Tip & How-To about Vacuums
Irobot, Dirt Dog, Scooba
By now I bet most of you have seen one of these.
They clean your carpet and don't complain about a paycheck.
They scrub your floors and they clean your shop, and some of them even do it on a schedule, while others clean out your rain gutters, and the expensive ones clean your pool!
Well guess what?
They all have pretty much the same brain.
Know what that means to you?
They can ALL clean on a predetermined schedule!
Yes Irobot sells a Roomba called a scheduler which has a remote control, but they can all be programmed with that same remote control to clean at any time you desire, 7 days a week, once a day. The real beauty of this though is that you can buy that remote on Ebay for pretty cheap.
The only thing you have to remember is to set them to different times and feed those times in separately. You MUST have the Irobot turned on prior to sending it a schedule, otherwise you wont hear a confirmation tone.
Lets say you want the Dirt Dog to clean up a pretty nasty floor before the Roomba does it's thing. You set the day, lets make it Wednesday.
Now you set the scheduler on the remote control pad so the Irobot runs when you're asleep.
The average Dirt Dog runs 45 minutes to an hour, so we set it for midnight.
Then we set the Roomba for 1am. For each time we set for each device there will have to be a code sent and recorded by the device itself, which wil be followed by a short confirmation tone.
Remember that before you send a new schedule to a different robot, you will have to erase or modify the old schedule recorded in the remote control. The schedule doesn't need to be present on the remote control for the Irobot to run on time. Once the schedule has been sent and the confirmation tone has sounded, nothing else needs to be done for the Irobot to do it's job, so you can safely wipe the previous schedule and set a new one, then send that schedule to another Irobot.
When the Remote Control sends a code, it effectively sets the clock on the Irobot, then tells it when to run according to that clock.
Now lets say you want the kitchen floors scrubbed every wednesday, but you dont want the Scooba bumping into either the Dirt Dog or the Roomba.
The solution is to set it to run at 2am.
The end result is a very clean floor that even your toddler can safely play on. Lets also remember that the very same remote control you use to set those schedules can also be used to guide and control the Irobot much like you would a remote controlled toy car. SO, if you have a party and someone spills a drink, you can simply guide the Scooba to that spot and have it wash and wet-vac the area.
That's my Tip for the Day
Bob S.
Vacuums Logo
my hoover spin scrub has no suction wont pick up water why?
No suction means somewhere in the intake side of the system you have either a blockage or an air leak.
Jan 21, 2015 | Hoover Brand New SteamVac Spin Scrub...
Carpet cleaning
Carpet shampoo is popular way to clean your carpets. There are many different brands of carpet shampoo, so make sure that you follow the guidance on the label.
  1. Make up the solution as directed on the packaging. In many cases, the product will need to be diluted with water.
  2. Use just enough carpet shampoo to cover the area.
  3. Do not make the carpet too wet - not only is this a waste of detergent, but it's also going to increase drying time.
  4. Scrub on the particularly stubborn areas using a hard-bristled brush.
  5. Let the carpet dry.
  6. Vacuum the shampoo once it has dried.
Carpets and floor cleaning
May 17, 2013 | Vacuums
where do i put the clean water at and the cleaning solutions
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=695898
Generic problem for all Vacuums
Where do I put the
Posted by nichole171 on Jun 22, 2008
Where do I put the clean water at and the cleaning solutions
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I am not sure what type or brand name for the type of scrubbing unit you have , but the clean water and the cleaning solution generally go into the same container and then it will release onto the carpet or floor.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 22, 2008 | Vacuums
Hoover SteamVac Deluxe
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=624426
Posted by providence51 on May 26, 2008
My cleaner is not dispensing the shampoo solution. Still sucks up the dirty water that I manually applied with a scrub brush. I use this on my tiled screen porch floor and it has worked great many times.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac Carpet / Upholstery Deep Carpet Cleaner.
There is a release value in the bottom the holding tank that may be bad and not opening or the trigger assm in the handle may be broken and not connecting to release the water to scrub and clean the carpets. You should really check with your local factory authorized Hoover vac dealer in your area or , please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
May 26, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Changing from carpet cleaning to hard floor cleaniang
If you are looking to floor cleaner then don't go anywhere, Our experts helps you to clean your floor and the best thing is that you are never feeling regret after taking our services.
Taking fast services call us anytime 3105441028.
Commercial Floor Cleaning Services Waxing Los Angeles CleanerImage
Apr 23, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
207 people viewed this tip
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
