Tip & How-To about Microwave Ovens
How to change a microwave oven fan motor.
When your microwave makes loud noises, and they are eminating from the fan motor you will need to replace the motor. It no doubt has bad bushings. If not oiled periodically, and who does this, the motor will gall the bushings and make a loud screeching sound. Sometimes just oiling the motor after the sound starts will solve the problem, but most likely only temporarily. A permanent solution would be to replace the motor.
Unplug the unit. If your unit is not a freestanding unit and is mounted under the cabinet it will have to be removed from the cabinet first to continue. Usually this requires two people and the removal of two screws inside the cabinet above the microwave, tilting the unit down at the front and lifting the back of the unit off the mounting rail.
Remove all the screws from the rear of the unit case, perimeter and slide the cover off to the back. The motor should be visiable at this point. If it is not there could be a guard over it which should come off with one or two screws.
Go to http://www.repairclinic.com where you can get the new motor. They generally have parts for everything and at the best prices.
The mounting procedure should be obvious, either two or four screws. Remove and replace the motor. The motor wires should be spade lugs. Remove and replace one at a time to avoid any confusion.
Reassemble the unit by reversing the procedure listed above and remount under the cabinet if originally mounted under a cabinet and you should have a quiet running microwave.
hardrocko
Microwave Ovens Logo
speed queen noise when on spin
follow this test and fix it. God bless you
  1. MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  2. Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  3. Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  4. Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replaced.
Nov 19, 2013 | Microwave Ovens
Microwave occasional loud buzz
make this test and fix it. God bless you
Nov 14, 2013 | Jenn-Air JMV8208AAS Microwave Oven
GE microwave occasionally buzzes loudly.
Nov 14, 2013 | Microwave Ovens
gh5184xps3 microwave
this cause noise ; God bless you
  • MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  • Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  • Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  • Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replace
  • Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#13#ixzz2ZPm395lp
    Jul 18, 2013 | Whirlpool Microwave Ovens
    Coleman EB15A - Buzzing noise from transformer area, no heat or fan
    see this causes and proceed. God bless you
    Magnetron If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
    Exhaust Fan Motor If the microwave is loud when running the fan motor might be
    Stirrer Motor If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
    Turntable Motor If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
    Oct 18, 2012 | Microwave Ovens
    439 people viewed this tip
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
