Tip & How-To about Cell Phones
How to jailbreak iphone 3g 3.1.2 firmware with blackRa1n
Step 1: Update iTunes to the latest version available and reboot your computer.
Step 2: Download BlackRa1n from our iPhone downloads page and install it, then reboot your PC (note that rebooting is not necessary but I always do this as a precaution).
Step 3: Plug your iPhone to your computer and launch BlackRa1n. Click on “make it ra1n”.
Step 4: Your iPhone will now enter recovery mode. The regular recovery mode image on your iPhone will be replaced by a picture of GeoHot.
Step 5: BlackRa1n will run on your iPhone and then it will reboot.
A pop up will show up asking you to donate. If you successfully jailbreak your iPhone, I suggest you send $5 or $10 to GeoHot.
Step 6: Once your iPhone reboots, you will notice a new icon on your springboard. This is BlackRa1n. Now make sure you have internet connection and launch BlackRa1n on your iPhone.
Step 7: Choose what installer applications you want to install on your iPhone and then tap “Install”. I suggest only installing Cydia but you may install them all if you want to.
BlackRa1n will download and install the selected applications.
Step 8: Once done installing, your iPhone will respring and you should see your installer app on your springboard.
Step 9: Once your installer app (Cydia in our case) is installed. You can safely uninstall BlackRa1n by launching the app and selecting “uninstall balckra1n”.
Step 10: Reboot your iPhone. You’re done!
Cell Phones Logo
DISABLED OR BLOCKED IPHONEA1303 16GB
You can enable or activate your phone without Restoring or Loosing data.Please follow this procedure...
* Open iTunes.You can check your iTunes version by clicking "iTunes" in the menu bar and then clicking "About iTunes."
If you don't have itunes yet,download the highlighted keys below.
DOWNLOAD ITUNES
* Make sure you have the Blackra1n jailbreak tool on your desktop. download the link below
BLACKRAIN FOR WINDOWS
BLACKRAIN FOR MAC
* Attach your iPhone to a USB port on your computer by using the iPhone data cable. Open the Blackra1n tool and then click in the middle of the box where it says, "Make it Rain." Now perform a hard reboot on your iPhone.
To perform a hard reboot, simultaneously, press the iPhone on/off button located on the top right of your iPhone and the "Select" button centered on the bottom of the iPhone below the screen. Hold down both buttons for approximately 60 seconds. Your screen will go black. Then you will see the apple logo. Then your screen will go black again. After about 60 seconds, you will see the normal iPhone reboot screen, which shows the iTunes logo and a picture of a USB data cable.
Release both buttons and you will see the Blackra1n reset screen which looks like a picture of a teenage boy surrounded by iPhone images. Your iPhone should now be fully functional and no longer disabled.
Good Luck...
Aug 04, 2011 | Apple iPhone (16 GB) Smartphone
how to solve if my iphone 3G cannot be on, it stuck at the apple screen?
  • The quickest way to fix your iPhone 3G is to sync it to a different computer. When you do this the computer will recognize it as a new device and install the software on it like it's never been used before, that said everything you have on it is gone. It may take a while so be patient.
  • 2 If step one is successful you can sync it to your computer. It will recognize that it is synced with another computer and ask you if you want to sync it to this one; go ahead and do it. This may take a while too because you will install the applications, songs, data, etc. you had on it before.
    WARNING! DO NOT DISCONNECT YOUR IPHONE 3G WHILE SYNC IS IN PROGRESS OR ELSE YOU WILL BE STUCK IN RESTORE MODE AGAIN!
  • 3 If steps 1 and 2 did not work or you do not have another computer to sync it with the following steps will help.
  • 4 Backup your music, videos, and applications. Typically it would be the iTunes folder in the My Music folder. This is a precautionary step to the following steps to come, your music should be unaffected but stranger things have happened.
  • 5 Uninstall iTunes, Quicktime, and other Apple component software from your computer. Follow the steps listed on the Apple Support page, "Removing iTunes, QuickTime, and other software components for Windows XP" the link is available in the resources section. Restart your computer when done.
  • 6 To be sure everything is uninstalled completely run the Windows Installer CleanUp Utility. This program removes remnants of uninstalled programs from your registry and deletes files that the uninstall fail to catch. You can download and read more about this program from the Microsoft Help and Support Page, "Description of the Windows Installer CleanUp Utility" the link is available in the resources section. Restart your computer.
  • 7 If you have a registry cleanup utility like Registry Mechanic or CCleaner run the program and restart your computer. It is sad to say but the Windows Installer CleanUp Utility may not catch everything so having a secondary cleaner could be essential.
  • 8 Install the latest version of iTunes. Currently iTunes 8 is the latest, it could change tomorrow so download it from Apple.com. Restart your computer.
  • 9 Open iTunes and connect your iPhone 3G. It may take a while for it to recognize the phone, be patient. Once iTunes recognizes your phone it will prompt you to download the latest iPhone software, the current version is 2.1. Follow the installation instructions in the Apple iPhone - Software Update page, the link is available in the resources section.
  • 10 Hopefully these steps helped you recover your iPhone 3G. It is possible that even after a successful recovery your phone may revert back to being stuck. In my experience I was able to save my iPhone 3G from restore mode but when I downloaded the software update it got stuck again, luckily steps 1 and 2 fixed it.
  • Oct 06, 2010 | Apple iPhone 3G
    Got unlocked iphone, tried to restore factory settings now its stuck on bitten pineapple...any help plz just got this phone?
    Here u can follow the steps
    Step 1: Make sure you have downloaded the latest version of iTunes if you haven’t already. Download iTunes 8.2 from the link given below.
    Step 2: Now connect your iPhone with your PC. You must connect it to a single usb port on the backside of your computer. Do not use any usb hub or the ports in the front as this could cause an error during update process.
    Step 3: Start iTunes 8.2. Sync your iPhone with your PC so that iTunes backs-up all your important data including settings, apps, music, contacts and photos.
    Step 4: You will now have to download a custom cooked firmware for your iPhone version (2G or 3G). I can’t post the download links for these files for the reasons you all know very well. Just Google “iPhone 2G Custom 3.0” (If you are using iPhone 2G) or “iPhone 3G Custom 3.0” (If you are using iPhone 3G) and use one of the torrent links to download the custom created .ipsw file.
    Step 5: Once you have downloaded the required .ipsw file, Copy/Paste it into this location:
    “C:\Users\[username]\AppData\Roaming\Apple Computer\iTunes\iPhone Software Updates\” (Windows 7)
    “C:\Users\[username]\AppData\Roaming\Apple Computer\iTunes\iPhone Software Updates\” (Windows Vista)
    “C:\Documents and Settings\[username]\Application Data\Apple Computer\iTunes\iPhone Software Update\” (Windows XP)
    Step 6: Restart iTunes. You will now be prompted to install this firmware you just download. Just close this prompt dialog by clicking on “x” from the top right-most corner of the window.
    Step 7: Now you will have to restore your iPhone to this custom firmware 3.0 that you just downloaded. Click on your phone from the sidebar in iTunes to get to this screen as shown in the screenshot below:
    Now press and hold left “Shift” button on the keyboard and then click on “Restore” (Not “Update) button in the iTunes and then release the “Shift” button.
    This will make iTunes prompt you to select the location for your downloaded custom firmware 3.0. Select the downloaded .ipsw file and click on “Open”.
    Step 8: Now sit back and enjoy as iTunes does the rest for you. This will involve a series of automated steps some of which are highlighted below:
    Don’t do anything silly at this point. Just wait while iTunes installs the new firmware 3.0 on your iPhone. Your iPhone screen at this point will be showing a progress bar indicating installation progress. After the installation is done, iPhone will restart automatically and you should now have a fully unlocked and jailbroken iPhone 2G. iPhone 3G on the hand will only be jailbroken, not unlocked. iPhone 3G users will have to wait for Dev-Team to release ultrasn0w on Cydia in order to unlock their phones.
    Step 9: Once you are done with the unlocking and jailbreak process. You can now restore all your settings, apps, music, contacts and photos to the newly installed firmware version 3.0 by restoring the backup that you made in Step 3 from iTunes.
    Feel free to ask me any question here should you run into any problem during the update process.
    Disclaimer: This guide is for testing & educational purposes only. I’m not responsible for any loss of important data or malfunctioning of your iPhone.
    Download Links:
    Download iTunes 8.2
    Download iPhone OS 3.0 Custom Firmware (iPhone 2G) [Screenshot]
    Download iPhone OS 3.0 Custom Firmware (iPhone 3G) [Screenshot]
    /**/ Thanks
    Thiru
    Jun 20, 2009 | Apple iPhone Smartphone
    computer shuts down when connecting iphone
    Try the latest itunes:
    http://www.apple.com/ipod/download/
    - Quit iTunes if it's currently open.
    - Visit Apple Downloads to see if there are newer versions of iPod Updater (this contains software for all models of iPod) and iTunes than what's installed on your computer.
    - If there are newer updates available, download the Windows versions of the updates, then run the installers on your computer to install the updates.
    - When it's finished, iTunes will already be updated, but you'll need to run the iPod Updater to update your iPod, so connect your iPod to your computer.
    - On the Start menu, point to All Programs, point to iPod, point to iPod Updater, then click the latest iPod Updater.
    - Click the Update button to update the software on your iPod (if the Update button appears unavailable, your iPod is already up to date).
    If it still fails, remove the automatic restart from windows:
    Go to Start -> Control Panel -> System
    Go to Advanced
    Under the Startup and Recovery section, click Settings...
    Under System Failure un-check "Automatically restart"
    Feb 11, 2009 | Apple iPhone Smartphone
    178 people viewed this tip
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
