Tip & How-To about Cell Phones
Loading Blackberry Desktop Manager in the System Tray
By default, setting up the Blackberry Desktop will cause the Desktop Manager to pre-load full screen each time the computer is started. To pre-load the manager application in the system tray instead, do the following:
  1. Open the desktop manager,
  2. Select the "Options" pull-down from the upper right hand corner.
  3. Check the option to "Hide when Minimized"
  4. Click "START > All Programs > Startup"
  5. Right click the Desktop Manager icon
  6. Select properties
  7. Under the Run option on the general tab pull down and select the word, "minimized"
The desktop manager will now load but only show when the Blackberry device is attached.
Cell Phones Logo
blackberry mobile has error102 on screen
You need to reinstall your device OS to regain access to your device.
Check steps below for OS upgrade -
Before starting make sure that BlackBerry Desktop Software is installed on the computer.
Make sure that you have installed updated device software installed in your PC. Check this link to get update device software from carrier OS download site.
Users can perform a full or selective backup of the data using the Backup and Restore tool in BlackBerry Desktop Manager by completing the following steps:
  1. Connect the BlackBerry device to the computer running BlackBerry Desktop Manager.
  2. Open BlackBerry Desktop Manager.
  3. Double-click Backup and Restore.
  4. Select Backup to perform a full backup or select Advanced to perform a backup of specific databases.
  5. Choose a location to save the backup file, then click Save.
To perform a clean install of the BlackBerry Device Software, perform the following steps:
  1. Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
  2. Double-click the Application Loader icon.
  3. Click Next to start the installation process.
  4. Type your BlackBerry smartphone password, if prompted, and click OK.
  5. Click the check boxes next to the names of the applications you want to load, and then click Next.
  6. Click Advanced, and then click the check box beside Erase all currently installed applications.
  7. Click Next.
  8. Click the check box next to Do not automatically backup the application data during the loading process.
  9. Clear the box next to Backup and restore applications installed wirelessly.
  10. Click Next > Finish.
  11. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager.
Regards
Jun 28, 2011 | RIM BlackBerry Bold 9700 Smartphone
My blackberry 9700 has a white screen with a message saying JUM eRROR 102. Please help me asap
.Open BlackBerry Desktop Manager.
Click Next to start the installation process.Type your BlackBerry smartphone password, if prompted, and click OK.
Click Advanced, and then click the check box beside Erase all currently installed applications.Click Next.
Mar 08, 2011 | RIM BlackBerry Bold 9700 Smartphone
jvm error 547
Here is the procedure to resolve:
Step #1
Step#2
Step#3
Step#4
Click Next.
Jan 18, 2010 | RIM BlackBerry Pearl 8100
Suddenly device went to white screen and JUM Error 545 came up, nothing works, will not reset
Step #1
Step#2
Step#3
Step#4
  7. Click Next.
Hope it helped.
Nov 26, 2009 | RIM BlackBerry Pearl 8100
blackberry flip jvm error 545
To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.5 to 5.0, perform the following steps:
Before proceeding, make sure that the latest version of BlackBerry Device Software is installed on the desktop computer by completing the following steps:
  1. Open BlackBerry Desktop Manager.
  2. Click Help.
  3. Select About Desktop Manager.
  4. Click the Device Software tab.
  5. Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider.
Warning: The following procedure will delete either all data, or applications on the BlackBerry smartphone. Back up the BlackBerry smartphone data before proceeding.
To perform a full backup of the BlackBerry smartphone data complete the following steps:
  1. Connect the BlackBerry smartphone to the computer running BlackBerry Desktop Manager.
  3. Click Backup and Restore.
  4. Select Backup to perform a full backup.
  5. Select a location to save the backup file, and then click Save.
To perform a selective backup for one or more databases perform the following steps:
  4. Click on Advanced.
  5. Select the database(s) on the right side selection window for Device databases.
  6. Select the Arrow that points to the left side of the screen to transfer the database(s) to include in the backup.
  7. Verify the database(s) are on the left side selection window for the Computer databases.
  8. Click on File in the menu located at the top left hand side of the Desktop Manager.
  9. Name the backup file and select a location to save the file.
  10. Click the option to Save once the location for the file is selected.
Once you perform backup procedure, kindly then perform the following steps:
  2. Double-click Application Loader.
  5. Select the check boxes next to the names of the applications to be loaded, and then click Next.
  6. Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications.
  7. Clear the check box next to Backup up device data automatically during the installation process.
  • Click Ok > Next > Finish.
  • When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager.
  • To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.1 to 4.3, complete the steps 1-5 above and then proceed with the following:
    1. Click Advanced , and then select the check boxes beside Erase all application data and Erase all currently installed applications
    2. Click Next.
    3. Select the check box next to Do not automatically backup the application data during the loading process (if prompted).
    4. Clear the check box next to Backup and restore applications installed wirelessly (if prompted).
    5. Click Next > Finish.
    Oct 22, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
    142 people viewed this tip
    Top Cell Phones Experts
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
