Tip & How-To about Video Game Consoles & Games
Reset your Wii Video Settings to the Default
One annoying thing about the Nintendo Wii is that there is no way to reset the video settings once you have changed them in the Nintendo Wii System Menu.
It will not detect which cables you are trying to use and just tries to use the last settings that you set it to.
So, if you have changed your Nintendo Wii from using the regular cables that came with the system to using component cables, then switch back to a TV using regular RCA cables (these are the yellow, red and white cables) then you need to reset the settings on your Nintendo Wii to the default video settings.
You can reset your Nintendo Wii video settings to use Composite (or RCA - Yellow, Red and White) cables by doing the following:
1. Make sure the Nintendo Wii is powered off and a red light is showing.
2. With the power off, unplug the video cables from the back of the Nintendo Wii, leave them plugged into your TV (these should be the RCA/Composite cables)
3. Press the Power button on the front of Nintendo Wii. Make sure the cables are still unplugged.
4. Keep the Nintendo Wii powered on and plug your cables back into it with it still running.
5. If all went well, the picture should appear normally now.
6. Once the picture has reappeared, you should go into the Nintendo Wii Menu (the Wii button in the bottom left hand corner) and change the display back to 480i to make the changes permanent.
I hope this tip helps!
Video Game Consoles & Games Logo
Cannot remember old password ,How do I reset so as to use with info that I have entered.in system
Here is how to reset your Nintendo Wii:
1. First, the easy way. A soft reset of the Ninetendo Wii. If you Nintendo Wii has just started acting up and there is no reason to perform a hard reset then follow this instruction. Simply press the reset button and hold down for 2 seconds on your Nintendo Wii Console.
2. Now, for the more advanced hard reset. Interestingly, the Nintendo Wii has NO hard reset facility to be accessed through the machine or via buttons. The ONLY way to hard reset your Nintendo Wii is to UNPLUG it for 5 minutes. Once it is unplugged it resets itself and your badly behaving Nintendo Wii should be restored.
Note: By hard resetting the Nintendo Wii, it will not delete any information on the SD Card that is used for storage. If you wish to delete this data, stick it into a computer with a multi-media card device or a digital camera and reformat it.
May 30, 2011 | Nintendo Wii Console
I accidentally set my wii to HDTV settings and I need to reset it back to normal tv but my screen is so messed up I cant see options or anything
May 01, 2011 | Nintendo Wii Console
how do i factory reset ?
Another option to try is to go to the following:
Wii settings and press reformat wii system memory.
The last part of wii settings and press reformat wii system memory.
The last part of wii settings and press reformat wii settings and press reformat wii system memory.
If all else fails you can ask nintendo, you can call them at 1800-255-3700
I hope this helps and good luck.
Oct 28, 2009 | Nintendo Wii Console
i need to know how to reset my wii system?
there are 3 ways to reset,1.press the reset button on the console.2.go to the last page of settings and press system reformat.3.eeek.pull the plug out for 5 minutes.and plug it in again.
Apr 08, 2009 | Nintendo Wii Console
reset wii console
Step1First you will need to check a few things, just to make sure what the actual problem is.
*Check to see that all cords are properly plugged in.
*Make sure the sensor bar is properly center above or below your tv set.
*Make sure that nothing is blocking the signal to the sensor bar.
*Make sure that the batteries in the remote are in good working order.
*Make sure that there are no wireless devices close by that might be interfering with the signal. Step2If after all this the remote is still not working then it probably needs to be re-synced. Step3Turn off and unplug your wii console for a few minutes. Step4*Turn the power back on and when you see the the safety screen open the small flap on the front of the wii console. Inside you will find the red sync button. Press and hold the red button down for 15 seconds.
* Then remove the battery cover from the wii remote, inside you will see another red button.
* Press and release the red button, the blue lights on the remote will start blinking.
* Quickly press and release the red sync button on the wii console.
* The remote will stop blinking and it should now be synced.
Feb 19, 2009 | Nintendo Wii Console
13,520 people viewed this tip
Top Video Game Consoles & Games Experts
Nikki  Mclean
Nikki Mclean
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
