Tip & How-To about Heating & Cooling
Want to save lots of money on your electric bill water heater
Its easy all you have to do is install a timer on your electric water heater ...the timer can shut off your waterheater when you sleep or when your at work or both it works great and WILL save lots of money ! also you can all ways put a buy pass switch so if you need hot water when you would normanaly need it you can have it ... if anyone needs help with installing this ... send me a mesg on fix ya or airforceac@live.com
Heating & Cooling Logo
RINNAI R94LS CONVERT TO NATURAL FROM PROPANE
The electric water heaters have replaced the traditional of water heating. The advanced features and the latest technologies of water heater have made it so easy for everyone. Find the best electric water heater on the market today. Read electric water heater reviews and comments from experts. Almost each product is manually reviewed and tested.
Electric Water Heater List Reviews waterheaterlist com
Jan 28, 2013 | Rinnai R94LSi Tankless Water Heater...
Where is water shut off valve for Rheem 40 gal electric water heater?
The water does not have a shutoff valve. The valve should have been separately installed, usually directly above the water heater on the cold water line.
Gary
Sep 25, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
my reliance electric waterheater wont shut off.i replaced both upper and lower themostats. it runs till it trips the reset switch.sounds like the upper element still running after lower shuts off
Test elements for short to ground.
Element that is shorted in center might not trip breaker.
Because thermostat only turns off one leg of 240V circuit, the element will continue heating using 120v to ground:
http://waterheatertimer.org/How-to-test-water-heater-element.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Nov 01, 2009 | RELIANCE ELECTRIC WATER HEATER
restricted air inlet
Clear the area around the bottom of waterheater so as to allow air flow around mesh area built into base of water heater and or open unvented door passages involving waterheater. This mostly a safty issue which seldom occurs if not remedy quickly.
Please rate. Thanks JJ505
Mar 29, 2009 | General Electric GE SmartWater Household...
171 people viewed this tip
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
