Tip & How-To about Computers & Internet
Reduce the file size of a PDF file
Sometimes when we scan a document and the output file is PDF the file size is too big which is very difficult to send as an email attachment. This also happens when you convert word documents into PDF format.
This guide assumes that Adobe Acrobat Professional or Standard is already installed on your computer for PDF conversion.
On your current PDF File click on File then select Print
On the Print window select Adobe PDF as the Printer Name then click on the Properties Tab
On the PDF Document Properties Window under Default Settings drop down, select Smallest File Size.
Click on OK on all open windows. This will start the conversion process. When it's finished this will prompt you to save the file. It is advisable to save the file in a different file name rather than replacing the original copy.
After the conversion you may compare the file size of the original file and the reduced PDF file. The reduced file can now be sent on email attachments easily.
Computers & Internet Logo
how to scan documents to an email address
you should first right click on yoru destop and find "NEW" click on "make new folder", then type a name for the folder (anything you want). Now go to your scanner software and find the preferences and tell it to save scanned documents to your NEW folder. another option is to simply scan a document and when its done, click "file, save as" and save it to your new folder. When you are done scanning, open your email program and type in the email address to where you want to send the documents. when you are done typing the "subject" and a short note to whomever the mail is too, go to "insert" or "attachments" (varies depending on you email program). find the folder with your documents in it and hold down the "Cntrl"key and then click each file you wish to include. then click "ok" and all the files should now be attached to your email. BE AWARE, there may be a limit to how much data you can include in your email. If your email provider rejects your message due to file size being too large, simply send the files one at a time in multiple emails. There are also options out there (too numerous to list) that will allown you to send large files that are too big for your email program. I hope I haven't confused you. Good luck
Mar 23, 2011 | Gestetner DSc232 Copier
I scanned a document, but when I go to attach the file, it stays in attaching files forever??
Greg, Do you mean that when you want to send it by email it keeps attaching the file forever? If yes then check the size of the scanned document. What happens is that the moment you attach a document to an email Windows start sending it to the email server and that takes time as uploading is slower than downloading. And if the file a large one as scanned documents can be, then it will take that much longer. Try a smaller document first. Size wise small document. If that works fine then you can try larger documents. yes it may be time consuming but there is no price for mental satisfaction. To reduce the size of the scanned document, reduce the pixels in settings of the scanner. or reduce the page size. You will find the document reduced many times over.
Nov 19, 2009 | Gateway Audio Players & Recorders
Scanning a document and attach it to my email
Just scan the file, use save as, choose file type,name and then location to save file, to (folder) you created in My Documents ,ie; Temp (folder).Later when sending e-mail attach file to message by clicking attachments browses to My Documents, Temp click file then attach file.It is now attached to your message.If you can save as PDF file do it ,it will be easier for person receiving.Good Luck.
Sep 09, 2009 | HP DeskJet F380 All-In-One Printer
Scanning docs & size of pdf files on Mac w/HP l7680 All-in-one
The scanner produces a "picture" of the document, much as if you laid it flat on a table and took a picture of it with your digital camera. If you did this, your .jpg from the camera would be several hundred K at a minimum - comparable to the file size off the scanner. That's why the file is so big, it contains a picture and not text data - even though it's still a .jpg file.
If you reduce the scan resolution you will save space, but at the expense of legibility of the document image. To get it down to the smallest possible size, you will need to run the scanned image through OCR ( Optical Character Recognition ) into a Word document for example, and then print it out to a .pdf file. If you have a clean source document with few graphics this isn't as difficult as it may seem. Microsoft Office has an excellent OCR process known as Document Imaging. You need to carefully proof read the result but with a clean input Document Imaging is amazingly accurate in Office 2007.
In short, there is no easy solution to your problem.
Dec 30, 2008 | HP Officejet Pro L7680 All-In-One Printer
When I scan one page, in the document info it show the size of the file to b : 13.66 MB or 29MB
This is not an issue with your printer, this is an issue with your email provider. It's telling you that the file size is too big to be sent by your email provider.
You can check with your email provider to see if they can increase the size that attachments are allowed to be, but that is no guarantee that the person you are sending to can receive files when they are that big.
The best solution is to either scan at a lower resolution, or use a more compressed file format. If you're not doing so already, scan to a .jpg file format. If that still does not work, try reducing the scan resolution... start at 600dpi, then maybe go down 100dpi at a time until it is small enough to send.
May 14, 2008 | HP LaserJet 2840 Printer
289 people viewed this tip
David Payne
David Payne
