Tip & How-To about HP DeskJet F4280 All In One Printer InkJet
HP Deskjet F4200 Series All-in-One Printers Protection Fault Problem
A lot of HP Deskjet F4200 Series All-in-One printer users complain about the installation problem experienced with this product, especially those using the Windows XP operating system. The driver installs perfectly; it performs the alignment and prints the test page. But as soon as you print a document, photo, or anything from the computer, the printer fails and says "The program has encountered a problem and needs to close". When you go to the printer properties, you'll get a message: Function address 0x500a0490 caused a protection fault. (Exception code 0xc0000005) Some or all property page(s) may not be displayed.
The problem can be resolved by completely uninstalling the driver and installing it again. When the installation is complete, click the START button on the lower left corner of your screen then on the right pane, click 'Printers and Faxes'.
Under the printer tasks, click 'Add a printer' then click Next on the Add Printer Wizard dialog box. Select 'Local printer attached to this computer' and uncheck 'Automatically detect and install my Plug and Play printer' then click Next. Click 'Use the following port' and select LPT1: (Recommended printer port) then click Next.
Select HP under the Manufacturer list and under the Printer list, select hp deskjet 990c then click Next. Select 'Keep existing driver (recommended)'; click Next, name your printer, select Yes to set your printer as the default printer then click Next. Select Yes to print a test page, click Next then Finish to complete the setup. Click OK when a dialog box appears.
Go back to the 'Printer and Faxes' folder and right-click on the name of your printer. Select Properties and click Ports/Connections then check 'USB...Virtual printer for.....hp deskjet 990c'. Click Apply then OK and you should now be able to use your HP Deskjet F4200 Series All-in-One printer.
HP DeskJet F4280 All In One Printer InkJet Logo
Where can I buy the disk to install HP Deskjet F4280? Have tried to do it online but want to buy the disk as that doesn't seem to work
HP has the disc available for order in some countries, depending on your OS. When I went to http://support.hp.com/us-en/drivers/selfservice/HP-Deskjet-F4200-All-in-One-Printer-series/3390945/model/3390948 and chose Windows 7 as the operating system and clicked Update, I found the link for ordering physical media at the bottom of the list of software and drivers. The order page is http://support.hp.com/us-en/mediaorder/HP-Deskjet-F4200-All-in-One-Printer-series/3390945/model/3390948/softwareitem/CB744-10007/step1 . (For me, this page worked in IE.)
Fill out the form and agree to the shipping and handling fees. I hope this helps. This link didn't appear for Windows 8.1 or Windows 10. I hope this helps.
Dec 13, 2015 | HP Office Equipment & Supplies
How do I load the ink cartidges to a F4200 H P printer
This tutorial from HP support shows DeskJet F4210 which should have the same procedure:
HP F4200 Series Replace Ink Cartridges
Jan 16, 2010 | Office Equipment & Supplies
3,859 people viewed this tip
mukhtar21 shaikh
mukhtar21 shaikh
