Tip & How-To about Computers & Internet
Find out Full details about your Computer
Click Start--> Run
type DXDIAG and hit the Enter key
if you are running this command for the first time, following dialog box appears click YES
Click on Each Tab to view full Details and even perform checks on your computer Hardware!
Computers & Internet Logo
Solutions for "HP Pavilion dv5
File: \BOOT\BCD Status: 0xc000000F Info: An error occurred while attempting to read the boot configuration data. First try going into Windows safe mode with command line utility enabled. (F8 on bootup). In command console typechkdsk /f /r and enter Y for yes at the prompt. Wait for it to finish, it may take a while and then test the issue. If the problem persists, please continue with the following instructions. Rebuild BCD 1. Put the Windows Vista installation disc in the disc drive, and then start the computer. 2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears. 3. Select a language, a time, a currency, and a keyboard or another input method, and then click Next. 4. Click Repair your computer. 5. (Click the operating system that you want to repair), and then click Next. 6. In the System Recovery Options dialog box, click Command Prompt. 7. Type BOOTREC /FIXMBR, and then press ENTER. 8. Type BOOTREC /FIXBOOT, and then press ENTER. 9. Type BOOTREC /REBUILDBCD, and then press ENTER. Use the Windows Recovery Environment (WinRE) to run System Restore 1. Insert the Windows Vista installation disc into the disc drive, and then start the computer. 2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears. 3. Select a language, a time and currency, and a keyboard or input method, and then click Next. 4. Click Repair your computer. 5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next 6. At the System Recovery Options Dialog Box, click on System Restore. 7. Follow the System Restore Wizard instruction as usual and choose the appropriate restore point. 8. Click Finish to restore the system. Startup Repair from the Windows Recovery Environment (WinRE) 1. Insert the Windows Vista installation disc into the disc drive, and then start the computer. 2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears. 3. Select a language, a time and currency, and a keyboard or input method, and then click Next. 4. Click Repair your computer. 5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next. 6. At the System Recovery Options Dialog Box, click on Repair your computer. 7. (Click the operating system that you want to repair), and then click Next. 8. In the System Recovery Options dialog box, click Startup Repair
finaly if you do not have the cd you can use a copy too.
Kronoguy
Jul 04, 2011 | Computers & Internet
i foreget how to reset browser
Follow the below steps to reset Internet explorer 7 or 8
  1. Exit all programs, including Internet Explorer (if it is running).
  2. If you use Windows XP, click Start, and then click Run. Type the following command in the Open box, and then press ENTER: inetcpl.cplIf you use Windows Vista, click Start Collapse this imageExpand this image vistastartbutton.jpg. Type the following command in the Start Search box, and then press ENTER: inetcpl.cplThe Internet Options dialog box appears.
  3. Click the Advanced tab.
  4. Under Reset Internet Explorer settings, click Reset. Then click Reset again.
  5. When Internet Explorer finishes resetting the settings, click Close in the Reset Internet Explorer Settings dialog box.
  6. Start Internet Explorer again.
Nov 25, 2010 | Microsoft Internet Explorer 7
i need to know what kind of hard disk use in?
If you are using windows:
  1. Click on the Start button.
  2. Click RUN and a "Run" dialog box appears.
  3. Type dxdiag and press the ENTER key (or Click the OK button)
  5. Then browse through the tabs to look at the hardware and software details of your computer.
Feb 26, 2010 | Acer TravelMate 2355 Notebook
no sound
try this steps: 1. click windows button bellow 2. click run 3. type dxdiag then hit enter. (dxdiag is a diagnostic test to find out if your sound system is working properly. 4. after you launch the dxdiag in your system and there will be a dialog box appear in your screen, just click YES button then your done then after clicking the YES button the dxdiag box appear in your screen. 5. wait while the dxdiag box loaded it jurisdiction as shown below the box. then when it's done just click the next page button below. 6. To know if your system has a sound. simply click the sound button on the upper side of the dxdiag box. then click the Test DirectSound. when you click the specified button there will be a dialog box again but just click yes to play the sound but take note you should have speaker or a headset to hear the sound. 7.For more (you can install a sound driver for back up). God bless and I hope this step will help you in your problem.
Oct 25, 2009 | E-Machines eMachines W2686 PC Desktop
Windows Installer cannot be accessed. Message shows.I have tried everything but nothing happens.
Method 1: Use the Msconfig tool to confirm that the installer service is running loadTOCNode(2, 'resolution');
  1. Click Start, and then click Run.
  2. In the Open box, type msconfig, and then click OK.
  3. On the Services tab, click to select the check box that is next to Windows Installer
  4. Click OK, and then click Restart to restart the computer.
If that didn't do it,go to the next step.
Method 2: Re-register Windows Installer
  1. loadTOCNode(2, 'resolution'); Click Start, and in the Search box, type Msiexec.exe,
  2. click Search everywhere for All files and folders.
  3. The location of the file should be C:\Windows\System32
  4. Click Start, and then click Run.
  5. In the Open box, type regedit, and then click OK
  6. Locate and then click the following registry key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\MSIServer
  7. In the right pane of the Registry Editor window, double-click ImagePath.
  8. In the Edit String dialog box that appears, make sure that the string in the Value data box contains the correct path for the Msiexec.exe file that you determined in step 3.
    If the Value data box does not contain the correct path, make changes to correct the path, and then click OK to close the Edit String dialog box
  9. On the File menu, click Exit to quit Registry Editor.
  10. Start your computer in Safe mode, and then register the Msiexec.exe file.To do this, follow these steps:
    1. Shut down your computer, and then restart your computer.
    2. Restart your computer and press the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, press the F8 key when you see the Boot menu.
    3. Use the ARROW keys to select Safe Mode, and then press ENTER.
    4. If the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
    5. Log on to the computer.
    6. Click Start, click Run, type msiexec /regserver in the Open box, and then click OK.
  11. Shut down your computer, and then restart your computer normally.
Method 4: Reinstall Windows Installer
To reinstall the Windows Installer, follow these steps.
  2. In the Open box, type cmd, and then click OK.
  3. At the command prompt, type the following lines. Press ENTER after you type each line. cd %windir%\system32
    ren msi.dll msi.old
    ren msiexec.exe msiexec.old
    ren msihnd.dll msihnd.old
  4. At the command prompt, type exit, and then press ENTER.
  5. Restart your computer.
  6. Update the Windows Installer files to the latest version
  7. After the installation of the Windows Installer is complete,restart your computer normally
    Check the Windows Installer service (Control Panel - Administrative Tools, Services) is running. It should be set to manual or automatic. Also check the dependency Remote Procedure Call (RPC) service is running.
If that don't do it,Try this Open a command prompt.(Start,all programs,accessories,Right click on command prompt and run as administrator) type sfc /scannow
Feb 22, 2009 | Microsoft Windows Vista Ultimate Edition
169 people viewed this tip
David Payne
David Payne
