Tip & How-To about Computers & Internet
How to Install 2 or more Operating Systems on your Computer
You will need to make sure your hard drive is large enough to accommodate the space requirements of both operating systems, plus enough room to install software and store files for each perating system. Personally, I do not recommend attempting this on drives of less than 50GB with Windows operating systems XP and later. You will first need to optimize the existing installation to reduce and condense your total disk space. To do this you can run the following utilities on your existing installation: create a restore point then, run a registry cleaner (Ccleaner is reliable and free), registry defrag, system cleaner (Trial versions of Yacimsoft Optimizers or Glary Utilities are fully functional free downloads which will give you all the tools needed to achieve these functions), uninstall any program files you do not use . . . then perform a complete disk defrag once all junk files, temp files, old document files etc have been deleted and removed from the recycle bin . . . then reboot the computer.
To perform the disk partition inside Windows XP and later, make sure you are logged on to a user account with full administrator privileges., then click on start and RIGHT click on My Computer (WinXP) or Computer (Vista and 7) on the start menu and select “Manage” this will invoke the “Computer Management Console. In the far left column find and select “Disk Management” This will open the Windows utility to create disk partitions.Your primary Hard Drive will be labeled “Disc 0” and display information about the size of your drive. Newer laptops and desktops may already show multiple partitions setup by the manufacturer which are used to restore your original factory settings – DO NOT DELETE OR TAMPER WITH THESE OR YOU WILL LOSE YOUR ABILITY TO RECOVER YOUR ORIGINAL OPERATING SYSTEM IN THE EVENT YOUR OPERATING SYSTEM BECOMES UNUSABLE.
Find the rectangular section of the Hard Drive Graphic which bears the word BOOT Right click, Select “SHRINK VOLUME”. A new window will appear with minimum number of megabytes the drive can be. You will NOT want to use the minimum number. If you do, you will be creating a partition only big enough to accommodate your current data. There will be little or no room to add additional programs or save files. What you will instead need to do is look at the total capacity, then calculate how much additional space you want to allocate to your original Windows installation with enough remaining space to install the secondary operating system.
Lets pretend the original OS is any flavor of VISTA and you are planning to install Windows XP SP3 on your new partition . Your HDD is 60 GB (this will be shown in MB units which will be a 5 digit number for drives less than 100 GB and a 6 digit number for drives over 100 GB total capacity).
Note: HDD capacity calculations are not exact. Do not be surprised if your 60GB drive actually only shows a “Total Size Before Shrink” of 58777 megabytes or some other number less than 60000 as you might expect. This is an industry norm. The true capacity is rounded up to the nearest GB even though the actual capacity may be slightly less.
In this scenario the Disk Management utility informs you the minimum size you can shrink your Vista volume to is 22497 megabytes. You want more room for downloads and stuff you add later. The total capacity you need for your XP installation and other files you decide will be 20 GB. This leaves approximately 20GB of space you can apply to the Vista partition. Therefore you will enter a number something like 44000 in the Shrink window field labeled: Enter the amount of space to shrink in MB. Now click the “Shrink” button. The operation will take several minutes to complete. Once the Shrink has completed successfully, reboot the system to make sure your original OS is operational and the computer boots without any issue. Then return toDisk Management You shoulod now see your Vista volume and a second area of Unallocated Space.
Right click in the unallocated space, select “New Simple Volume” This will begin the Simple Volume Wizard. Click Next. Use the maximum size indicated & click “Next”
In the next menu select “DO NOT ASSIGN A DRIVE LETTER OR PATH. Format the new partition to NTFS.Click “Finish”
Return to the Disk Management utility & you will see the new partition. When the format is complete, right click on the new partition and select “change drive letter” use the default drive letter suggested.
Insert your XP Installation CD into your DVD/CD and run SETUP within Vista and select the option to install a copy of XP on this machine.Select the empty new partition you created for XP and follow the installation instructions.
Vista Boot Loader will detect the XP installation and prompt at startup which OS you wish to boot. You now have 2 separate options for which operating you want to run on your computer.
DO NOT ATTEMPT TO RUN PROGRAMS INSTALLED ON ONE OS IN THE 2ND OS. YOU WILL NEED TO INSTALL ANY PROGRAMS YOU HAD INSTALLED ON YOUR ORIGINAL OPERATING SYSTEM SEPARATE INSTALLATION IN THE NEW OS. ALWAYS SAVE PROPRIETARY FILES AND BACKUPS TO THE CORRECT PARTITION CONTAINING THE OPERATING SYSTEM WHERE CREATED.
EXCEPTIONS ARE: MOST STANDARD MEDIA AND DOCUMENT FILE FORMATS – mp3, .doc, .pdf, .jpeg etc. These files are universal and can be accessed from either OS by pointing their opening application to their location on any logical drive.
My Next How-To will be PART 2, Installing multiple Operating Systems on a Clean Unformatted Drive.
Please send any feedback or questions to GeekMaker@hotmail.com
Colt Baldwin – FixYa.com Computer Technology Support Expert.
Computers & Internet Logo
how to reformat srdospo backup drive
I would reinstall your back-up program and try again. If that doesn't work I would delete all the back-ups and try again. More information could be helpful too(what back-up program, Operation system, etc...)
Nov 28, 2013 | Computers & Internet
I have had an Evesham PC desktop computer since 2002. I use Windows XP. Is there any possibility of downloading Windows 8? Annie
You might need to upgrade a few hardware items first also you might upgrade to vista then windows 8
Creating a new partition on your hard drive gives your future version of Windows 8 a place to live on your drive.
Knowing exactly how much space the OS requires helps you determine how large to make your partition.
Size requirements don't tell the entire story on their own, though.
Other factors like drive type and additional storage help ensure you get the best Windows 8 experience where your hard drive is concerned.
Size Requirements
Both Windows 7 and Windows 8 have the same system requirement regarding hard drive space, so if your hard drive can handle Windows 7, Windows 8 shouldn't be a problem.
For 32-bit versions of the operating system, you'll need at least 16 GB of available disk space. The 64-bit version requires 20 GB.
Your partition will have to be at least one of these sizes, depending on your OS version.
The PC Advisor website warns that these are literally the bare minimum requirements, and using these figures leaves you hardly any space to save files and install apps or programs.
Size Recommendations
You'll get more out of Windows 8 if the operating system has enough free space for you to install your favorite programs and apps.
PC World calls this extra space "breathing room," suggesting you give your Windows 8 partition at least 30 to 40 GB.
If you're dual-booting with another operating system or you're accustomed to keeping excess data on a separate partition, 30 to 40 gigabytes should be fine.
If you'd rather have all your songs, videos and PC games on the same partition as the operating system, consider giving it substantially more space.
Solid State Drive
Windows 8 works on traditional hard drives with spinning disks, but it's optimized to run on a solid state drive.
If you've got an SSD, consider putting your Windows 8 partition on that drive.
While any operating system benefits from the speed increase an SSD brings, ARS Technica specifically recommends this drive type for Windows 8, saying the operating system's "tablet-esque feel and search-heavy usage model will be much better served by solid-state storage."
Other Requirements
Hard drive space is a crucial system requirement, but others are just as important.
Ensuring your computer meets the other requirements before partitioning your drive for Windows 8 saves trouble in case your computer can't handle the OS.
You'll need at least a 1 GHz processor that support PAE, SSE2 and NX.
Your computer has to have at least 1 GB of RAM for 32-bit Windows 8, or 2 GB for 64-bit.
Your graphics card must be at least a DirectX 9-capable card with a WDDM driver. Also, while you're formatting your drive, format the Windows 8 partition in the NTFS format.
Storage Spaces
Storage Spaces is a useful Windows 8 feature when you're working with multiple drives and partitions.
The tool enables you to group drives into one larger storage space so you don't have to constantly switch partitions and explore different drives.
For example, if you create a storage space between two 32 GB flash drives, you'd be able to access it as if it were one larger 64 GB drive.
http://windows.microsoft.com/en-us/windows-8/system-requirements
Microsoft windows 8 system requirements
http://www.pcadvisor.co.uk/features/windows/3358892/windows-8-system-requirements/
PC World windows 8 system requirements
http://www.pcworld.com/article/2012847/how-to-master-storage-spaces-in-windows-8.html
PC World how to master storage space windows 8
http://windows.microsoft.com/en-US/windows/download-shop
Sep 11, 2013 | Evesham Computers & Internet
Hard disc space required
You need to free up some room on your computer. The game looks like it is requiring 39-40 gb of free disk space, and your pc only has 29gb of room. Try lookin at big hunks of media that is saved on your desktop. Normally video files are the largest. If you don't need them delete them. This will free up some space to install the software.
Apr 12, 2012 | Square Enix Dungeon Siege III
I want to back up my hard drive onto my Elements external drive. The computer says that the Elements 3607 does not have enough space. What do I do?
Well first of all check how many free space you have on your ext. drive. If you DO have enough to back-up your files,then i would suggest you right clicking on your ext. drive,choose properties and format it,but beware,formating will delete ALL your data on external drive.
If you think i was usefull,click on Thumbs up button,cheers!
Mar 07, 2011 | Western Digital Elements powered by WD 320...
ms office won't open gives there is not enough memory disk space full message but memory no where near full
Depending on how much disk space you have left onyour hard drive, Microsoft Home and Student requires at least 1.5GB offree space. I've posted the minimum system requirements below, you willneed these to run Office Home and Student 2007.
Minimum Requirements: (View on Microsoft Website)
  • 500mhz Processor
  • 256 Memory (RAM)
  • 1.5GB of Free Space (Hard Drive)
  • CD/DVD Drive
  • Display: 1024x768 or higher resolution monitor
  • Operating System: Microsoft Windows XP with Service Pack (SP) 2, Windows Server 2003 with SP1, or later operating system
Mar 15, 2009 | Microsoft Office Professional 2007 Full...
211 people viewed this tip
David Payne
David Payne
