Tip & How-To about Cell Phones
IPhone factory (hard) reset. (Final)
If you are facing application and startup errors with your iPhone, and you may have tried to perform a 'soft' reset which failed to work, the only solution would be to perform a hard reset.
Some of these system errors may include, application launch failure, failure to be detected by iTunes, startup failure (iPhone may freeze on startup), the solution may perform a full factory reset.
The only bad side is that, you will lose all your data, but, you will have a functioning iPhone. If you had earlier backed up some data, you can perform a system restore after performing the factory reset.
To perform a full factory reset, follow the procedures below:
1.Press the home button (the big circle below the screen) and the sleep wake button (the button on top of the iPhone) simultaneously. Ignore the “Slide to power off” message.
2.Hold both buttons for about 10 to 15 seconds.
3.The iPhone will shut down.
4.Wait for about 10 to 15 seconds then turn the iPhone back on by pressing the sleep/wake button.
5.You should now see the Apple logo, your iPhone is restarting and thus booting up.
6.The hard reset will have completed successfully.
System Recovery:
After the hard reset has been successfully complete, it will not be functioning so you will have to perform a System Recovery.
Please note that System Recovery is different from data restore.
Follow these steps to perform system recovery:
1. Plug in the iPhone into your computer.
2. Run and open iTunes.
3. iTunes will prompt a message that says “iTunes has detected an iPhone in recovery mode.” Click OK.
4. You will be taken to the iPhone pane. Then, click on “Restore”.
5. Wait for the full restoration process to complete, and the iPhone will have been restored back to the state in which you had just bought it.
After the process is complete, you can restore your data from the backup you made, if you made any back ups before the problem occurred.
Thank you for using Fixya,
Kenneth.
Cell Phones Logo
my iphone screen is completly black i've tried holding the home and the off button down at the same time and its still not working wtf . i really need help !!
Hi, this happened to me once and I researched a fix by looking for 'iPhone black screen of death'
Here's one of the current articles that comes up under that search:
1) If an application (such as Safari) is frozen, just press and hold the iPhone's home button for about 5 seconds, or until the home screen shows up. (This didn't work for my iPhone so we had to perform a soft reset).
2) To perform a soft reset, press and hold the iPhone's Sleep/Wake button and the Home button for several seconds, or until you see the apple logo on the screen. (This action did reset my iPhone and I was very happy at this point). The guys that helped me said that continually performing soft resets can cause problems however.
3) Hard resets are not recommended, but are required when a soft reset won't do the trick. The Apple Geniuses wouldn't tell me the key combo to perform a hard reset because it restores the iPhone to a state that's unusable. Users risk losing data and you must synch your iPhone with iTunes to make it function after a hard reset.
Also, if you are not turning off apps after use they could be overloading things and might cause it to happen again. to turn off apps do a double tap on the 'Home' button, and all your open apps will be listed along the bottom of the screen. press on one icon and hold until the icons start to wobble and have the X in the top right corner click on these to turn them off. Its also good practice to do this several times a day if you use a lot of apps because having ghem open eats up your battery power.
Apr 17, 2013 | Apple iPhone Smartphone
hard reset of my hp ipaq 510 i forgot my password
s.gifs.gifHP iPAQ 500 Voice Messenger Series - Resetting the Device
Sometimes you need to reset your iPAQ if, for example, it is not responding to your pressing a button or your tapping the screen.There are two types of resets.
  • Soft Reset - A soft reset stops all running applications, but does not erase any programs or saved data.
  • Factory or Hard Reset - A factory or hard reset clears all user-installed settings, programs, and data, and restores your iPAQ to factory settings.
Performing a Soft ResetPerform a normal or soft reset to stop all running applications, to restart the iPAQ after installing a new application, or if the iPAQ locks up.CAUTION:Make sure to close all running applications before performing a soft reset, since a soft reset erases all unsaved data in such applications.Perform a soft reset using one of these two options.
  • Turn off the iPAQ by holding down the End key.c01118005.jpg1 - End Key
  • Remove the battery of your iPAQ.
Performing a Factory or Hard ResetPerform a factory or hard reset when there is a need to clear all settings, programs, and data from the RAM.CAUTION:Performing a hard reset will return the iPAQ to its default settings and it loses all information (files and settings, among others) that is not recorded in the ROM. Back up all important information or data before performing a hard reset.Follow these steps to perform a hard reset and return your iPAQ to factory settings.
  1. Turn off your iPAQ by holding down the End key.
  2. Then hold down the center of the 4-Way Navigation key and turn on the iPAQ again while continuing to do so.c01118006.jpg1 - 4-Way Navigation Key2 - End Key
  3. A confirmation screen opens asking whether you want to perform a hard reset or not. SelectYes . The iPAQ will reboot with its original factory settings.
NOTE:The applications and data present on your iPAQ before performing the hard reset can be reinstalled by synchronizing your iPAQ with a computer using ActiveSync/WMDC (Windows Mobile Device Center).NOTE:If you don't want the iPAQ playing a tune after you turn it on, create a new text document and save the document as StartUp.wav. Replace this new document with the file on your device.
Jun 20, 2012 | HP iPAQ 510 Voice Messenger Smartphone
BlackBerry 8700c Hang-up
Try to take the battery first and leave it for 3 hours and put it back again,and try to check if the screen respond in tapping if still not working then do some reset procedure...
Soft Reset
A soft reset tells your handheld to stop what it's doing and start over again. All records and entries stored in your handheld are retained with a soft reset. After a soft reset, the Welcome screen appears, followed by the General Preferences screen.
Use the reset tip tool (see below), or the tip of an unfolded paper clip (or similar object without a sharp tip), to gently press the reset button inside the hole on the back panel of your palm handheld.
Reset Tip Tool: On most PalmOS handhelds, the stylus that comes with your handheld has a reset tip inside. To use it, unscrew the barrel from the stylus quill.
Double-Soft Reset
If your device doesn't seem to want to power up after a soft reset, and you've checked the other obvious solutions (fresh batteries, power button, contrast wheel, contrast button) you may want to try the 'Double-Soft Reset'. Simply perform a soft reset as directed above, but press the reset button twice in quick succession.
Warm Reset
A warm reset bypasses any system extensions (such as HackMaster hacks, OS patches, Alarm settings, etc) that are loaded on your handheld. Sometimes a damaged third-party application will try to respond to a reset but will fail and cause the handheld to 'hang'. Using a warm reset, you can start the handheld, then delete the damaged application before it has a chance to try to run again. After deleting the application, follow with a soft reset to start up the handheld normally.
To perform a warm reset:
  1. Press and hold the upper half of the scroll button on your handheld.
  2. Using the reset tip tool (or a similar object without a sharp tip), gently press the reset button inside the hole on the back panel of your handheld.
  3. When the Palm Computing Platform logo appears on the screen, release the scroll button.
If you're not sure which application is damaged, you can use a tool like ResetEmu in conjunction with a warm reset to help pinpoint the offending application.
Hard Reset
With a hard reset, all records and entries stored in your handheld are erased, except for the default or specimen databases predefined by the manufacturer (but see Extended Hard Reset below). Formats Preferences and other settings are restored to their factory default settings. You can restore any data previously synchronized with your computer during the next HotSync operation. If you're running OS 3.1 or earlier, and you're not using a third-party backup utility like BackupBuddy, you may need to reinstall your third-party applications.
Never perform a hard reset unless a soft or warm reset does not solve your problem.
To perform a hard reset:
  1. Hold down the power button on the front panel of the handheld.
  2. While holding down the power button, use the reset tip tool (or similar object without a sharp tip), to gently press the reset button inside the hole on the back panel of your handheld.
  3. Release the reset button.
  4. When the logo screen appears on the screen, release the power button.
  5. When the message appears on the handheld screen warning that you are about to erase all the data stored on your handheld, press the upper half of the scroll button on the front panel of the handheld to complete the hard reset and display the Digitizer screen.
Pressing any other button instead of the upper half of the scroll button will perform a soft reset.
Extended Hard Reset
An Extended Hard Reset will completely erase your handheld, and will also bypass the creation of some default databases.
This differs from a normal hard reset, which will automatically create the databases for the built-in applications, and will insert some specimen records into those databases: numbers for Accessories and Technical Support will be created in your Address database, a registration reminder will be created in your ToDo database, and several helpful memos will be created in your Memo database.
In addition, a normal hard reset will also create a Network database with some default Network profiles for your Network panel in Prefs, and a file of several default MIDI alarm sounds will be created.
If you have the Notepad application, a normal hard reset ensures a sample note will appear on your NotePad, and if you have the Mail application, an email message from 'Mail Help' will be automatically inserted in your handheld Inbox.
An Extended Hard Reset will ensure that all of these startup files are not created.
If you decide to perform an Extended Hard Reset and install one or more third-party applications that expect to see the built-in databases present, you may encounter an error. For this reason, it's suggested that after an Extended Hard Reset, you run each of the built-in applications (Datebook, Address, ToDo, Memo, and if installed, NotePad and Mail) at least once to ensure empty built-in databases are created.
After an Extended Hard Reset, you will not be able to select alternate alarm sounds for Datebook alarms, but the default alarm sound will still be heard for appointments with alarms set.
To perform an Extended Hard Reset:
  5. When the message appears on the handheld screen warning that you are about to erase all the data stored on your handheld, press and hold the upper half of the scroll button on the front panel of the handheld.
  6. While still holding down the scroll button, press, in any order, the Datebook button, the Address button, the ToDo button, and the Note/Memo button.
  7. Release the scroll button, to to complete the hard reset and display the Digitizer screen.
Pressing some but not all the buttons while holding the scroll key will result in a normal soft reset. Pressing no buttons while holding the scroll key will result in a normal hard reset.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Sep 04, 2008 | RIM BlackBerry 8700g Smartphone
565 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
