Tip & How-To about Computers & Internet
How to Boot Yout Apple Mac Intel Base system In Dual Mode
Hello All,
If you want to install Windows XP or VISTA in your Apple Mac system and want a dual boot option.Try This......
Press the (OPTION) key while powering on the system.You can find both the OS drive Images.Click on the OS you want to Boot.
Tryy It
Computers & Internet Logo
I INSTALL WINDOW XP 2006 IN MY MAC BUT NOW WHEN I START MY LAPTOP THEN I HAVE SEEN MESSAGE NO BOOT DEVICE PRESS ANY KEY MEANS MY WINDOW IS NOT OPEN
When you turn on the computer again, hold the Option (a.k.a. the Apple key) and a new screen should pop up asking with partition you want to boot into.
Feb 28, 2011 | Apple MacBook 13"White /2.0Ghz Intel Core2...
how to install xp on this unit from vista
You have to format the hard disk before you can insall XP on a Vista machine, or you can try to install a dual boot system. Go to Microsoft.com and search for dual boot system help
Jan 29, 2010 | Computers & Internet
dual boot xp and vista on one hard disk
http://majorgeeks.com/VistaBootPRO_d5625.html
from here download vista boot pro ..and install it..there u can find option to add OS MENU while booting...
Feb 12, 2009 | Microsoft Windows XP Professional
2 operating systems
The Boot Configuration Data (BCD) store contains boot configuration parameters and controls how the operating system is started in Microsoft®Windows Vista.
Remove Windows Vista From Dual Boot System Windows Vista works slightly different from earlier versions of Windows when installed on a dual boot system, in that it has a completely different boot loader.
When Windows Vista is first installed as a dual boot operating system a new boot folder is added to the root directory of your PC. This is a hidden file and therefore is not noticed. When you boot your PC a menu appears with the following options:
  • Earlier versions of Windows
  • Windows Vista
Clicking the Windows Vista option will boot the PC into Windows Vista. If, however, you select the earlier versions of Windows option, another menu will appear from which you can choose Windows XP or whatever earlier version - Windows 2000 or Windows 2003 server - you installed first.
Because of this new boot loader it is not as easy to remove Vista from a dual boot system scenario. Simply deleting the Vista partition will, of course, remove Windows Vista, but, unfortunately, it will not remove the Windows Vista boot loader. For this reason, if you simply delete the Windows Vista partition, on rebooting your machine you will not automatically boot into Windows XP (or an earlier version). Instead you will once again be presented with a menu from which you have to choose which operating system you wish to boot to.
Obviously, once you have removed the boot loader and rebooted the Vista operating system will still be on the partition you originally installed it on. To remove Vista completely you will need to Delete the partition that Windows Vista was installed upon.
To remove this menu, or more to the point, the boot loader, proceed as follows:
1/ Boot the PC to Windows Vista
2/ Ensure you are logged onto the Internet and then download the freeware boot loader utility VistaBootPro (www.vistabootpro.org)
3/ Once you have downloaded VistaBootPro, install it on your machine
4/ During Install VistaBootPro will install an icon on your desktop
5/ Locate the VistaBootPro icon and Right Click on it. Then, from the drop down menu, Click on the Run As Administrator option
6/ User Account Control (UAC) will pop up and ask for permission to run the program
7/ After you have given UAC permission - you must be the administrator or have administrator privileges - VistaBootPro will run.
8/ Once VistaBootPro opens, Click on the Bootloader tab
9/ In the Bootloader Maintenance section, Click on the Radio button next to the option marked 'Uninstall the Vista Bootloader (Used to restore Legacy OS) option' and then Click the Apply button
10/ Finally Reboot your PC
11/ On rebooting your machine you will boot directly into Windows XP (or an earlier operating system). No menu will appear.
12/ All that is left to do now is to delete the partition which originally contained Windows Vista. (Assuming you wish to remove the Vista partition from your hard drive).
Sep 12, 2008 | Acer Aspire 3680 Laptop
how to install vista on I-MAC
Hi Harry
yes, vista can be installed on I-macs ...but i need to know which version of operating system do you have (whether it's leopard or tiger and version 10.5.2 or earlier)
I say so because new version of Leopard Operating system has a feature called "boot camp"... this is Apple's "bootloader" ... which means it will help you install windows Vista on Apple I-mac .
If you have genuin vista disk handy with you and after you have backed up all the data on the apple machine , this is what you gotta do....
1. Using the Finder, navigate through Applications, Utilities and run Boot Camp Assistant.
2. Click Continue on the Introduction screen.
3. Next, you will need to specify how you want your hard drive divided up for Windows. A separate partition will be created that Windows will use. Drag the divider to adjust the size for Windows as shown below. I recommend at least 15 GB to allow for the OS and some apps. When you are ready, click Partition and your disk will be prepared.
4. It is time to start the Windows installation. Insert your Windows Vista install DVD and click Start Installation. Your Mac will automatically reboot and boot to the install DVD.
5. Install Windows Vista as you would normally do. When asked where to install, select the partition called BOOTCAMP. You will need for format this partition with NTFS.
6. When Windows Vista has installed, remove the Windows Vista install DVD and insert your OS X 10.5 Leopard install DVD. Run the Boot Camp installer application and all the Windows drivers for your Apple hardware will be automatically installed.
7. When you want to switch to OS X or Windows, just reboot and hold down the Option key to select what partition to boot.
Jun 07, 2008 | Computers & Internet
199 people viewed this tip
David Payne
David Payne
