Tip & How-To about Hoover F5881-900 Vacuum
How To Diagnosis & Fix Hoover SteamVac's When Brushes Stop Spinning
When the brushes stop spinning on a Hoover SteamVac, it can be caused by several things. In order to diagnosis why your brushes aren't spinning, please view the diagnosis solution I have done on Fixya:
http://www.fixya.com/support/t4286338-hooverspin_scrub_brushes_always_stop
If you have diagnosed your machine, and found that the internal receptacle is not spinning, then you'll now need to replace your turbine. This tip will explain in detail how you'll need to complete this repair.
Here's what you'll need to complete this repair:
- Hoover SteamVac Replacement Turbine Brush Gear (several different parts for different models)
- Phillips Head Screwdriver
- Flat Head Screwdriver
Step 1. Remove both the clean solution, and the dirty solution tanks from the machine, and press the handle release pedal so that the handle is laying down flat:
Step 2. With a flat head screwdriver, pry off the rotating brush speed indicator knob:
Step 3. Unscrew the silver screw that's at the very top of the see-thru suction port where the dirty solution tank rests.
Step 4. Turn the SteamVac upside down so that the brushes are facing upwards. There are four clips that hold these brushes in place. You'll need to remove the brushes from the machine by squeezing the four tabs while pulling upwards at the same time. The picture actually only shows the two tabs on the right hand side being squeezed, but the tabs on the left hand side are in the exact same location:
Step 5. Once you've removed the brush block from the machine, there are 4 screws on the bottom that need to be removed. Keep the two silver screws on the very corner in place, you won't need to remove these. Remove the four screws that I've highlighted in red:
Step 6. Turn the machine back over right side up, so that the brushes are on the bottom. There are two clips that hold the top housing in place. Insert your flat head screwdriver in between the top and lower housing in the rear of the machine close to the rear wheels, and pry upwards to un-clip these clips on both the left and right sides, then remove the top motor housing from the machine.
Step 7. You'll now have complete access to the turbine. Remove the two silver screws in the front of the unit that hold the turbine in place, as well as remove the front hose from the turbine:
Step 8. Once you have removed the two screws you'll be able to lift the turbine up. There's a second hose in the rear of the turbine that you'll also need to remove before you can remove the turbine completely. After you've removed the hose, take the turbine out of the machine. You'll notice to the immediate left of the turbine other hoses that connect to a black circular part. This is actually the pump that sprays the water on the floor. If you ever have the problem where the clean water solution will not spray, it's a good possibility that this part needs to be replaced.
Simply install the new turbine, reattached the hoses and two front screws. When you're putting the top motor housing back on the unit, make sure that the brush speed selector knob that's on the right side of the turbine fits through the **** in the top motor housing. Also before you tighten the two screws that that hold the top housing in in front of the brushes, there's two clips. You'll need to snap the top motor housing behind these two clips. Simply push front of the motor housing until you hear it snap into place.
Chris J.
GoVacuum
Hoover F5881-900 Vacuum Logo
How to change the belt?
There is no belt on a Hoover SteamVac. The brushes are rotated by an air driven turbine. If the brushes aren't spinning, you most likely need to replace the turbine assembly.
Jul 05, 2011 | Hoover SteamVac F5914-900 SpinScrub...
I'm having trouble getting the brush speed knob pried off. I don't want to break it ... any suggestions?
Apr 10, 2010 | Hoover V1 SteamVac SpinScrub Vacuum
Brushes Stopped Working Again, What causes this to happen?
There are several things that can cause the brushes to stop spinning on a Hoover SteamVac. Usually when we see this problem come in, the brushes are usually just stuck to do carpet fibers, or pet hairs that get stuck inside of the brush block. A very easy way to clean these brushes is to take them out of the SteamVac (see the link below that is a full diagnosis of brushes not spinning on a Hoover SteamVac), and use a garden hose that has a spray nozzle on the end, and just spray each and every brush. If you start at the top of each brush, and spray water around the entire brush, each brush should spin pretty quickly from just the power of the water hose.
A lot of the times it's just stuff that got caught inside the brush block that stops them from spinning, I would say 7 out of 10 times this will fix the problem.
It also could be that the brush block is broken, or even the turbine inside of the SteamVac that drivers the brushes could be broken as well.
Here's a link to a Fixya repair solution that I did which will help you diagnosis what is exactly causing the brushes to not spin. If you examine the pole on the block, as well as the square shaped female receptacle, and that receptacle is spinning, then your brushes are just clogged up with debris.
If you need to purchase a new brush block, and you have the model that you listed this repair under, Hoover F7220900, here's a direct link to the brush block on our site:
Hoover SteamVac Brush Block, Part # 48437029.
Here's the diagnosis of the brushes:
First, what you'll need to do is take the brush block out of the machine. To do this there are 4 clips on the brush block. You will need to turn the machine upside down, and pull down on the brush block to where it won't pull out any farther. There are 4 clips, 2 on top, and 2 on the rear of the brushes. (See picture I have circled one of the clips in red) Simply press these clips at the same time, and pull the brush block out of the machine. I'd say that 70% of the time that I see this problem, the main issue is that the brushes just need to be cleaned. If you have pets in the home, a lot of the time the pet hair will just be lodged inside the brushes, will prevent them from spinning. Use a pressurized water hose with spray nozzle is ideal) and spray each brush with water to dislodge any pet hair. You should be able to get these brushes spinning when you spray them. Spray each brush until the brushes are spinning pretty fast. Re-insert the brushes into the machine, and test to see if the cleaning has fixed your problem. If the cleaning still fails to fix the problem, take the brushes back out of the machine.
One you have the brushes out of the machine, the first thing you should look at the brush stem that goes into the turbine inside the machine. This is the green pole pictured in middle of the brush block. Examine this pole to determine if the top of it has broken off. It should exactly how the picture shows it. Make sure that the plastic has not broken.
If the pole has broken, you will simply need to replace the brush block. If the pole is not damaged, the next thing to try is to turn the machine on while you have the brushes out. Look inside the machine, where the pole goes into the turbine (also important, make sure the switch for the brushes is turned to "Rotating Brush Speed Hi), this female receptacle should spin when the machine is turned on. It is important the try this when the foot pedal is released, and the handle down, and not in the upright position, as there is an internal switch that shuts the brushes off when the machine is in the upright position.
If you notice that the female receptacle where the brush pole is inserted is spinning, then your turbine is fine. If this part is not spinning, then most likely you will need to replace your turbine.
I hope this helps you with your problem. If not, please feel free to request a repair clarification and I'd be happy to walk you through the diagnosing. I also can provide you with a blown up parts schematic to your machine, please just get the model number off the back of the machine and provide, and provide me with the full model number. I would be happy to provide any technical support you need, just request a clarification on the repair.
Chris Jones
Apr 07, 2010 | Hoover F7220900 SteamVac V2 Upright Vacuum
1,854 people viewed this tip
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
