Tip & How-To about Cycling
Most GM cars especially Pontiac's are prone to a clicking noise that sounds like a relay clicking on and off repetitiously at various speeds. This is cause by a faulty direction switch. It took Pontiac years to figure this one out. My first encounter of this was my friend rebuilt a steering column with used parts and his results gave him this problem. We had found the brass contacts were mushed down grounding out at times when ever the engine was running spiking the voltage in the wiring causing the relay to turn on and off all the time. The only remedy is to replace the directional switch with a genuine GM updated part. Then the clicking noise will be gone
Cycling Logo
Sounds like I have tweetie bird stuck under my hood.
could just be time for a new belt but some GM products will make that kind of noise when the bearing in the alternator is going bad
Oct 31, 2012 | 2002 Pontiac Grand Am
I hear a relay clicking under the dash in my 1997 sunfire. what could it be?
these cars has a bad reputation of this clicking dued to qa faulty directional switch causing the relay to click at various speeds
Apr 09, 2010 | 1997 Pontiac Sunfire
Front End Rattling in 2006 Pontiac Pursuit
Sounds like a body weld issue ( as this is a unitized body design). Several US GM models prone to this. No real good cure.
Jan 15, 2010 | 2006 Pontiac G5
2000pontiacgrandprix noise under accelration maybe exhuast?
Hello! First of all, congrats on owning a great car! That engine (3.8L Series II L67) is without a doubt one of the finest GM (Buick) has ever produced!
On to your problem - I think you have one of 2 things wrong:
1) a loose heat shield
2) a broken exhaust hanger
Both of these will cause intermittent (and highly annoying) rattling sounds, especially at low speeds or when the engine is under load (like going up a hill for instance). There are 2 hangers under the car located almost directly under the front floorboard. These are prone to breakage. There is also a heat shield in this same area - that is very prone to coming loose. If it's the heat shield - you can either remove it - or have it tack welded. If the hanger(s) are broken, you will need to take it to an exhaust shop (unless you know a welder :) ) and have those fixed - shouldn't cost you more than $20 either way.
Hope this helps and good luck!
Sep 24, 2009 | 2007 Pontiac Grand Prix GXP Sedan
119 people viewed this tip
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
