Tip & How-To about Computers & Internet
Fast program panel on windows
Did you now that on windows you can make your all program panel show very fast than usually.
1. press the start button
2. find the menu called Run
3. the panel run will show up
4. type regedit and enter
5. and the registry editor will show up
6. press button ctrl + F on your keyboard
7. panel Find is show
8. type " menushowdelay " without space then press enter
9. after the menushowdelay edit strings found double click
10.change the number usually is 400 change with 0 or 1 then press ok
11. close all panel.the you can try the different from u all program menu on your windows
Computers & Internet Logo
Outlook program has refused to open and ask that I check internet for solution
Try to open Outlook in safe mode. Follow thses steps to do it.
1.Click on start button (for Vista it will be Windows button ) and click on Run.
2.Type outlook.exe /safe and press enter.
3.If outlook is not starting then we have to do a detect and repair. Follow these steps to do that.
Detect and repair.
1.Click on Start button (for Vista it will be Windows button ) and click on Run.
3.Go to Help tab in Outlook and select office diagnostics, click on continue and click on Run Diagnostics.
Method 2:
Try to open Outlook without addins.
1.Click on start button and click on Run.
2.Type outlook.exe /a and press enter.
If he can open Outlook in this way, then the third party addins are causing the issue. This can be resolved by
removing the third party addins. Follow these steps to remove third party addins.
1.Open Outlok and click On the Tools menu, click Trust Center, and then click Add-ins.(for Office 2007).
2.In the Add-ins box, identify the add-in that you want to disable and note the Add-in type located in the Type
column.
3.Select the Add-in type in the Manage box and then click Go.
4.clear the check box for the Add-in that you want to disable and then click OK.
  • Method3:
    Press Cntrl+Alt+Delete to open task manager and click on processes. click on outlook.exe and click on End process.
    If there is multiple outlook.exe running end all of them. Try to open outlook after ending all outlook.exe processes.
  • 4
    Method4:
    Take a back up of pst files and reinstall Outlook . follow these steps to take a backup of pst files.
    1.Close any messaging programs such as Outlook, Microsoft Exchange, or Microsoft Windows Messaging.
    2.Click on start button and go to setting and open control panel.
    3.Double-click the Mail icon.
    4.Click Show Profiles.
    5.Click the appropriate profile, and then click Properties.
    6.Click Data Files.
    7.Under Name, click the Personal Folders Service that you want to back up. By default, this service is called Personal 8.Folders. However,
    it may be named something else
    9.Click Settings, and then note the path and file name that appears.
    10.Close all the Properties windows.
    11.Open the file through the path and copy it to a new folder as backup.
  • Oct 05, 2010 | Computers & Internet
    New Aspire with windows 7 is very slow
    It may have a virus or just a bad windows install.
    Try using your restore disk or option to bring back to factory.
    Jan 07, 2010 | Acer Aspire AS5520-5537 Notebook
    computer boot screen slow?
    Do the following to make your PC Fast
    Do 1
    1. Turn on your computer, and hold down delete.
    2. In the BIOS window, look for the Boot Menu option.
    3. Choose the QUICK BOOT to turn off memory test
    .4. Make sure the hard drive comes first in the BOOT ORDER.
    5. Turn off any logo displays.
    6. Restart
    Do 2
    1. Open your Start menu.
    2. Click Run
    3. In the command screen type msconfig
    4. In the system configuration utility,click either BOOT tab.
    5.In the boot menu, change the default setting for Time Out from 30 to 5 seconds.
    Do 3
    1. Click the Start button.
    2. In the Start Search bar, type control userpasswords2
    3. Load the User Accounts window
    4. Uncheck User must enter user name passwords...
    5. Click Apply
    Do 4
    1.Click Start button and load the Control Panel
    2. Under the Control Panel menu, click Programs.
    3. Under the Windows Defender heading choose View currently running programs
    4. Choose Startup Programs from the Category option
    5. Remove Programs that you feel unnecessary for startup
    Do 5
    How to disable this indexing service
    1. Click on Start
    2. Click Run
    3. Type services.msc
    4. Select Indexing Service and Double click on it.
    Select Manual under Startup Type.
    5. Click Stop
    6. Click OK
    Jan 02, 2010 | EPoX EP-8KRA2+ Motherboard
    190 people viewed this tip
    David Payne
    David Payne
