Tip & How-To about Handspring Visor Deluxe Handheld
Visor Deluxe does not start
Hi.
The procedure below shows how to reset the PDA to factory settings after backing up all your personal data.
After backing up your data with HotSync, perform a hard reset, this will erase all applications and returns your device to its factory default settings.
To perform a hard reset:
1. Hold down the power button on the front panel of the PDA.
2. While holding down the power button, use a paper clip to press the reset button.
3. Release the power button.
4. You will get a message warning that you are about to erase all the data stored on the PDA, do the following:
Press the top scroll button on the front panel
to complete the hard reset and display the startup screen.
If you press any other button you will do a soft reset, that will not fix the problem. In that case restart the procedure.
5. After doing hard reset the unit will return to the initial factory state. All third party installed applications will be deleted, and setting will be reported to factor default.
Connect to HotSync and do a backup of the PDA, then do hard reset on Palm.
If the PDA is not detected by Hotsync, then there is an additional problem.
To troubleshoot problems given by third party application you do a backup, then rename the backup folder containing third party application data to Backup.old, and do hard reset.
After that you start restoring applications from backup.old one at the time, when one application jams the Palm, that is the responsible for the error message.
Procedure is described here.
Regards.
G.
Handspring Visor Deluxe Handheld Logo
It tells me that I don't have enough memory and should delete data files App 8004 and App 8002. I don't know what I can remove without damaging the performance. What can I move to the extra card I have
Hi.
To start you can delete safely any music or video file.
If that is not enough to fix the problem, then the best thing to do is resetting the PDA to factory settings after backing up all your personal data.
Regards.
Mar 02, 2010 | Handspring Visor Deluxe Handheld
After a soft reset, my Palm TX becomes stuck on the "Palm Powered" screen. I have tried all of the resets, including the hard reset. The PDA does not respond to any of the resets. I can not turn the PDA off; I usually leave the PDA running until the battery drains. After I recharge the PDA, the same problem exists. Any suggestions on how to get my PDA working?
You need to perform full reset which will erase all personal data and set everything to factory default. You need to press reset and power button to perform full reset.It will give you confirmation once you choose yes it will perform hard reset If issue persist you may disconnect and reconnect to internal battery
Aug 02, 2009 | Palm TX Handheld
I am not able to access any installed programs installed in my HTC P3400i, can any one help me in this ????? By : Pinak
u mean that windows is there but programs are not showing up then try hard reset the device follow below procedure to reset it to facory default see if it helps or u can also download the latest update of software from www.htc.com for ur PDA
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
Feb 18, 2009 | HTC Touch P3450 Smartphone
format a palm PDA
Hi jotleyjohn
Probably the best advice on doing this comes direct from Palm. check this link out and follow the procedures they give to do a factory reset, that will erase all data.,
If you have any dramas, feel free to get back to me here.
regards
robotek
Jul 15, 2008 | Palm TX Handheld
the screen
Hi.
I guess that after so long the original problem had been fixed.
Here the tip, in the hope this will help anybody in trouble with this PDA.
Try resetting, follow procedure below, that will set calibration to factory default. Click here. The procedure shows how to reset the PDA to factory settings.
Nov 01, 2007 | Handspring Visor Deluxe Handheld
1,061 people viewed this tip
Top Handspring Computers & Internet Experts
Damen Wong
Damen Wong
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Handspring Computer and Internet Expert? Answer questions, earn points and help others
