Tip & How-To about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
How To Fix Your Bissell Carpet Cleaner When Solution Won't Spray
If you have a Bissell Carpet Cleaner, and you're machine is not spraying water on the floor, there are several things that might be causing this. Here's a list of possible problems that might be causing the machine not to spray water:
It may be a problem with your pump belt. Bissell Carpet Cleaners use a belt that powers the pump to spray solution out. There are also a few other possible issues, but as a Bissell warranty station, the belt going bad out-numbers all other problems.
Remove the belt access door and inspect the pump belt to ensure it is not broken, worn or stretched. You may also check the belt by turning on the power and watching the brush on the bottom of the machine. If the brush rotates the belt is not broken.
Here's a great video that will show you how to check, and replace the pump belt on your ProHeat carpet cleaner:
How To Replace the Bissell ProHeat 2X Carpet Cleaner Belt Video:
http://www.bissell.com/VideoRating.aspx?id=1555
If this was not the problem, here are some other things that you may check:
  • Make sure there is liquid in both the Tank-in-Tank and the SmartMix bottle. Both tanks must contain fluid or the machine will not spray properly.
  • Check for proper placement of the o-ring on the SmartMix Cap Insert (some o-rings are detachable and need to fit over the straw; others are molded to the cap).
  • Check for liquid in the base of the machine where the SmartMix Bottle sits (SmartMix Reservoir). If there is no liquid in the reservoir, the neck on the SmartMix Bottle may be undersized and the cap will not make proper contact with the unit. If there is no liquid present, you will need a replacement SmartMix Bottle.
  • Check for the black or red tank gasket on the SmartMix Bottle Cap and on the bottom of the Tank-in-Tank Assembly. If gasket is lodged in base of unit or has been lost, reattach gasket on auto-load or order new gasket if appropriate.
  • Check the valves on the bottoms of the Tank-in-Tank and SmartMix Bottle to make sure water/solution will come through when the "x" valve is depressed. (Bladder or SmartMix bottle may be empty or the valve may be blocked internally.) Use a soft-bristled brush and hot tap water to clear any debris. Replace autoload assembly or cap/insert if necessary.
  • Check if the small rounded window tabs on the top edge of the Floor Nozzle are locked in their mating slots on the base of the machine, and not inadvertently lifting the tank up out of place.
If these suggestions have not resolved the problem you are experiencing with your machine, you might want take your machine to a local BISSELL Authorized Service Center. I really hope that this information was helpful to you. If you find what's wrong with your Bissell and have specific questions about how you can fix it, please just let me know and I'll be happy to walk you through step by step to fix any problem you may have on your Bissell.
Thanks,
Chris Jones
GoVacuum.com
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
my Bissell Proheat carpet cleaner/hose for cleaning will not spray anything
My ProSeries Carpet Cleaner won't spray. What ... - Bissell
www.bissell.com > Support > Helpful Resources > FAQs
BissellLet's start by figuring out where your carpet cleaner can spray. If you have no spray at all, start below. If you have no spray at the floor but can spray from the hose, scroll down for the ... Turn the unit on after cleaning and see if water sprays to the floor now. IV. .... My ProHeat® Self-Propelled's Powerdrive isn't engaging.
Bissell Carpet Cleaner Won't Spray. Easy Repair - YouTube
? 1:48
https://www.youtube.com/watch?v=nccdrjpGp34
Dec 20, 2013 - Uploaded by Cecil Argue
You may have a bad pump, clogged hoses or a clogged heater. ... Just want to tell you that this was the perfect ...
Nov 30, 2015 | Bissell Vacuums
bissell carpet cleaner will not spray the cleaning solution
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
hgjdg
Jul 21, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
2,094 people viewed this tip
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
