Tip & How-To about Home
HANDY TIPS AND TRICKS....!!!! Check it out
1) For removing perspiration stains from shirts and other clothing soak it in Vinegar and warm water.
Then clean as usual.
2) For removing mild-dew form the shower and bath tubs use products containing Phosphoric acid.
3) Remove build up from the shower doors wipe it with LEMON OIL..It prevents it from the future buildup
as well.
4) Dusty and dirty mini blinds can be cleaned in a snap....just fill the bath tub with warm water and soap
and soak the blinds....for white blinds add some bleach as well to the water.
5) For cleaning Ceramic tiles just pour some Isopropyl alcohol over it and rub nicely with a mop. Make sure childrenĀ
are out and room is well ventilated.
Just follow these certain handy tips and tricks as they works wonders for your home.....!!!!!
Home Logo
Moss in water chamber how do I remove
From experience, I usually boil a pot of water (6 to 8 cups ) and let it cool down a little bit. Then I get white vinegar (avoid the fruit vinegars) and add about 5 cups of it into the water. Then I would let the shirt soak in the white vinegar and water for about an hour. Vinegar is a mild acid so it acts as a loosening agent for the stain. After your remove the shirt from the pot in the hour, wash as usual. (preferably with a stain removing detergent like tide) The link below provides other methods of removing moss and grass stains. I hope I helped!
Going Green Grass and Moss Stains
Jan 29, 2016 | 3.1 Phillip Lim Silk Keyhole Tank Top -...
how can I repair a bleach stain on a t-shirt
For an immediate treatment of a bleach stain, try Sodium Thiosulfate (often referred to as photographic fixer, it is an agent that has been used as a way to neutralize bleaching effects of other substances. Blot stain at first with a white cloth that has been dipped in ST until stain begins to disappear of fabric becomes saturated. Rinse with cold water and repeat until desired effect or no more progress has been made.
If you wanna get rid of the stain without using laboratory grade chemicals, use white vinegar. Before this, make sure you rinsed bleach out of fabric, if you don't it will release a toxic chlorine gas.
Soak a clean white cloth with vinegar and start blotting stain, keep doing this until fabric won't hold anymore.
Aug 06, 2014 | Clothing
Bleach stains on black jeans
Bleach doesn't stain ! it removes the dye from the fabric.
I would suggest trying to re dye the fabric with a black dye as Jeans material might be more successful .
Synthetic fabric is not as easy to re dye end up using a permanent black marker on Synthetic Shirt that I got bleach on. .
Mar 12, 2014 | Clothing
What causes yellow underarm stains on my shirt?
The yellow stains that appear on your shirt are usually caused by many factors including sweat, soil, stress and antiperspirant ingredients. In case some of these factors come together, yellow stains appear on your clothes.
Feb 03, 2013 | Health & Beauty
How do I clean the washer to eliminate the dark spots of lint and dirt on laundry?
Prevent lint from clinging to clothes by adding 1/2 cup white distilled vinegar to the wash cycle.
To remove soap residue that makes black clothes look dull use white distilled vinegar in your final rinse.Get stained white socks and dingy dishcloths white again. Add 1 cup white distilled vinegar to a large pot of water, bring it to a rolling boil and drop in the articles. Let soak overnight. Some stains on clothing and linens can be soaked out using equal parts milk and white distilled vinegar.Before washing a mustard stain, dab with white distilled vinegar.ttack spaghetti, barbecue, or ketchup stains with a white distilled vinegar and water solution.Remove perspiration odor and stains on clothing, as well as those left by deodorants, by spraying full-strength white distilled vinegar on underarm and collar areas before tossing them into the washing machine.Forgot that you left wet laundry in the machine and it now smells moldy? Pour a few cups of white distilled vinegar in the machine and wash the clothes in hot water. Then run a normal cycle with detergent.Remove smoky odors from clothes by filling the bathtub with very hot water and 1 cup white distilled vinegar. Hang the garments above the steaming water and shut the door so the steam can penetrate the fibers.Keep the steam iron clean and in good working order by getting rid of mineral deposits in steam vents and spray nozzles. Fill the water chamber with a solution of equal parts white distilled vinegar and distilled water. Set it in an upright position and let it steam for about 5 minutes. When the iron is cool, rinse the tank with water, refill and shake water through the vents onto an old cloth. Test before using.Remove scorch marks from an iron by rubbing it with a warmed-up solution of equal parts white distilled vinegar and salt. If that doesn't work, use a cloth dampened with full-strength white distilled vinegar.Remove musky smells from cotton clothes by sprinkling them lightly with white distilled vinegar and then pressing them.Get water and salt stains off shoes and boots by wiping them down with a solution of equal parts white distilled vinegar and water.Give patent leather shoes and bags a better shine by wiping them down with white distilled vinegar.Get cleaner laundry! Add about 1/4 cup white distilled vinegar to the last rinse. The acid in white distilled vinegar is too mild to harm fabrics, yet strong enough to dissolve the alkalies in soaps and detergents. Besides removing soap, white distilled vinegar prevents yellowing, acts as a fabric softener and static cling reducer, and attacks mold and mildew.Eliminate manufacturing chemicals from new clothes by adding 1/2 cup white distilled vinegar to the water.Remove soap **** and clean the hoses of your washing machine with white distilled vinegar. Periodically run the machine with only a cup of white distilled vinegar in it-nothing else added to the wash cycle.Bring out bright colors by adding 1/2 cup white distilled vinegar to the rinse cycle.Fluff up wool or acrylic sweaters (hand- or machine-washed) and rid them of soap smell with 1/2 cup white distilled vinegar in the last rinse water.
Get rid of the tiny holes left along the hemline when you take out the hem of any garment by moistening a cloth with white distilled vinegar, placing it under the fabric and ironing.
Oct 31, 2011 | Whirlpool Washing Machines
970 people viewed this tip
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
