Tip & How-To about Computers & Internet
What are drivers?
Drivers are small software programs that help control devices attached to your computer because drivers enable your operating system and other software to communicate with various hardware devices, controllers, and other peripherals. In other words, drivers work as instruction manuals that provide software with the information with regard to controlling and communicating with different hardware devices.
Why do we need drivers? Drivers help computers identify and run installed hardware. A device driver is a code that an operating system uses to control disk devices, display adapters, input devices such as a mouse or trackball, modems, fax machines, printers, and other hardware. Without drivers, computers will not be able to distinguish between a sound card and a modem. Most computer devices and peripherals need drivers to run, which means that computer accessories, such as printers, scanners and digital cameras also need drivers to function. This is what all computer hardware and accessories that are purchased come with drivers stored in either a floppy disk or a CD. A computer automatically loads the drivers when these disks are inserted in their respective drives.
Like any other software, drivers are upgraded and updated by the manufacturers to remove bugs, add extra functionality to the hardware or to improve the performance of the device. Unless you update your drivers regularly you may face problems ranging from the relatively minor, such as having hardware that seems to perform poorly, to the more major problems such as hardware failure, hardware conflicts and complete system crashes.
Choosing and installing the correct device drivers for a given hardware is often a key component of computer system configuration.
Where you can get Drivers? Drivers can also be downloaded from the websites of hardware manufacturers. You can download the most recent or updated drivers for your hardware. You can do this by navigating through each manufacturer’s website and searching for the page that allows you to download drivers for their products. However, there are some software (ex. Driver Robot) that automatically scans your computer, looks for the drivers you need, and automatically installs them to your computer. These kinds of software are very easy to use and they can ensure that you will have the most up-to-date drivers for your devices.
Computers & Internet Logo
on what basis system drivers are compatible ?
Device drivers are needed to communicate with a hardware device within a computer. A computer program, such as the operating system, sends an instruction to an device driver, which then tells the hardware device what to do. Operating systems typically contain drivers for all types of hardware devices, but they are mostly generic. Finding the drivers that are needed by a computer can be done by finding the type of hardware being used and updating or installing software.
Go into the computer's BIOS to view installed hardware. When starting the computer, press the F2 key or Delete to enter the BIOS. The BIOS will display the type of hard drive as well as the type of CD/DVD drive that is installed in the system. Look in the Device Manager within Windows to see the hardware devices that are installed. Double-click on the "System" icon within the Control Panel and then go to the "Hardware" tab. Click on the "Device Manager" button to see a list of devices that are installed and used by the operating system. Check Windows Update for available updates to on-board hardware devices. Hardware components, such as a video controller and audio controller, can have an updated driver that can be downloaded and installed from Windows Update. Use the installation CD that came with the hardware device. The setup program will install the software and drivers that are needed to use the device. Refer to the manual that came with the computer or hardware component. The manual will list the model number of the device as well as the website of the manufacturer. Visit the manufacturer's website for a hardware device that is installed on the system. Updated drivers to devices are available from a manufacturer to correct problems and to add additional functionality to a device. The site can also be used to find drivers for hardware if the manufacturer is no longer in business.
b>
May 03, 2012 | Microsoft Computers & Internet
i have lost my mother cd and after format i m unable listen sound
After a fresh install of an operating system you have to set up your sound again
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
if you dont have a motherboard disc you will have to download the drivers
click start control panel administrive tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
if you dont have a disk with the drivers you will have to download them
http://www.boxdrivers.com
using this link you will be able select your drivers
http://download.cnet.com/Realtek-AC-97-Driver-Windows-98-Me-2000-XP-2003/3000-2120_4-10238712.html
Realtek AC'97 Drivers & Applications. The package includes: Driver/Application Setup Program; RtlRack for Win98/Me/2000/XP and AvRack for Win95/NT4; Realtek Sound Effect Manager. DirectX 8 is required to enable advanced features.
http://download.cnet.com/Realtek-AC-97-Driver-Windows-Vista-Windows-7/3000-2120_4-10962344.html
http://download.cnet.com/Realtek-High-Definition-Audio-Codec-Windows-Vista-Windows-7-32-bit/3000-2120_4-10788600.html free sound drivers
Realtek HD audio driver package. The package includes: driver setup program, drivers for Vista 32-bitedition.
if these arent right you will find free sound drivers
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
(be precise)but don't use numbers or / - also the download software finder under that there will be a list place a tick in the box of any one you want/need
hope this help you
Sep 16, 2011 | Asrock 775i65G Motherboard
the problem with sound (cod 10 error). compaq nx7010
A Code 10 error usually occurs due to:
  • Missing device driver
  • Malfunctioning device driver
  • Incomplete device driver files
If the device due to which the error has occurred contains the value FailReasonString in its hardware key, then this string is displayed as an error message. Otherwise, the device displays the following error message:
This device is either not present, not working properly, or does not have all the drivers installed. (Code 10)
Most of the time, you can resolve this error by updating the device driver for the faulty device. To update the driver, select the System option from the Control Panel. In the System Properties dialog box, select the Hardware tab, and then select the Device Manager button. Scroll through the Device Manager window and identify the faulty hardware device. Right-click on this device and then select the Update Driver command. Next, follow the screen instructions to update the driver of the selected device.
Causes of System Errors
System Errors Usually Occur due to:
  • Device driver conflicts
  • Corrupt or damaged software files
  • Malfunctioning hardware
  • Corrupt or damaged system registry
  • Virus or spyware infection
Steps to Prevent System Errors
With a little vigilance and extra precaution you can easily prevent most system errors. Some of the tasks that you can perform to prevent system errors are listed below:
  • Keep your operating system, device drivers, and software applications updated with the latest hot fixes, security releases, and updates.
  • Run regular antivirus and anti spyware scans to keep your PC free from harmful and disastrous malware. Always keep these software updated with the latest security releases so that your system is always protected against malware infections.
  • Avoid opening attachments of unsolicited emails and visiting dubious websites.
  • Do not download freeware and shareware from websites whose authenticity you aren't sure of.
  • Be very careful while downloading ActiveX controls from various websites. ActiveX controls provide their master with complete control over your system and therefore, a malicious ActiveX control can cause severe damage to your system and may also enable a hacker to steal your personal information.
  • Last but not least, perform regular registry maintenance to ensure that your registry is free from errors. 90% of all system errors are connected to the system registry in one way or another. You can easily perform registry maintenance with the help of a registry cleaner such as RegGenie. This software will provide you with a simple-to-use graphical interface and enable you to scan and clean registry errors in just a few mouse clicks.
System errors are common on Windows systems and can occur due to a number of reasons, including problems with device drivers, hardware, software applications, and the system registry. Code 10 is one such system error that occurs due to problems with a device driver. You can fix this error by updating the faulty device driver. Preventive maintenance with the help of antivirus software, registry cleaners, and a certain amount of vigilance while working on the Internet can help you keep your PC free from system errors.
Additional Recommendations...
Driver Update: Many errors are related to driver problems such as obsolete, outdated or incompatible drivers. A driver update tool is recommended to scan your system for corrupted and outdated drivers and to ensure that all your drivers stay up-to-date.
Jan 15, 2011 | HP Compaq JBL Pro (401508-001) Computer...
what is the drivers
Drivers are software programs written by a device manufacturer for components (such as a sound or video card) which, when executed, enable the device to communicate with your operating system. Most components come with a driver CD that enable you to install the drivers on your hand drive per the manufacturer's instructions.
If you find this information to be helpful to you, please rate my response to you on the FixYa website.
Nov 28, 2010 | Computers & Internet
283 people viewed this tip
David Payne
David Payne
