Tip & How-To about Computers & Internet
Find hardware device unrecognized by OS
People sometime com in to problems when they want to fin the drivers for there hard ware common questions are
>>wht is my main board
>>wht is my ram type (ddr1>,ddr2?)
>>wht is my vga card type,ram
normalcy this require removal of system casing and a look inside the pc but
a simple freeware could do the trick. its'called CPUZ, you can download it at http://www.cpuid.com/cpuz.php
It will tell you the info about your PC, including CPU name & brand, internal & external clock speed / multiplier, core vltage, BIOS, and of course -- Memory module, frequency, timing, vendor, speed ... etc.
Screen shot
Computers & Internet Logo
what is an internal harware error
Hard ware(Printers): which you can touch in printer, like operational panel, cartridge, print heads,cables,trays etc,,
Internal hard ware(printers): Gears,RAM, Formatter, DC board,hard disc, CD's, fan,mechanical parts etc..,
Software(printers): Drivers, instruction codes, programmings etc..
Aug 25, 2014 | HP P3015 Laser Printer
about ask the hard ware
If you are asking how to make the internal sound card (built into the main board) work, you need to make sure the correct driver software is installed. You can download the sound drivers from HP here:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=34886&lc=en&dlc=en&cc=us&product=95524&os=228&lang=en
Downloading and installing the latest drivers from the manufacturer is a good place to start when you have sound problems. Also be sure that the sound devices are properly enabled in the Windows sound setting screens.
If your question refers to how to install some external sound device, normally it is a simple matter of connecting the device and installing any software supplied by the manufacturer. You should refer to any instructions that were supplied with the device.
Feb 03, 2009 | Compaq Presario 700 470024-192 Notebook
no display
sir usually in beeping its either you have a damage peripherals so it will not work and have you recently place new cards or hardware on your board? if you did or not please remove all hard ware and carefully place them back again and make sure that they will contact on their corresponding pins, then try plug it again, and make sure that all of your hard ware are in good condition and no damage even one. please try this solution please send us your feed back thank you and fixya..
Dec 13, 2008 | Mercury P4VM800M7 Motherboard
Hi tried that... sound card is connected and vm-ware tools is also installed... its surely a problem with the windows 2003 server. because the error sound is played through the macbook speakers but not any of the player audio... thats due to the "multimedia audio controller" error or no driver. i tried a lot to fix that too.... but i failed.... thats y i am here. I tried installing "Yamaha driver - Yamaha Sound Card Drivers -" - its a search result for intel 440BX board.... help me to find the right driver to solve this error...... ================================================== ===== Operating System System Model Windows Server 2003 Enterprise Edition Service Pack 1 (build 3790) VMware, Inc. VMware Virtual Platform System Serial Number: VMware-56 4d d0 52 9f 73 ec 14-68 8d f5 e0 68 26 7f be Enclosure Type: Other Processor a Main Circuit Board b 2.40 gigahertz Intel Core2 Duo 64 kilobyte primary memory cache 16384 kilobyte secondary memory cache Board: Intel Corporation 440BX Desktop Reference Platform BIOS: Phoenix Technologies LTD 6.00 07/07/2008 Drives Memory Modules c,d 21.46 Gigabytes Usable Hard Drive Capacity 19.04 Gigabytes Hard Drive Free Space HL-DT-ST DVDRW GSA-S10N [CD-ROM drive] 3.5" format removeable media [Floppy drive] VMware, VMware Virtual S SCSI Disk Device (21.47 GB) -- drive 0 384 Megabytes Installed Memory Slot 'RAM slot #0' has 256 MB Slot 'RAM slot #1' has 128 MB Slot 'RAM slot #2' is Empty Slot 'RAM slot #3' is Empty Local Drive Volumes c: (NTFS on drive 0) 21.46 GB 19.04 GB free Network Drives None detected Users (mouse over user name for details) Printers local user accounts last logon Administrator 8/27/2008 5:37:48 PM (admin) local system accounts Guest never SUPPORT_388945a0 never Marks a disabled account; Marks a locked account None detected Controllers Display Standard floppy disk controller Intel(R) 82371AB/EB PCI Bus Master IDE Controller Secondary IDE Channel [Controller] VMware SVGA II [Display adapter] Bus Adapters Multimedia LSI Logic PCI-X Ultra320 SCSI Host Adapter Intel(R) 82371AB/EB PCI to USB Universal Host Controller Standard Enhanced PCI to USB Host Controller None detected Communications Other Devices VMware Accelerated AMD PCNet Adapter primary Auto IP Address: 172.16.147.128 / 24 Gateway: 172.16.147.2 Dhcp Server: 172.16.147.254 Physical Address: 00:0C:29:26:7F:BE Networking Dns Server: 172.16.147.2 Microsoft AC Adapter USB Human Interface Device (2x) Standard 101/102-Key or Microsoft Natural PS/2 Keyboard HID-compliant mouse (2x) VMware Pointing Device [Mouse] Generic USB Hub USB Composite Device USB Root Hub (2x) ================================================== =====
see heres the thing when using VM-Ware, VM-Ware doesnt use drivers for your physical hardware, because it emulates the hardware that is seen in the hardware information of your system preferences.
So installing even drivers for the "emulated" hardware will not work, as VM-Ware uses its own drivers for the hardware, which are included with the VM-Ware Tools, if that doesnt seem to work, you may want to contact VM-Ware support, as they may have a better solutiuon.
Aug 29, 2008 | Intel Motherboard
main board soft ware
Fiend your solution direct from mercury. Here is your solution.....
http://www.mercury.com/motherboard/prob676ijt65/solution
aamknr-10
Mar 06, 2008 | Mercury P4VM800M7 Motherboard
358 people viewed this tip
David Payne
David Payne
