Tip & How-To about 3d Rose Londons Times Funny Society Cartoons - Early Cave Decorating - Light Switch
Dont throw old hard paint away
If you have got emultion paint that as gone hard try using a old blender and a bit of water' and mix until all the lumps have gone
if it thickens add more water.
3d Rose Londons Times Funny Society Cartoons - Early Cave Decorating - Light Switch Logo
WHY WON'T COLD SKIMMED MILK THICKEN WITH BAMIX BLENDER `/
Skim milk has little to no fat, therefore it will not thicken when whipping. If you want to whip it, I suggest you dissolve a packet of unflavored gelatin in 1/4 oz skim milk, microwave it for about 30 seconds until the gelatin is dissolved, and add 2-3/4 cups cold skim milk. Refrigerate for about 15 minutes or until the consistency of egg whites, then try whipping it. Good luck!
May 08, 2015 | Bamix Immersion Handheld Blender
where can you find the mixing ratio for the product being used?
you did not state what paint and what gun and what pressure - telepathy is overrated and works only in the movies...
if you use two pack mix - on the package is clearly stated how much part 'a" and how much part "b" should be used, you can then add up to 20% of thinners if allowed in particular paint.
you need to pay attention if mix is by weight or by volume, light paints are usually by volume,
paint should be rather light oil to water consistency in low pressure guns, if gun nozzle is below 0.8mm strainer must be used (190micron is ok) above that you can use your old pantyhose to strain paint after mixing.
hope this will help you at least a bit...
Oct 26, 2014 | 3M Mix Ratio Insert,pk100 - 3M
how to cook maja blanca
mmmm my favourite.
Ingredients
  • 1/2 cup water
  • 1/2 cup cornstarch
  • 1 cup coconut milk
  • 3/4 cup water
  • 1/2 cup white sugar
  • 1/4 cup fresh sweet corn kernels
  • 1/4 cup sweetened flaked coconut
Directions
  1. Butter an 8-inch baking dish or pie pan, and set aside. Mix 1/2 cup of water with the cornstarch in a bowl, and stir until smooth.
  2. Combine the coconut milk, 3/4 cup of water, and sugar in a saucepan over low heat, and stir until the sugar is dissolved. Bring the mixture to a boil, add the corn kernels, and then stir in the cornstarch mixture, stirring quickly to avoid lumps as it becomes very thick. Bring the mixture back to a boil, and simmer until fully thickened and smooth, stirring constantly, about 2 minutes. Pour the maja blanca into the prepared dish, and set aside to cool until firm, about 2 hours.
  3. Place the coconut flakes in a dry skillet over medium heat, and stir to toast. Watch them carefully so they don't burn. Remove the toasted coconut flakes to a bowl, let cool, and sprinkle over the pudding before serving.
Aug 04, 2011 | Rosetta Stone 3 Filipino (Tagalog) Level 1...
what is the correct concistancy the paint needs to be mixed at for the dynatec psg 45 electric spray gun
It depends on 3 things.
What you are painting.
Whether you are applying latex, oil-base, or primer.
What size TIP you are using.
We use spray equipment and use size 17 and 19 for latex, and 11 for oil.
Double-check the size that came with your gun and look at tips at Home Depot.
Old tips wallow out and the spray pattern is irregular/uneven and the gun blows out too much paint and our material costs go up.
The manual says "dilute correspondingly"
http://www.airless.com.au/Airless%20Sprayer.pdf
Let's say you are spraying oil-base stain: I would NOT dillute this material.
Oil-base primer: 1 thinner to 4 paint
Latex primer: use a roller and brush so you have a good undercoat for the paint.
Oil-base paint: I would add 1/8 thinner with 1 paint, and be careful of runs
Latex stain: try 1 water to 4 stain
Cheap interior flat latex: 1 water to 4 paint
Latex semi-gloss interior: 1-1/8 to 4 paint and apply very thin coats and let dry between coats.
Cheap exterior flat latex: 1+ to 4 paint, and add more or less water as needed
Good exterior latex paint: use a roller and brush because the purpose of latex exterior pain is to apply heavy protective coat over outdoor materials ... dilluted exterior latex will not give sun and mildew protection.
We use heavy spray equipment and apply exterior latex straight form the can. It's the only way to give lasting job, unless you're doing a temporary playhouse.
The key to successful spraying is to strain your paint to get out the lump and clogs - BEFORE putting paint into the gun.
We always strain the paint unless it's a freshly opened can.
If can was opened yesterday, we strain it.
That because paint gets a dry film that will clog the sprayer.
First you need to mix your material, so you need a couple buckets.
Pour the paint and thinning material in 1 bucket, and then to mix, pour back and forth between two or three buckets. This action will mix the paint thoroughly and save you an hour of rotating a paint stir stick.
Next, you need to strain the paint.
Wash out a 5-gallon bucket.
Buy 5 gallon strainer that fits into bucket.
Pour material into bucket with strainer, lift strainer up and then grab end of strainer and squeeze out all the paint.
Immediately put lid over paint so no drying film will form.
Wash out strainer.
You're ready to put paint in spray gun.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on paint project.
Jan 06, 2011 | Garden
How to clean the stove top
use my home made stove cleaner.
make it your self. get a 500 g tub of dry causic soda powder add 2 pints of cold water and mix will. me carfull to use rubber gloves and glasses for protection. not ad a little wall paper paste to the soda untill it thickens slightly into thin jelly like texture.
apply with a paint brush and rub into stainles and enamel cooker serfaces but not painted sides or pannels that have been screen printed.
leave over night and rince with warm clean water on a clean cloth, useing gloves
Feb 25, 2010 | Maytag MGR4451ADS Stainless Steel Gas...
579 people viewed this tip
Top 3d Rose Electrical Supplies Experts
Ronald Prier
Scott Jelt
Scott Jelt
Are you a 3d Rose Electrical Supply Expert? Answer questions, earn points and help others
