Tip & How-To about Computers & Internet
Desktop Short Cut Missing
Hello,Some times your Desktop shortcuts or Start Menu Disappeared.It is happening due to Error Occurred in Explorer.exe. You can Clear this Error without Formatting.Just Do Following..
  1. Copy "explorer.exe" from other clean computer (from C:WINDOWS)
  2. And Paste it In your computer go to C:WINDOWS
  3. Show hidden files from (Tools - Folder Options - View - Show hidden files and folders)
  4. Delete existing 'explorer.exe' and any other files start with explorer...
  5. Put the new file (explorer.exe)
  6. Log off / Restart
  7. Log on
OR Just try this Solution.Close all your Opened Windows/Programs(OR Restart PC). Just Run this Dos File.It will Restore your Desktop Surely.. I/we need your valuable Feedback...Keep Using FixYa
Check this Link............. "Unable to Open Theme Corrupted" in Nokia 6300 Click here
Computers & Internet Logo
internet explorer is not visible on desktop
Find a Missing Internet Explorer Icon in Windows XP
  • Step 1 Click the "Start" button. Click on "All Programs." Look for an icon called "Internet Explorer." Right-click the icon. Select "Copy" from the menu.
  • Step 2 Find a blank space on your Desktop and right-click on it. Select "Paste" from the menu. You should see a new icon called "Internet Explorer." Double-click it to make sure that it works.
  • Step 3 Open "My Computer" on your Desktop if you were unable to find the Internet Explorer icon in "All Programs." Double-click the "C:" drive. Double-click "Program Files." Open the folder named "Internet Explorer."
  • Step 4 Select the "iexplore.exe" icon and right-click on it. Choose "Create Shortcut" from the menu. Scroll down to the bottom of the window. Right-click the "Shortcut to iexplore.exe" icon. Click "Copy."
  • Step 5 Paste the icon to your Desktop. Open it to make sure it works.
  • Step 6 Click the "Start" button and select "Search" from the menu if you are unable to find the "iexplore.exe" icon in your Program Files folder. Search for "iexplore.exe." Locate the file. Right-click it to create a shortcut. Paste the shortcut to your Desktop.
  • Find a Missing Internet Explorer Icon in Windows Vista
  • Step 1 Click the "Start" button. Select "Run." In the "Run command" box, type "regedit.exe."
  • Step 2 Look for the key ""HKEY_CURRENT_USER." Click twice to open it.
  • Step 3 Navigate to "Software" and open it. Open "Microsoft," "Windows," "CurrentVersion," "Explorer," "HideDesktopIcons" and "NewStartPanel."
  • Step 4 Open the "{871C5380-42A0-1069-A2EA-08002B30309D}" key on the right side of the screen. Change the value to "0" to show the icon on your Desktop.
  • Jul 14, 2010 | Microsoft Internet Explorer 8
    I have had an account with AOL for years without a problem but when I click on my desktop icon it will not open. What has happened and how do I fix it?
    AOL shortcut was created on your desktop. Due to some technical issues, the configuration might have changed. Do not worry. I will help you to re-create another shortcut of AOL on your desktop for one time click and work,
    When the AOL software is installed, a shortcut is created on your Windows desktop, allowing you to quickly and easily sign on. If your desktop icon is missing, or if it points to a version of the software other than the one you would like, follow these instructions.
    To create an AOL icon on your desktop
    1. On the Start menu, select Programs, then click Windows Explorer (on Windows XP, select All Programs, Accessories, then click Windows Explorer).
    2. Browse to the folder that has your AOL software (e.g., C:\Program Files A File is an electronic document which can be text, pictures, sounds, videos or whole programs. Reminder: Never download files from someone you don't know. Files may contain dangerous Trojan Horse programs that may capture your AOL password, severely damage your computer, or contain objectionable graphics. To report a violation in an attached file, please forward the e-mail to screen name TOSReports.\America Online 9.0).
    3. Click the file waol.exe once to select it.
    4. On the File menu, click Create Shortcut.
    5. Drag the new shortcut icon (Shortcut to waol.exe) to your Windows desktop.
    Notes
    You can rename your shortcut to something more meaningful to you. Simply press F2 on your keyboard while the shortcut is selected, type a new name, then press ENTER.
    To delete a shortcut, drag it to the Recycle Bin. Your AOL software will still be on your computer.
    That should work. For further reference, click the link;
    http://canada.aol.com/help_files/canada_help9/Canada_Help_9.htm#Technical_Support/Installing_the_AOL_Software/Adding_an_AOL_shortcut_to_my_desktop.htm
    Regards,
    Anirban Mazumdar
    Jun 04, 2010 | E-Machines eMachines Desktop PC
    the claculator has disappeared. Cannot find it. Can I restore it?
    go to start run and type in calc.exe to just get it up
    alternativly right click on your desktop and go to create a new shortcut...in the location field type calc.exe and this will put it on your desktop - from there you can drag it into your start menu.
    Brentwood IT
    Sep 25, 2009 | Logitech 967437-0403 Keyboard
    How do I get IE 8 icon on my desktop
    Go to the installation directory. It is probably C:\Program Files\Internet Explorer.
    Look for a file there called iexplore.exe.
    Right click on that file.Then use the "Create ShortCut" menu pick! That creates the shortcut. Last step: just drag the shortcut to your desktop. Done!
    Jul 04, 2009 | Microsoft Internet Explorer 8
    363 people viewed this tip
    David Payne
    David Payne
