Tip & How-To about Computers & Internet
How to Maintain your PC in simple steps
shut down your pc if you are using just for home purpose... dont keep it in Hibernate/Sleep mode... always have an antivirus software installed on the pc and please dont install more than one security software it will make your computer accessbility slow.... try running CCleaner or Disk cleanup each week ... try staying away from downloading any free software and
specially which is for cleanning up/ repairing your pc files ....
Computers & Internet Logo
My LG optimus keeps getting stuck in sleep mode. When I turn it on it seems fine but once it enters sleep mode it won't turn back on. I have to restart the phone to get a picture again. Any tips?
Is it ''sleep'' mode or ''Hibernate'' mode? If ''Hibernate'', then that is the problem. Turn off ''hibernate.'' If it is in fact just ''sleep'' mode, check to see if it is set for ''enter password to exit sleep'' _and_ you don't have a password set up... then either create a password or set it so that it does not require a password upon exiting sleep. Also, you can always resort to resetting everything to ''default'' settings. (This will not effect any data on the phone, and you can take your time setting all the settings ''just right'').
Jan 02, 2015 | LG Cell Phones
VPCSA does not properly go to sleep / hibernate
My advice is to shut down and unplug the Laptop when not in use. Set the Power Options to High Performance, set Sleep and Hibernate to never, adjust your Advanced Power to shut down when lid is closed. A reboot everyday resets the computer and IF there is a Power Surge your Laptop will not get fried. If left plugged in the battery COULD malfunction and become a fire hazard. Not to mention the unnecessary power applied to components and shortening their lifespan.
May 08, 2013 | Computers & Internet
Gateway MT6707 shutdown problem
Open the Control Panel, select Power Options, select High Performance, select Change Plan Settings, Under Plugged In, set time to Turn Off Display, set Put the Computer to Sleep to Never, select Change Advanced Power Settings, scroll through the settings , click on the + at Power buttons and Lid, set to shut down, Sleep and Hibernate to Never, adjust the rest to your preference. When you are not using the Laptop ALWAYS shut down and unplug to prevent damage due to power surges.
Apr 03, 2013 | Gateway Computers & Internet
cant get power saving mode off
Step 1:
Sleep Mode b> Sleep mode is primarily used with home computers (desktop computers). Sleep mode is designed to save the current work, programs, and settings of your computer using your computers memory, while using very little power. b> Hibernate Mode b> Hibernate mode is primarily used with laptop's. Hibernate mode is designed to save your computers current state on to the hard disk, then turn off your computer to stop using power completely. This mode is usually used when you do not plan on using your laptop for an extended amount of time. Benefits b> Using Hibernate mode is more power-efficient, but files may become fragmented over time by using this mode frequently. Sleep mode does consume more power, but the advantage that Sleep mode has over Hibernate is that it does not take as long to resume your computers former state when you are ready to continue using it.
Feb 23, 2013 | Lenovo 3000 Computers & Internet
I have winows vista and it takes a few minutes for my pc to shut down and startup how can i get it to shut down and start up faster
Forget it, it takes what it takes. There is an idea of an external drive, that can be rigged that helps, but It is a waste of resoruces.
Consider using sleep mode, for faster cycling and only shutdown when you actually need to. If this is a laptop, consider hibernate. Both sleep and hibernate focus on faster start ups, but on laptop, if you use sleep and run out of battery, you can loose data that you were working on. ALWAY save and backup.
Oct 15, 2010 | Computers & Internet
172 people viewed this tip
David Payne
David Payne
