Tip & How-To about Computers & Internet
ACCESSING HIDDEN THEMES ON WINDOWS 7...!!!!
So looking for some exciting new themes for your Windows 7.....no need to look here & there, its
there hidden in your computer. These themes are particularly based upon certain basic points such as language
& location that you choose when you are installing Windows 7. These location-specific themes are found
in the personalized Menu. Just give a right click on your desktop anywhere and and you can have access to
location that you choose.
Still there are certain other themes as well that you can choose rather than choosing the default ones.
Its very easy to access these hidden themes in your system...wanna know how to access it.....follow the smple steps below:
1) Go to Start Menu
2) Type this in you search box:
C:\Windows\Globalization\MCT.
3) Windows Explorer pops up showing certain locations such as South Africa, Britain, Australia,
Canada etc.
4) Click on your choice & selct the wallpaper that you like, or you can install the full theme.....as you like
5) You can Install the particular theme by just giving it a double click.
6) These Installed themes can be seen in "My Themes" in the "Personalization" Panel
And not to forget there are still some official websites from where you can download loads of
other themes or wallpapers.....But this can be one of the easiest way to access something hidden in
your own system...... So just give it a try.....
Good Luck....!!!!!
Computers & Internet Logo
HOW TO DELETE AERO FROM MY WIN 7 HOME
Windows Aero Glass is Microsoft's 3-D high-end interface for Windows 7. In order to get this interface, you must be running a video card that supports running Aero Glass. Some video cards barely support running Aero Glass and performance suffers and the computer will lag. By simply disabling Aero Glass, you can take a crawling computer and bring new life into it. In any situation, if you want to increase performance, disable Aero Glass.
Right-click on the desktop and select Personalize. Select Windows 7 Basic theme and a "Please Wait" icon appears and changes your theme. Select Windows Classic theme if you are used to a Windows XP look and feel. A "Please Wait" icon appears and changes your theme. http://social.technet.microsoft.com/Forums/en-US/w7itproui/thread/ce96731f-8f7a-4d13-ba9b-7826cb595e3d
Feb 14, 2013 | Computers & Internet
Use hidden international wallpapers and themes in windoes 7 When you first install Windows 7, it asks for your language, time and currency. Based on your responses, it installs a set of wallpapers and themes. If you choose English (United States) for your time and currency format, for example, the available desktop backgrounds and themes will include a United States section with scenery from locations such as Maine, the Southwest and so on. Hidden, though, are background scenery and themes from other English-speaking countries -- Australia, Canada, Great Britain and South Africa. Normally, you can't access those backgrounds or themes, but there is a simple way you can install and use them: 1. In the search box in the Start menu, type C:\Windows\Globalization\MCT and press Enter. (Note: If Windows 7 is installed in a drive other than C:, use that letter instead.) 2. Windows Explorer will launch and show you a list of subfolders under C:\Windows\Globalization\MCT: MCT-AU, MCT-CA, MCT-GB, MCT-US, and MCT-ZA. Each subfolder has wallpapers for a specific country: AU for Australia, CA for Canada, GB for Great Britain, US for the United States, and ZA for South Africa. For any of the countries whose wallpaper and themes you want to use, go into its Theme folder, for example, C:\Windows\Globalization\MCT\MCT-ZA\Theme. Double-click the theme you see there (for example ZA). 3. That will install a shortcut to the theme and wallpapers in the Personalization section of Control Panel. You can now use them as you would any other theme or background, by right-clicking the desktop, choosing Personalize, and choosing a background or theme. They will be listed in their own section.
Jan 12, 2010 | Computers & Internet
is their a program i can download to change my themes for windows 7 starter at first i couldnt change my wallpaper but then i found a program called OC and its possible so i wana know if someone created a program for the theme
Microsoft windows 7 has default 5 theme but Windows 7 beta 1 build 7000 onwards has several hidden & locked themes provided for regional countries such as Australia, Canada, Great Britain, United States and South Africa.Since these hidden themes are installed along with your Windows 7 installation you can unlock/unhide these hidden Windows 7 Themes for regional contries. Below are three deferent methods to get Windows 7 hidden themes.
Screenshot of Default Windows 7 Themeswindows-7-default-themes.jpg Method 1: Steps to Unlock & Unhide Windows 7 hidden locked Themes1. Unhide the Windows 7 System and Protected Operating System files from Windows explorer -> Organize -> Folder and Search Options -> view tab
2. Navigate to C:WindowsGlobalizationMCT.
3. Open a MCT-(AU, CA, GB, US, or ZA) folder for the regional theme that you want.
NOTE: AU, CA and ZA regions all have the same themes though.
4. Open the Theme folder in the selected region folder.
5. Select the .theme file to use it.
NOTE: Once you select a .theme file, Windows 7 will save it so that you will be able to change or select this theme again from within the normal Personalization window location.
6. Hide the Windows 7 System and Protected Operating System files.
7. Enjoy your new regional themes!!
Method 2: Using windows 7 Search (Simplest Method)1. Go to Windowswinsxs Directory
2. Search for *.theme.
winsxs-themes.jpg3. Double click themes with name in the format of XX to apply and save the theme.
Method 3: Registry Entry1. Open notepad and copy past the following lines
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionThemesInstalledThemesMCT]
“%windir%\Globalization\MCT\MCT-AU\Theme\AU.theme”=””
“%windir%\Globalization\MCT\MCT-CA\Theme\CA.theme”=””
“%windir%\Globalization\MCT\MCT-GB\Theme\GB.theme”=””
“%windir%\Globalization\MCT\MCT-US\Theme\US.theme”=””
“%windir%\Globalization\MCT\MCT-ZA\Theme\ZA.theme”=””
[HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionExplorerWallpapersKnownFoldersWindows WallpapersMergeFolders]
“%windir%\Globalization\MCT\MCT-AU\Wallpaper”=””
“%windir%\Globalization\MCT\MCT-CA\Wallpaper”=””
“%windir%\Globalization\MCT\MCT-GB\Wallpaper”=””
“%windir%\Globalization\MCT\MCT-US\Wallpaper”=””
“%windir%\Globalization\MCT\MCT-ZA\Wallpaper”=””
2. Save file as allregional.reg on desktop.
3. Double click on allregional.reg to add above registry entry.
4. Now you can access all Windows 7 Hidden & Locked Themes via right clicking on desktop and personalize settings.
We have created allregional.reg file for you, Download allregional.reg and run it on your machine and access hidden Windows 7 Themes instantly.
Screenshot of Unlocked – Unhide Windows 7 Hidden Themesunlock-unhide-windows-7-hidden-locked-regional-themes.png
Feb 09, 2010 | HP Computers & Internet
177 people viewed this tip
David Payne
David Payne
