Tip & How-To about Cell Phones
Phone
Try using the mac or windows 7 to what he prblem in some cases its just the battery in different types of phone try unplugging and bam there you go
Cell Phones Logo
MacBook Pro is slow when disconnected with electric charging.
First step would be to Reset Your Mac's SMC
The method for resetting your Mac's SMC depends on the type of Mac you have. All SMC reset instructions require shutting down your Mac first. If your Mac fails to shut down, try pressing and holding the power button until the Mac shuts down, which usually takes 10 seconds or so.
Mac portables with user-removable batteries (MacBook and most MacBook Pros):
1.Shut down your Mac.
2.Disconnect your Mac portable from its MagSafe connector.
3.Remove the battery.
4.Press and hold the power button for at least 5 seconds.
5.Release the power button.
6.Re-install the battery.
7.Reconnect the MagSafe connector.
8.Turn your Mac on.
Mac portables with non-user-removable batteries (MacBook Air and some late 2009 MacBook Pro models):
2.Connect the MagSafe power adapter to your Mac and to a power outlet.
3.On the built-in keyboard (this will not work from an external keyboard), simultaneously press and hold the left shift, control, and option keys while you press the power button. Release all keys at the same time.
4.Press the power button to start your Mac.
Mac desktops (Mac Pro, iMac, Mac mini):
2.Unplug your Mac's power cord.
3.Press and hold the Mac's power button for 15 seconds.
4.Release the power button.
5.Reconnect your Mac's power cord.
6.Wait five seconds.
7.Start your Mac by pressing the power button.
Alternative SMC reset for Mac Pro:
If you have a Mac Pro that isn't responding to the normal SMC reset as described above, you can force a manual SMC reset by using the SMC reset button located on the Mac Pro's motherboard.
2.Unplug the Mac's power cord.
3.Open the Mac Pro's side access panel.
4.Just below the Drive 4 sled and adjacent to the top PCI-e slot is a small button labeled SMC. Press and hold this button for 10 seconds.
5.Close the Mac Pro's side door.
6.Reconnect your Mac's power cord.
7.Wait five seconds.
8.Start your Mac by pressing the power button.
Now that you have reset the SMC on your Mac, it should be back to operating as you expect. If the SMC reset didn't fix your problems, you can try combining it with a PRAM reset. Although the PRAM works differently than the SMC, it can, depending on your Mac model, store a few bits of information that the SMC uses.
Jan 23, 2013 | Computers & Internet
How to find MAC address on my HP Elitebook 8460p?
use your command prompt and type ipconfig /all then look for physical address. that is your mac address.(To get to command window just press windows key and R then type cmd and press enter.)
Aug 02, 2012 | HEWLETT-PACKARD Elitebook 8460P
pointer on laptop jumps to a different line while typing.
This may be caused by weak batteries, or interference by some nearby appliance (the worst case is another wireless mouse, of course: happened all the time in an office with six identical workstations, even to the two that were beyond a wall. But also wireless - not cellular - phones may interfere). Also the positions of receiver and mouse may play a part. Once sure the batteries work, try placing the receiver and mouse in different positions and see if it helps.
Otherwise, the receiver antenna could be defective.
Nov 07, 2009 | Microsoft Wireless Notebook Optical Mouse...
Hello, I am trying to send photos to my mac through bluetooth, but the phone keeps droping out. can you please help.
just make sure that you are using the right software for your phone(mac in this case: some drives are for windows) and also they are compatible.(you can do this by reading your phone manual)
if you are still not satisfied try it on a different PC with a windows operating system or still a mac if you so prefer.
good luck
May 12, 2008 | Lands Phones
158 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
