Tip & How-To about Cell Phones
When your having trouble charging your phone , because your phone is broke
1.take the battery out
2. stick it in a potato
3.put it in the Freezer
4. wait 12 hour
5. stick batttery back in cell phone
6.throw away potato or heat it up well and eat potato
7.enjoy cell phone use
warming- if battery doesnt work either buy another potato or buy a charger
Cell Phones Logo
Okay, I'm working on a scooter for my nephew that originally came with (2) 12 volt 12Ah batteries minus the charger. and I know I need to replace them with (2) batteries of the same 12 volts and lets
not exact, to charge apropiate needs 10% more than nominal voltage. if not, will not charge the batteries.
And the charger its very important because you can over charge the battery.An example,if you have a 12 Amps Batteries each one if you put it in series will be 24 Volts.at parallel conection will be 12 volts but the double of Amps.
At serial connection will be 12 Volts the amps will be the same but the volts will be 24.
The charger at 12 Volts must be 13.8-14.5 DC Volts and divide the Amps in Hours.
The charger at 24 Volts must be 26-28 Volts. to charge well.
The charger for 12 amps batt example must charge 2 amps per hour at 6 hours = 12 Amps.(2 Amps Charger by 6 Hours Charging= 12 Amps.(Fully Charged.
3 Amperes Charger needs 4 Hours to charge 12 amps Batt.
5 Amperes Charger needs 2 Hours charging an a quarter
All of this is at DC Current.
Luck.
Oct 18, 2014 | UPG 12V 12Ah Electra Scoot-N-Go 88615...
how to remove the screen on a sliver 7 model
It's a little fiddly:
1) Remove the battery cover
2) Remove the 4 screws on the transceiver board
3) Unplug the 2 flex cables, coaxial cable and earpiece cable from the board.
4) Remove the transceiver board
5) Remove the rubber plug and antenna cover from the rear lower of the handset
6) Remove the 2 screws under this cover
7) Carefully unclip the bezel from the phone and remove it
8) Unclip the 6 clips holding the display bezel in place from the back of the phone - you need to use a thin screwdriver in the 6 slots (4 of them are under where the transceiver board was, the other 2 are in the batttery compartment.
9) Lift the display and frame away from the chassis.
When reassembling:
Make sure the keymat is correcly located on the pins on the front bezel
Ensure the earpiece cable is in the right place, and not trapped.
Be careful reattaching the cables to the transciever board - they are both small and fragile.
Sep 27, 2009 | Motorola Mobility SLVR L7 Cellular Phone
146 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
