8: On your Left hand side click on Update Firmware
Step 9: Now it will ask for password,leave it blank and click on Submit
Step 10: Click on Browse and select the file which you download and click on Update
Step 11: The Firmware will start update in the Router ,please dont disconnect the power cable until the process gets completed
Step 12; After you have done this now you check the internet connectivity you wont be having any issue
Regards,
Aysaam
Computers & Internet Logo
cant connect to router
Hi this is priya .......
got your issue .....
If you are using a belkin router please try with the following steps
Step 1: Connect modem>>router
Step 2: Check whether you are able to go online
step 3: If you are able to go online connect the modem to the yellow slot on the router and then connect your computer to any one of the grey slot
Step 4: Open a new internet explorer page and type http://192.168.2.1
Step 5: You will get a router set up page
Step 6: Check towards the left column below Internet wan click on connection type and it will ask for the password and leave it blank and click submit
Step 7: Select the connection type as dynamic and hit next
Step 8: Below host name please click on change wan mac address and then hit submit
Step 9: Your status will be connected
If you have any issues please contact Belkin technical support 18002234456
Thanks .....
With regards.....
Priya
Oct 20, 2010 | Computers & Internet
We have plugged in the router to the instructions on the box what next not working
To restore the router to factory default settings, please do the following:
1. Unplug the router's power supply
2. Press and hold the reset button on the bottom of the router
3. Keep the reset button depressed and, at the same time, plug the power supply back in
4. Keep the reset button depressed for another 10 seconds
5. Release the reset button
======================= Manually configuration ==============================
Step 1 : Connect modem - Router - Computer ( Wired )
Step 2 : Open router setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left side under internet WAN click Connection Type
Step 4 : leave the Password Blank and click submit
Step 5 : Choose the connection type as dynamic and click next
Step 6 : Leave the Host name blank and click apply
Step 7 : On the left Under Internet WAN Click MAC Address
Step 8 : Click Clone and Click Apply changes
Step 9 : If the Internet status on the top right is connected
Step 10 : Then check if you have internet
Step 11 : if not Then unplug the Power Cable from the Modem And the Router
Step 12 : Plug the power Cord to the Modem
Step 13 : Wait till all the lights are on
Step 14 : Plug the power to the belkin
Step 15 : Check the color of the light in the belkin
Step 16 :If green then Check if you have internet
If not working then call belkin
=================== WIRELESS SETTING UP A WIRELESS CONNECTION ====================
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Aug 21, 2010 | Belkin Wireless Surf Router (F7D2301)
unable to connect wirelessly to laptop and PS3
ISP DSL ask your provider is your connection is PPOE or Dynamic and after do this.
Note is PPOE you need to type first your User name and Password
Jun 28, 2010 | Belkin Wireless Surf Router (F7D2301)
i have a new modem from comcast and now my router will not connect to the internet. i have reset the router and even connected directly to the router to see if i can get internet and still can not get through. what should i check next?
ISP Cable or Dynamic
Step 9: ISP DSL
Note: If your connection is DSL choose the connection type as PPOE
and set your User name and Password( ask yous ISP provider
May 27, 2010 | Belkin Wireless Pre-N (F5D8230-4) Router...
looses internet connection
Hi Friend,
Please follow the below website and check it will be step by step procedure
http://www.fixya.com/support/r4548393-frequent_disconnection_when_using_belkin
If you have any Clarification please feel free to contact us
Regards,
Aysaam
Apr 11, 2010 | Belkin (F5D8231-4) Wireless Router...
298 people viewed this tip
David Payne
David Payne
