Tip & How-To about Refrigerators
No Water Coming Out of The Water Dispensor on G E Refrigerator ?
If you are not getting water thru the door dispenser , first thing to check is if you are getting water to the water valve behind the refrigerator . This is the part in the back of the refrig , that the wall water line connects to .
If your ice maker is making normal size cubes , then you ARE getting water TO the water valve .
However , there are 2 coils on the water valve ( G E ) of which 1 is for the ice maker , and , the other , is for the water dispenser .
1 ) Remove the kick plate from the bottom front of the refrig . On some models , the kick plate " snaps " on , and other models , it is held on by a small screw on each side on the top portion of the kick plate .
Once the kick plate is removed , follow the plastic water line from the bottom of the freezer door , about 6 " , to a small coupling . This coupling , has a " ring " on both ends , one of which has to be pushed in as you pull the tubing from the coupler . Once this is accomplished , put a towel under the end of both ends of the tubing , to keep the floor dry .
2 ) Activate the water dispenser arm . If water comes out in a good stream , from the tubing which goes under the refrig , the water line inside the freezer door is frozen . You can either turn the freezer temp warmer for several days for the line to un-thaw or use compressed air ( I have heard using computer cleaner air bottles with the small tube works ) to the water line going up form the bottom of the freezer door to blow out the frozen ice .
Once the ice thaws , G E has a dispenser heater , part # WR49X10173 which comes with installation instructions , to keep this from happening again . If NO water comes out of either hose , then either the water tank inside the bottom of the refrig is frozen ( which would require several days of warmer temperature settings ) OR the refrig could have a bad coil on the water valve , which would require replacing the complete water valve .
I have only come across maybe 1 tank which was frozen , and the rest have been either the line in the door was frozen OR the water valve needed replaced .
Please note....if using compressed air in the door water line , DO NOT USE EXTREME HIGH PRESSURE , as this could burst the line in the door , causing the complete door to have to be replaced . Just the water line inside the door , is not replaceable .
Refrigerators Logo
Water dispenser not working GE model GSH25JSX13
Do you hear a slight buzzing when you try to get water?? If yes, you may have a frozen water line inside the freezer door. GE had some problems with those models. They offer a heater kit that has to be installed in the dispenser area of the freezer door. Once installed, in about a day the water line should be defrosted enough to dispense water again. If you don't hear that buzzing sound when trying to get water, you could have a bad inlet valve which is at the lower back of the refrigerator where your house water line hook to the refrigerator.
Mar 04, 2015 | GE Refrigerators
ice and water thru the door does not work
Check the water supply valve behind the fridge that It's on and you are getting water. Sounds like you're not getting water at all.
Jan 12, 2014 | Refrigerators
How does the easy fill water dispenser work?
there is a micro switch behind the door lever wich activates a water valve solenoid that allows water to go thru.
Oct 23, 2013 | Amana 21.9 cu. ft. Bottom Freezer...
the water isnt getting thru to the icemaker, i have used a hairdryer on the water valve and still nothing , i even changed out the water valve but alas no water is being pumped thru to the icemaker, what else could the problem be, the fridge is about 14 years old,and works fine except for this problem, please help me
Does water dispense through the dispenser ok in the door dispenser??
If yes wate r dispenses through the door ok the problem is going to be with the icemaker itself and its not sending power to the water valve when its supposed to fill so it could make the ice
If water doesnt dispense through the door check that water pressure into valve is sufficent..even if water does dispense what seems to be ok check first that thier is good water pressure into the valve before replacing icemaker
GENE
Sep 11, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
299 people viewed this tip
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
