Tip & How-To about Washing Machines
Washing machine won't drain, pump stuck
If your washing machine won't drain and, the pump appears to be stuck:
Go to an autoparts store and, buy a radiator locking hose pinch off plier. Then: unplug the washer (remove all power) bail out all the water with a cup or, bowl; remove the washer cabinet or, tilt back the washer against a wall so that you can access the pump from underneath the front; pinch off the tub to pump hose; lock the plier, place a towel under the pump; remove all screws on the pump cover; remove the blockage from the pump and, reattach the pump cover. remove the pliers and, test the washer. (if you can acces the pump from the front (like a front load washer) you do not need to bail out the water as, the pliers will hold the water in the tub, so that only a small amount of water will come out when you open the pump.)
Washing Machines Logo
won't drain
Go to an autoparts store and, buy a radiator locking hose pinch off plier. bail out all the water with a cup or, bowl; remove the washer cabinet or, tilt back the washer against a wall so that you can access the pump; pinch off the tub to pump hose; lock the plier, place a towel under the pump; remove all screws on the pump cover; remove the blockage from the pump and, reattach the pump cover. remove the pliers and, test the washer. (if you can acces the pump from the front you do not need to bail out the water as, the pliers will hold the water in the tub.)
Apr 07, 2010 | Maytag Neptune MAH5500B Front Load Washer
stopped in mid cycle. Lights on panel flashing and says "PF"
You have a "drain waterpump fault" To fix this the pump must be dis-assembled and, the obstruction blocking the pump impeller must be removed. First obtain a radiator hose pinch-off plier and, a hoseclamp plier from an autoparts store; place the hose plier on the pump hose just below the tub and/or, just above the pump. squeeze the plier until it locks closed; this will pervent the water in the tub from draining when you remove the pump cover. using a screwdriver open the pump and, remove the obstruction in the pump: be sure to cover the floor under the pump, with rags to catch any water still left in the pump.
Jun 09, 2009 | Washing Machines
shows f2 error code wont drain or spin
Jun 09, 2009 | Whirlpool GHW9100L Front Load Washer
water won't spin out of clothes
Jun 09, 2009 | Frigidaire ATF6000ES Front Load Washer
wont drain tank
HI, this is a sure bet that the impeller in the pump housing is damaged. that sound you are hearing is the impeller. the drive shaft has stripped the impeller. You will need to replace this damaged pump asap if possible.
Jun 01, 2009 | Kenmore Washing Machines
429 people viewed this tip
Top Washing Machines Experts
