Tip & How-To about Computers & Internet
WANT TO BURN A DATA-CD OR A DATA DVD ON WINDOWS 7 USING WINDOWS MEDIA PLAYER......???
Burning a Data cd on dvd on windows 7 is very easy and simple using Windows media player....
just follow the steps given below:
1) Click on the Start button
2) Click on All programs
3) Go to Windows Media player
4) Once the player is open look for the Player library and click on the Burn Tab There.
5) Once the Burn options are opened click on Data DVD or CD
6) Insert a blank cd into your cd-rom.....make sure the type of cd you are inserting is same as the
option you select for burning.
7) if in case auto play box opens then close it
8) In order to make it easier, prior to starting the procedure of burning a dvd or a cd make a folder on
the desktop which includes the data or the songs that you want to burn in......it makes it easier to locate a single
folder rather than to search individually for an item.
9) Drag the songs you want to burn right into the middle of the player library's list pane which lies on its right side
10) for removing a certain song, right click and select remove from list
11) after your'e done with the selection, just click on the START BURN button
12)It takes a little time to burn a data disc. Make a note that data DVD is not as same as DVD video disc.
That's it and you get a whole set of songs into your cd just within a few minutes.........so get goin.!!!
Good Luck!!!!!
Computers & Internet Logo
my cd rom will not play acd it as encountered a problem
You can Try these Steps :-
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Method 1: Remove the Adaptec CD-Burning Plug-in in Media Player version 7.x
Follow the steps below to remove the Adaptec CD-Burning Plug-in from Media Player version 7.x. Windows Media Player version 8 that came pre-installed in Windows XP does not display this issue.
Click Start , Settings , and then Control Panel .
Double-click Add/Remove Programs .
If installed, Windows Media Player 7.x will be presented in the list.
Click the Change/Remove button.
The Windows Media Component Setup window should be displayed. The radio button next to Remove Windows Media Player components should be selected. Click Next .
Place a check in the box next to Adaptec CD-Burning Plug-in . Click Next .
The Adaptec CD-Burning Plug-in will be removed from the computer. Click Restart to complete the operation.
Method 2: Removing the Upper and Lower Filter registry keys
The second method for resolving this issue is to remove the registry keys associated with the loading of CD recording drivers. Follow the steps below precisely to resolve the issue. Exporting the registry is imperative before making any changes to the registry. If mistakes are made during the editing process, the registry can normally be repaired with the exported registry.
Step 1: Remove upper and lower filters
The steps below describe how to remove the drivers associated with the drives disappearing. After removing the filter driver keys, the CD recording software will be have to be re-installed.
With a copy of the registry exported, click the plus signs [+] in front of the follow keys in the order they are listed: HKEY_LOCAL_MACHINE , SYSTEM , and then ControlSet . In some cases, multiple ControlSets may be listed similar to the following:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002
or
Click the plus sign [+] in front of either CurrentControlSet or the lowest numbered ControlSet. For example, in the second list above, ControlSet001 would be the correct listing.
Click the plus sign [+] in front of Control.
Click the plus sign [+] in front of Class.
Locate the following key and highlight it in the left window of the Registry Editor (The numbers can be very similar, be careful select the correct key. Another method to find the correct key is to highlight Class, then cut and paste the key below into a Find window accessed from Edit and Find in the Registry Editor.)
{4D36E965-E325-11CE-BFC1-08002BE10318}
With the key highlighted, the right pane will have multiple keys listed including LowerFilters and UpperFilters. Highlight LowerFilters and press the Delete (Del) on the keyboard. A confirmation dialog box will be displayed asking if the value should be deleted. Click Yes to delete the value.
Repeat the process for the UpperFilters by highlighting UpperFilters, pressing the Delete (Del) key on the keyboard and again confirming the value should be deleted by clicking Yes.
Exit the Registry Editor
Restart the computer. The optical drives should then be recognized and available for use.
NOTE:- If the computer still does not recognize the drives, go back into the registry and repeat the above steps for editing the registry for each of the ControlSets listed on the customer’s system.
Step2: Reinstall the HP DVD / CD-Writer software
Deleting the LowerFilters and UpperFilters will prevent the previously installed recording software from operating successfully. The software that came with the HP CD-Writer or DVD Writer will need to be re-installed to function correctly. Follow the instructions included with your CD-Writer to re-install the software.
Oct 07, 2008 | Computers & Internet
4 steps to reset lost Windows 7 password
Forgot Windows password? it is your better choice to use windows password recovery 6.0, a efficient and highly appreciated software on Windows password reset. GO TO its official site for more info
Nov 09, 2010 | Computers & Internet
EZCD 5.0 and EZCD 6.0
I don't think that 6 and 5 are compatible 6 is an upgrade from 5. I have just 5 on one of my old XP computers and it works fine, but that's all I have. I went to the website and they are not giving any support for Roxio 6 anymore.
I will tell you that Roxio Easy Media Creator is fantastic. The things you can do with that are unbelieveable. I got it at Sam's Club for about $70. But I know that does not solve your problem.
Roxio 5
To burn data files, Open project selector, make a data cd, click data cd project. WhenEasy CD Creator 5 opens and you choose your files to burn, try this: Select Disc at Once Radio button, click okay and click burn.
ID Number: 000008GN Products: General Information
OS: Issue When burning a CD or DVD, you receive an error, burning does not complete, or your media is rejected. Resolution Burning errors can happen for a variety of reasons. Roxio has found that doing the following steps resolves about 80% of all burning issues. Please give all these steps a try and see if it fixes your writing problems.
  1. Update your drive's firmware/drivers. Most companies regularly update their firmware and drivers. If you are unsure what model your burner is and its firmware, click here to find out.
  2. Enable DMA. Direct Memory Access enables better efficiency of data. For more info, check how to enable DMA.
  3. The media. Check the following:
    • The disc is clean and unused.
    • The media is recommended by your burner's manufacturer or try a different brand, preferably a name brand, if you continue to have problems.
    • Make sure that media (-R/+R, -/+RW, dual-layer compatibility) is supported by the burner by checking burner's manual or manufacturer's website. This is especially true for some Blu-Ray burners which do not support CD-R/RW media.
  4. If your burner is external, make sure it is connected directly to the computer via USB/Firewire and not a hub or other other device like a sound card.
  5. Update to the latest PX Engine. The PX Engine improves compatibility with newer burners on the market.
  6. A reinstall of the burner's drivers may also help.
    • Windows XP: Go to My Computer and choose Properties.
    • Windows Vista: Go to Start --> Control Panel --> System and Maintenance --> Device Manager.
    • Click on the Hardware tab.
    • Select Device Manager
    • Expand DVD/CD-ROM Drives, then select your burner and uninstall it by right -licking on it.
    • Reboot.
Roxio 6
OrangefoodJSLib.events().registerNativeEvent("mousemove",document.getElementById("rating_img"),highlightRating); OrangefoodJSLib.events().registerNativeEvent("mouseout",document.getElementById("rating_img"),ratingExit); OrangefoodJSLib.events().registerNativeEvent("click",document.getElementById("rating_img"),ratingVote); Article Details ID Number: EE6000132 Products: Easy CD Creator 6.x Platinum Suite
OS: Windows 98 Second Edition
Windows ME
Windows 2000 Professional
Windows XP Home Edition
Windows XP Professional Edition
Issue Roxio does not recognize the blank CD/DVD media in the recorder drive.
Resolution Follow the listed procedure to ensure that the CD/DVD media you are using is supported by your CD/DVD Recorder.
On Easy CD and DVD Creator:
  1. Open Creator Classic.
    1. Launch Roxio Easy CD & DVD Creator 6.
    2. Click on the Creator Classic icon.
  2. Check the supported media types.
    1. Click on Tools on the top left hand corner of the window, then select Drive Properties.
    2. Under the Devices section, click on your CD/DVD Recorder drive.
    3. Under Supported Media, click on down arrow to see a list of supported media your CD/DVD Recorder supports.
    4. Ensure that media type that you are using is listed here. If it is not listed then your CD/DVD Recorder does not support that type of media.
On Easy Media Creator:
  1. Launch Disc Information.
    1. Launch Roxio Creator Home menu.
    2. Click on the Tools tab, then select Disc Information.
    1. Under Supported Media, ensure the media type is listed.
    • Reboot.
I do know if you have Roxio5 you cannot installed Nero 6 InCD, not compatible. Other than all of the above, I have no more suggestions. I am really sorry, wish I could work on your computer to figure out the problem. This is my specialty. Reloading computer and figuring out problems. It is so much easier hands on.
Good Luck
Mar 30, 2008 | Roxio Easy CD & DVD Creator 6...
146 people viewed this tip
David Payne
David Payne
