Tip & How-To about Audio Players & Recorders
Onkyo Remote Control Programming
Would you like help programming your Onkyo remote control to control other devices?
To program your Onkyo remote control, follow these steps:
  1. Hold down the REMOTE MODE button for which you would like to enter a code, and keep pressing it down.
  2. Press and hold down the DISPLAY button until the remote indicator lights up (about 3 seconds).
  3. Within 30 seconds, use the number buttons to enter the 5-digit remote control code for your device. (look these Onkyo remote control codes up in the codes list.)
  4. The remote indicator will flash twice to indicate a successful programming.
The Onkyo remote control codes, listed by brand, are available here.
I hope that helps.
i have a onkyo resiver and a olevia unaversal remote are thay compadable and whats the cods
If the Olivia remote control have set-up code/s for Onkyo brand devices, you can. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
Feb 13, 2017 | Olevia Televison & Video
Can you use an Onkyo RC-771M remote control to operate Onkyo receiver TX-SR502 ?
Unfortunately, the RC-771M remote doesn't control the TX-SR502. It will only work with these Onkyo models: TX-NR1008 and TX-NR808. The RC-567M is the one for the TX-SR502; replacement remotes that are exact replacements are still available from various places including Amazon.com .
Since the TX-SR502 was released in ~2004, that replacement remote probably won't control other devices that were released in 2004 or later. Onkyo changed its IR code programming before the TX-NR1008 was released in ~2010 and the RC-771M can't communicate with the older receiver. The manuals for the receivers listed above are still available from Onkyo on the product page under the Downloads tab.
I wish that I had better news for you.
Jan 31, 2016 | Onkyo TX-SR502 Receiver
onkyo remote control codes
Your Vizio universal remote should be able to search for an appropriate code. If a thorough search produces no result, you may have to try another universal remote.
Sep 09, 2014 | Televison & Video
want to know how to set up my bell expressvu remote to control my onkyo tx-sr605 receiver?
If you are trying to use another manufactures remote to control your Onkyo receiver they are the ones who are responsible for programming the Hexadecimal codes into their remotes. We do not have codes for any other manufactures remotes. You may want to try the following website for codes www.remotes.com or http://www.remotecodelist.com for any codes to program your remote. As we do not have the remote controller codes for non-Onkyo controllers- you can try the generic remote controller code: 62503 or 52503.
May 04, 2014 | Onkyo TX-SR605 Receiver
499 people viewed this tip
 Grubhead
Grubhead
