Tip & How-To about Dell Axim X50 Pocket PC
How to Acess the update screen on your Dell Axim PDA
Hold down your power button and your wireless button both at the same time.
then press your reset button on the back of your Dell axim and release your reset button quickly, but keep on holding the power button and the wireless button until a white screen pops up saying something about updating.
If a screen comes up about resetting to factory default, get out of that screen.
Dell Axim X50 Pocket PC Logo
I forgot my password
Hi, Once you forget the Password, your only option is to perform a Hard Reset on the device and reset back to Factory defaults. You data will be lost, as this is in place to protect you in case the device has been lost or stolen. If you have backups, or sync the device with Outlook, you can run a restore or re-sync the device to populate the data back into your device. To do a hard reset:
  1. Press the Power button to turn the Axim unit On.
  2. Press and hold the Power button down while using the Axim stylus to press the Reset button at the same time.
  3. Release the Power button and the Reset button. The To clear all data in the memory screen appears.
  4. Press the Contacts button on the Axim to delete all of the data in the memory of the Axim handheld.
  5. Press the Mail button on the Axim to cancel the operation without losing data.
  6. THANK YOU
Dec 23, 2010 | Dell Axim X51v Pocket PC
Dell Axim x51 v
Hard Reset
NOTICE: When you do a hard reset, you lose all the data stored in your device
Flash memory, and any programs that you installed on your device.
Do a hard reset if:
  • You want to restore the device to factory default settings.
  • You forget your password and need to reset it.
  • Your device is experiencing severe operational problems and you have already attempted a soft reset.
NOTICE: It is strongly recommended that you back up your data before you do a hard reset.
To do a hard reset:
Sep 13, 2009 | Dell Axim X51v Pocket PC
I have a dell axim x51v I made a password change and entere it into a digital rape recorder the recorder died on me and I do not remember the password as it happened 2 day after de change my cuestion is there a way to crack the password and get the axim operable again?
Hard Reset:
Do a hard reset if:
To do a hard reset:
Sep 03, 2009 | Dell Axim X51v Pocket PC
set password on my dell axim X51v pocket pc and forgot it
Hard Reset -
Do a hard reset if:
To do a hard reset:
Mar 16, 2009 | Dell Axim X51v Pocket PC
forgot password
There is only one way that I know of from DELL and is performing a "Hard Reset". You will loose all your loaded programs and data loaded in Flash memory in the process:
1. With the Axim turned ON, press the Reset button until it clicks and hold it, then
2. Press the Power button, then
3. Release the Reset button, then
4. Release the Power button.
When you see the prompt on the screen, press the "Contacts" button to reset the Axim to factory defaults. You can also choose to press the "Mail" button if you need to cancel the reset process. :)
Jan 18, 2008 | Dell Axim X51v Pocket PC
871 people viewed this tip
mukhtar21 shaikh
mukhtar21 shaikh
