Tip & How-To about Computers & Internet
Monitor LCD Screen Replacement With A Laptop Screen
This tip is for the typical PC tech with a shop full of dead laptops and monitors, looking to make an extra Monitor for bench testing malfunctioning PC's. Maybe you're a tinkerer and just have some spare parts laying around, and want to make something cool and easy. Either way, this tip is a fun way to make old dead parts work for you, rather than sitting in a corner gathering dust.
Replacing a Laptop screen is pretty easy if you take it slow.
LCD Monitor screens are actually easy to replace too, if you are careful not to crack anything getting one out and in again.
This tip doesn't address any of the typical replacement methods.
What this does is show you how to use a laptop screen in a standard Desktop LCD monitor.
Having already disassembled your Desktop monitor, and determining that one or both of your backlights is dead, you will most likely begin searching for sources of a new one. Before you do that, try testing both backlights in the dead monitor screen first by hooking them, one at a time to an inverter in a working laptop to verify that both are dead.
Most of the time, you will discover that only one light is dead, and this is where the fun begins.
At this point, you have a few choices to make.
1. Extract a working backlight from a cracked LCD, we all have a few of those lying around somewhere in just about any PC tech area.
2. With the extracted backlight in hand and the old LCD screen still attached to the monitors electronics, remove either of the sets of wires going to one of your backlights, leaving one still attached.
3. Now you can attach the light you extracted to the empty socket your original screens light attached to, while leaving the other one still attached.
4, Now, turn on the monitor and wait for the extracted backlight to come on, if it doesn't switch it with the other light socket plugged to your screen, and plug the opposite light wire back in.
This will do 2 things for you. First, it will be a quick test of your inverter, and second it will verify that you do or don't have at least one working backlight still functioning in your monitor.
Remember that with most LCD monitors, just one backlight can provide enough illumination for your screen to show a very crisp picture.
The problem appears though, when we decide that our existing LCD is dead because we dont see it light up.
The solution for this is to simply disconnect the dead light wire from the existing inverter plug leading to the LCD screen, then replacing that with a working light from the cracked screen without disassembling the LCD screen itself. If you did everything right, your old dead screen will be working as it should. Be sure you swap the backlight connecting wires so that your Bright/Dim controls work as they did before.
You see, most dual light inverters work the same as a standard twin tube household flourescent light. When one goes out, they both eventually stop working. So, adding that second light completes the circuit, then swapping light socket connectors turns your backup light tube into the primary light, instead of the secondary.
Now, if THAT trick didn't work, you can move on to the Laptop LCD trick, which is pretty much what you did before, except that the Laptop LCD usually only has 1 light tube. So for this to work, you can complete the lighting circuit by simply adding your spare backlight tube to the second open backlight connector, then installing the LCD to your monitor.
Many of these Laptop LCD screens are the same height and width as comparable Desktop screens, but they are also thinner, and will have to be glued or taped to the frame from the inside. Everything else connects exactly as the original screen, but may need to have wire added to the Laptop backlight wire so it reaches the power source.
I figured this tip was worth posting, since I just did this trick with a 15" polaroid HDTV/HDMI/HiDef Television/Monitor combo.
The model I have died a few months after it was bought new from Walmart, and the customer just didn't feel like paying $129 for a new screen.
Being the packrat I am, I just couldn't bear throwing it away, figuring that some day I would find a matching screen. As you can see, I got tired of waiting. The pictures of my project are below.
That bright line of light isn't the flash from my Camera, it's the flourescent light tube from a broken LCD screen placed on top of the steel housing.
The incidental effect of that light is that my back wall is a nice nitelite, and hooking up new components is a lot easier. Yes I could have blacked it out, but I think I like the added light behind the TV.
I hope this Tip comes in handy for you.
Bob S.
Computers & Internet Logo
hp P6000 fans stop after 15 seconds. Hard drive light stays on. nothing on monitor
dead PC, DESKTOP PC ,as old as 2009.
the fans tells you the PSU shut off, for cause.
fans, so you saw all fans turn off or just 1. or 2 of 3.
my pc has 4 fans many have 3;
CPU fan stops ,cpu overheats , PC goes slow or dead. clean the lint off it.
GPU fan , video goes dead. if it overheats.
PSU fan is inside the PSU if it goes bad, PSU is bad.
no monitor stated, is it CRT or LCD is it 15 years old.
if the monitor is 2002 or newer the OSD screen works
even with PC turned off, press the select button see that OSD screen ? telling you the monitor is not dead in 1second flat;
i caN NOT understand why the HDD lamp glows,
if the PSU shuts off , most LEDs go dead, on my PC
the standby LED on the MOBO glows, unless you pull the PSU power cord.
your HP PC came with 9 different mobo, during its production run.
at least. so answers come harder from that reason.
here are some simple tests.
test 1
power on, hear fans run
does the DVD drive (or cd) button eject work,.?
do all fans not just 1 or 2 worK? look for all fans clean the lent out
or things will overheat,
PSU can be bench tested or in the PC case.
using a jumper wire, even the HP service manual covers that.
power on the PC (after keeping monitor on for 5 full minutes)
test 2
the Screen must say, "hit ESC key to enter HP setup" BIOS.
press the ESC key on the monitor
if no text shows up that is a dead PC< "text above missing{"
if the PC told you to hit another key do so.
The ESC key , activates the BIOS brain. this cause
all those pages to work as seen in your service manual;.
if BIOS is dead that is a bad PSU (monitor ok)
or CPU is overheated.
bad ram, take all sticks out and test 1 by 1, ask how. !
The PSU will shut down on up to 12 or more faults
but never shuts down the standby power bus. unless AC line pulled.
IF the PSU has fan as most do this is the first place I look.
try this guide
https://support.hp.com/us-en/document/bph06788
Jul 08, 2017 | HP Computers & Internet
no display
You need to do some troubleshooting here to figure out what the problem is exactly.
1. On all Laptops there is a Fn key and one of the Function Keys at the top row that has a picture of monitors on them. Hold down the Fn Key then hit this monitor function key at the top, usually it's anywhere between I'd say F8 and F11 in most cases. Hit it one time, and wait to see if the monitor lights up. If it does not hit it again. You will want to do this at least 3-5 times and wait for about a good 10-15 seconds between each time.
2. If that does not work, then try hooking up an external monitor to the laptop through the Blue VGA connector on the back of the laptop. (Sometimes these connectors are on the side of the laptop) You can hook up any external monitor to this port assuming you have the right cable. Some laptops come with a White connector that looks different than the blue connector in that it does not have pins. This is called a DVI connector. Most newer LCD's are now converting to DVI connectors, but all LCD monitors can use the blue VGA connector cables. Note: You may have to use the Fn + FKey again to get an image on the external monitor. IF you do get a picture on the external monitor and the laptop appears to operate normally otherwise, then chances are your LCD is dead and is in need of replacement.
Fix 1: Inverter is bad or died - Depending on LCD this can range in price from I'd say $40-$150 to purchase if you are tech savvy you can fix this yourself.
Fix 2: Backlight has died or is bad - Depending on where you shop for it, this part is usually fairly cheap, and if you are savvy enough can be replaced at reasonably low cost.
Fix 3: You are not tech savvy: Take your laptop into a local PC shop, and have them check it out for a bad inverter, backlight, or to confirm rather or not the LCD is dead. Note: LCD replacements can run upwards of $300 or more. I've seen them go as high as $500.
Hope this information helps.
May 18, 2014 | Toshiba Satellite Pro L300 Notebook
nothing in the monitor
If you have a standalone monitor that you know works you can test out the laptop by connecting that monitor to the external VGA port that can typically be found on most laptops.
You may need to check your laptop function keys to see if you need to manually change the video output source before determining if this test works or does not.
The Video output key typically looks like either a monitor with an arrow coming out of it or two monitors side by side with a line between them. There are a variety of icons for this and it can be difficult to predict exactly what your specific model has.
If the external monitor does show an image than your laptop's monitor has gone bad. It is possible to replace this by locating an identical model laptop on sites such as ebay or craig's list (buyer beware) that has a working monitor, but some other component failed.
Seeing as your T41 laptop is an older model the cost of parts will be greater than the value of the laptop itself. I would suggest investing in a modern laptop instead of repairing your T41.
Aug 29, 2011 | IBM ThinkPad T41 Notebook
When I open HP MY DISPLAY software it doesn't work. It looks full black. There is no menu or option. It shows blank. So I can't tune display color or any other things. I uninstalled it. Then I install this software again. In spite of this, it doesn't work. Now please give me some recommendations.
HP W1707 LCD Monitor circa 2008 old. 10 years old NOW.
No PC stated or any OS at all. windows what?
connected to what? it must be connected to a working PC
or the monitor is useless as 3rd shoe.
i can only be 2 things, PC or screen bad.
  1. the test is child easy test the monitor on another PC.
  2. or test the dead PC on another good monitor.
the monitor has no software ever.
only the PC side does for the PCs video chip GPU driver.
but the PC always has one, even if, poor quality resolution.
Toss magic coin land on bad w1707
The screen, can fail for many reasons lets say it fails on a good PC. known good.
these old monitors have CCFL lamps that love to fail inside.
It has no LED back lamps , before 2010. it haS CCFL lamps.
The monitor all by its self, pc disconnected.
you power it on and it shows logo, HP or Compaq
then for seconds turned on the menu may work.'
if you see nothing the CCLF are dead.
The menu button works only with good running PC. but
might work for 1 second.
some do others dont but only for seconds does the OSD work
lacking a good PC connected.
the OSD is the menu from the monitor brain inside
the button is called select or menu.
PC turned off and Monitor now turned on the screen shows.
if the PC is dead the Monitors brain then shows.
NO SIGNAL , or NO sync.
or if PC is set up wrong the monitors shows, OUT OF RANGE.
CCFL love to fail.
the lamps turn yellow, blink or go DEAD.
as can the HV inverter seen here.
http://www.pcdied.com/monitors.html#Inverters-monitors
PAR:
i one uses the monitor 10 hours a day
on the 5th year, the CCFL goes dead. that is there normal life span.
Dec 27, 2017 | HP W1707 LCD Monitor
207 people viewed this tip
David Payne
David Payne
