Tip & How-To about Computers & Internet
HOW TO REPLACE ACER LAPTOP LCD SCREENS
READ CAREFULLY FIRST BEFORE STARTING
Removing the screens bezels will void warantee
In Saying that ,
Heres how I would do a screen replacement,
You will need a small philips screwdriver for this ...
Remove the power and battery
To Remove the bezel from the front of the screen
There should be 4 or 6 screws holding the cover on,
Screws may be covered by rubber buttons,
then remove the screws holding the LCD to the hinges' frame.
Tilt forward your LCD and lie screen on your keyboard
LCD panels have a row of IC chips at the top that produce the images on your LCD so do not touch or flex this area because it may produce lines on the LCD or kill it completely.
botom of screen is inverter power and plug to screen
top rear of LCD is video feed from motherboard,
(above that are those important IC Chips-
DONT TOUCH THE CHIPS)
LCD wiil have tape fastening plug to the socket,
Remove tape and this will expose the plug.
Un plug from screens socket,
Reseat plug back into socket,
Put Tape back on to stop any unwanted movements,
Next step is to power up the LCD to test.
Rest LCD in back of lid and lie lid on table with base at 90 degrees for access to plug in AC power.
do not use battery for this test.
Turn ON power,
If it starts up, then you have a running machine again,
Shut down , unplug power and reassemble,
If LCD does not start then you need to replace the LCD panel and thats about all you can do,
Hope this helps.......
Cheers MisterdJ
Computers & Internet Logo
broken screen
To begin your fix, you'll need a few simple tools and a replacement LCD screen. For tools, I recommend a screwdriver with a variety of small bits, such as a Phillips #00 and a Torx T5. It's also a good idea to have a few thin metal blades or plastic spudgers. These are really handy for removing the trim that surrounds the screen.
As for the replacement LCD, you should be able to buy one either from the laptop manufacturer's authorized parts dealer or a third-party supplier. Depending the screen, they usually cost between $50 and $250 dollars-more if it's a high-end display or you buy an OEM replacement. Regardless, you'll want to buy a new screen that matches your broken one exactly. The only sure way to do this is to remove the broken one.
After disconnecting the power supply and removing the battery, carefully examine the bezel around the screen. You'll need to remove this bezel to access the screws that hold the LCD panel in place.
On this laptop, several rubber cushions hide screws, which hold the bezel in place. I'll need to remove these cushions and the screws that are underneath.
With the hidden screws removed, I used a thin metal blade to pop loose one of the bottom corners and worked my way around the bezel with a plastic spudger.
Feb 17, 2013 | Computers & Internet
how do you remove the screen
Televisions covered: typical Projection Televisions.
Projection TV's usually have a bezel surrounding the screen that is held on by a (firm) friction-fit to a rubber gasket.
Once the bezel is (carefully) removed, the screen itself is released.
How to remove the bezel: carefully pull it away from the cabinet of the TV (toward the front), by hand - its somewhat/slightly flexible. If a tool is used, one risks damaging the cabinet finish, or the bezel itself.
If I need to extract a screen, I'll usually release the upper 1/2 of the bezel from around the screen (removing the top and half of each side), then lift the screen panel itself up and out of the TV without removing the entire bezel - this way, I save the (unnecessary) work of removing the entire bezel, and also avoid the possibility of the screen panel falling out of the cabinet onto the floor in front of the set (as the last part of the bezel comes off the cabinet).
Its often tough to get this bezel off the first time, so when I take one off, I'll install a light coating of grease on the rubber gasket, since once it comes off the first time, it will inevitably need to come off again a few more times before the TV is fixed. And if the bezel is flexed too violently, it will break.
Cheap automotive bearing grease works fine.
Dec 23, 2011 | Mitsubishi VS-70707 70" Rear Projection...
screen is dark but if i put flashlight on screen i can read it
Seems like the backlight of your LCD is already failing, you need to replace it.
Hope this helps.
May 25, 2011 | Lifetime Gateway CX2728 Replacement Laptop...
there is green line in lcd screen thet will devlop or not
One of the chips at the top of your screen is faulty
and you can't fix it,Sorry.This may hellp tho.....
In Saying that ,
Turn ON power,
Cheers MisterdJ
Apr 13, 2010 | HP Computers & Internet
I have Acer Laptop suddenly now the screen remains blank even after switching on the laptop. Actually as I was surfing the net suddenly the screen display color changed and later I thought there is battery problem and I charged the laptop however even after full charge on clicking the button to start i see a blank page only and I repeatedly tried but no avail please help me
if you can see the start up screen in full color when it starts then the last update could have caused it,
But its more likely that the plug inside the back of the LCD has come loose and needs to be replugged back in,
In Saying that ,
Turn ON power,
Cheers Misterdj
Apr 12, 2010 | Acer Aspire 4520-5582 Notebook
1,185 people viewed this tip
David Payne
David Payne
