Tip & How-To about Computers & Internet
My laptop is running too slow.
Hi.
The most common reason for a computer running slow is insufficient RAM memory.
Check specifications on manufacturer website to find out the kind of memory supported and the maximum RAM allowed.
A computer running Windows Vista should have at least 2 GB to run smoothly.
Increase the RAM, if RAM available is no more than 512MB, then it must be surely and immediately upgraded.
Check also your hard drive free space. If you have less than 1GB free space on hard disk, Windows will have to write continuously virtual memory pages to hard disk, and that will slow down the processing speed. Also check fragmentation. Files pieces may be distributed in different areas of the hard disk, resulting in slower reading speed.
Go to
Start>>Programs>Accessories>System Tools>Disk Defregmenter and do a Defrag of the hard disk if needed.
If you have at least 1 GB RAM on XP or Linux, and 2 GB on Vista, and you took care of your hard drive, then you can check the processes that are starting up automatically and remove the useless one, or spot malaware that can affect speed. You can use a software like Hijack This, and search on google te function of each process started on the list reported by the software.
You can download Hijack this here MajorGeeks | If download does not start, then click at the top of the page, where it says Click Here If It Does Not.
Be careful if you delete the wrong files using this software you can harm the system, and Windows may not work properly.
If you think you have malaware you can also install Spy Bot, and do a system scan. Download Spybot from The home of Spybot.
If all the above does not work, and there is no malaware, then you usually reinstall the system.
Check also the bios settings, BIOS can downgrade the CPU speed on default , even if this is uncommon on recent BIOS.
If a computer is still slow with a fresh system and enough resources then it is one of those rare occasions when you have an hardware fault.
Hardware that can cause slow down is: RAM CPU Motherboard HD Video card.
Some tips on procedure can damage your windows installation. Do not download Hijackthis software and do not change BIOS settings and do not touch hardware unless you are sure of what you are doing.
Computers & Internet Logo
youtube keeps stalling, plays for 20secs then just stops?
YouTube freeze can happen due to many reasons. Major reasons are overload on website, simultaneous running of many programs on your computer, Low RAM, Slow internet connection or corrupt windows registry.
For smooth watching of YouTube Videos take following actions:
1. Watch videos at off peak times, if possible
2. Do not run other programs while watching videos. They slow down computer in general by making use of memory.
3. Add RAM on your computer. More RAM will make easy execution of heavy programs on your system.
4. Get better and speedy internet connection. Talk to your ISP in this regard.
5. Regularly clean windows registry. Windows registry is vital place that stores information for important computing functions. A congested or corrupted windows registry makes computer slow that causes YouTube like freezes. For this, get the best registry cleaner reginout cleaner and optimizer. Use it once in a fortnight for fast computing to avoid YouTube freezes and system slow down.
Jan 19, 2011 | YouTube Videos
i can't turn mute off on you tube
5. Regularly clean windows registry. Windows registry is vital place that stores information for important computing functions. A congested or corrupted windows registry makes computer slow that causes YouTube like freezes. For this, get the best registry cleaner reginout and optimizer. Use it once in a fortnight for fast computing to avoid YouTube freezes and system slow down.
Dec 07, 2010 | YouTube Videos
lenovo n500 3000 display driver problem?
Other than RAM there are also other things to be considered to be able to experience great gaming experience. Commonly the slow and laggy experience are due to insufficient RAM, low video memory, internet connction if your playing online,disk space and processor. And no its nor a driver issue. The best way is to solve this is to check the recommended "system requirements" of the games your playing. If all requirements are met i'm pretty sure you'll be able to play games smoothly. good luck!
Aug 24, 2009 | Lenovo 3000 N500 Notebook
low memory slow running video/audio programs host process stop working
The most common reason for slow processing speed is insufficient RAM memory.
Increase the RAM, if RAM available is no more than 512MB, then it must be upgraded.
Check also your hard drive state. If you have less than 1GB free, that will slow down the system. Go to Start>>Programs>Accessories>System Tools>Disk Defregmenter and do a Defrag of the hard disk.
If you have at least 1 GB RAM, and you took care of the hard drive, then you can check the process starting up on their own and remove the useless one, or spot mala-ware that can affect speed. You can use a software like Hijack This, and search on google te function of each process started on the list reported by the software.
May 17, 2009 | Acer Aspire 5520-5908 Notebook
my computer is low
Improve your coputer by up grading.
What type of PC you have.Tell me i will then tell you the solution
Nov 20, 2008 | Ahead Software Nero 6.0 (60045) for PC
917 people viewed this tip
David Payne
David Payne
