Tip & How-To about Office Equipment & Supplies
HOW TO GET THE BEST DIGITAL PRINTS...
Printing a photo but not getting it upto your expectation.....?? No worries just fiddle a little bit
with the printing options and keep in mind some important points that I am going to tell you....it will help:
1) RESOLUTION OF THE IMAGE TO BE PRINTED... Always keep in mind while printing a digital
printout that the resolution should be best fitted i.e. of the original photo.... if you stretch A photo too
much or squeeze you might not get the desired result. It depends upon the DPI i.e
dots per inch that appear on the paper in the snap that you print. To get a quality print you must
make sure to select proper dpi for an image in printing. Eg. for printing a snap of 300 dpi you must choose
the image resolution as 600 dpi, but in case of professionally required image quality you can select upto 24oo dpi.
2) PRINTING PAPER ... Make sure that the paper you are using is suitable for the ink and the printer that
you are using. Certain printers specially design Photo Paper suitable for the ink used in them for eg. HP printers
do have Hp photo papers to give a good quality of image.
3) SETTINGS IN THE PRINTER... You can adjust the image quality that you want by clicking on the
Properties Option in the printer dialog box that opens when you give a print command. for eg. you can select
Economy mode for saving the ink (but this will not give a good quality image as colors to will be low),
or you can use the Bes option, as suitable for you...
So next time you Print a photo or snap of yourself make sure to remember these points and have fun.....
Good Luck!!
Printer will not accept photo paper anymore.
Printing photo paper is bit to different than normal paper, Visit this link and follow all steps mentioned there to correct the problem. If needed change printing paper type to PHOTO paper, you'll find this option under Print Settings ( Step 3 under this link).
Thanks...!!
4 thumbs rating keep us motivated to answer more free questions.
Nov 26, 2010 | HP DeskJet F4280 All In One Printer InkJet
photo paper jam what thickness of photo paper should i use for a hp photosmart 8250 i keep getting jammed up and think the paper is to thick
Be sure and check the printing properties before printing. make sure that you specify the kind and thickness of the paper. This way the printer expects that thickness when printing. Sometimes, glossy paper makes the printer jam easily. Try putting around 25 regular paper on bottom of special paper and see if that helps.
Sep 13, 2009 | HP Office Equipment & Supplies
my hp 915 having trouble printing photos with glosy papers
don't try to put heavy weight paper like 230 gsm in hp 915, it's not a photo printer (MFP), use upto 170-180 gsm only for gears safety, for heavy weight media try another photosmart series printer.
Jan 09, 2009 | HP Compaq Presario 915 (470045-499) PC...
Wrong colors when printing on photo paper
yha way not
if you worry about wrong colors
it is possible you 3 colors cartage has mis a color it is maybe red,green,are yellow, refill your cartage and print again
Dec 16, 2008 | Canon Pixma MP500 All-In-One InkJet...
lexmark Z53 prints photos on 'normal' but enlongates image on 'best'
I'm getting around the problem by using Windows or Nero print options to get the photo as near to the size I need. It would be good if I could print photo's from Photo studio though much simpler and less time consuming.
May 23, 2008 | Lexmark Z53 Color InkJet Printer
185 people viewed this tip
k24674
