Tip & How-To about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
My Frigidaire Dryer is not heating anymore. Repair and testing for model FEX831CS0-FEX831CSO
Hi.
The example is referring to Frigidaire electric dryer model FEX831CSO. If you have a different model see here how to locate parts and diagrams: Where do I find parts and diagrams?
First part to test is the thermal fuse located at the back of the appliance. This is tested reading Ohms on fuse contacts. follow procedure explained further below to test the fuse.
If the fuse is not the culprit, it will be neccessary to access heater assembly and thermostats.
You access the heater parts by opening the top panel, part 3 on diagram below.
The heater assembly is part of the housing, and it is part 15 on diagram.
Replacing the heater requires further disassembly, first ensure that the problem is not a defective thermostat or thermal limiter. The thermostats fails far more commonly than the heater.
To test heater and thermostat use a multimeter set at Rx1. disconnect the thermostat contacts and read impedance at room temperature.
If the thermostat is good it will read zero or very low impedance.
An alternative way to test a thermostat is by jumping its contacts.
The element is also tested reading impedance. If the element has no continuity (infinite Ohms), then it must be replaced, otherwise it is good.
Test both the thermostat and the Thermal limiter, they are tested in the same way. Both this parts are accessible after removing the top panel, and can be replaced without further disassembling.
Here the parts:
Thermostat:PS446428 part 33 in diag.
Thermal limiter:PS419402 , part 36 in diag.
Test and repair must be done by a trained person. Call the phone number listed on the user manual if you need to contact a qualified technician.
Regards.
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
Possible causes of the agitator on a Frigidaire,model FEX831CSO, combination washer dryer, to fail, and how to fix it
manuals for Frigidaire here:
http://laundry.manualsonline.com/search.html?q=Frigidaire%20FEX831CSO
Jun 30, 2016 | Frigidaire Washing Machines
Need to know which color wire goes to which connector on the timer. frigidaire wiring diagrams
Hi garyab9ss, I appreciate your post!
It appears your inquiry is listed under Frigidaire Electric dryer and you need the wiring diagram. May I have the model number please? You can typically locate the serial tag (which lists your model number) on the upper front, as you open the door or on the right/left edge on the inside of the door. Also, please provide me the timer part number that you have in hand. With this information I can deliver the correct material to you. Thank you! - Z
Jul 28, 2014 | Frigidaire Electric Dryer
why wont my dryer stay running?
Good Morning Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, will not stay running. Please check to make sure the door is staying closed. If the door is opening in mid-cycle, then the dryer will stop running. Also, make sure the plug is in the socket tightly. Your dryer could be shaking the plug loose, which could possibly be causing it to stop running. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire FEQ1442ES Electric Dryer
I have a stackable FEx831CSO. The plastic ring that goes around the dryer drum and holds it in place, broke and fell off. The dryer now makes a terrible sound and the drum is slamming around inside. Can the plastic ring be replaced? If so, where can we find one?
It can be replaced. Here's a link to your manual for the dryer, which on the 2nd and 3rd pages has a diagram of it and a part number for you...when you have your part number you can order it either directly from Electrolux or find one on Ebay or another online source....if you have a local appliance shop you may be able to get one there as well....here's the link:
http://manuals.frigidaire.com/prodinfo_pdf/Webster/5995396412.pdf
Nov 04, 2012 | Frigidaire FEX831CS Top Load Stacked...
dryer timing button off
Hi - Are you referring to the dryer timer button (located on the far left side on most laundry centers) is broken? If so, you might need to replace the entire button. You can contact the manufacturer directly to get part or go through a part distributor but part numbers can be different.
Knob, dryer timer, white-part number: 131873304/MSRP: $24.20
Sep 25, 2012 | Frigidaire FEX831CS Top Load Stacked...
4,533 people viewed this tip
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
