Tip & How-To about Office Equipment & Supplies
Xerox system error
If you are using a Xerox printer, you might have faced a system error problem, similar to "System error 09.038.46:113334" or something within that line.
I faced a similar error message like this a few months ago and i solved it using the following steps.
The ink count sensor flags were stuck.
Verify that the ink is correct and genuine and then reset the system and error message by performing the following steps:
1- Turn on the printer
2- Wait for the xerox logo to begin moving across the display
3- Before the logo is centered on the display (stops moving) press and hold the "back" and "help" buttons on the control panel.
4- Hold both buttons until the display reads "beginning service mode initialization".Release the buttons and the printer reboots into service mode with the "Service Diagnostics" menu displayed
5- Then scroll until you find function menu then click "OK"
6- Scroll until you find "Clear ISC" fault and press "OK"
7- Click back several times and then reboot the machine.
If you follow these exact steps your problem should be solved.
Thank you for using Fixya,
Kenneth.
13387.48:16806 error code on Xerox Workcenter C2424
From the Xerox Solution center --
Solutions for : Fault Codes 13,XXX.4X: Thermal Error Related Fault Codes: 13,xxx.4x Solutions ranked by relevance:
  1. Make Sure the Room Temperature is Within Operating Temperature Specifications
  2. Make Sure the Power Source is Not Causing the Behavior
A previous firm I worked at had these units. Do not plug them into a surge protector of backup power supply system.
Mar 22, 2011 | Office Equipment & Supplies
xerox C2424 system error 0701043:29778
Try some cleaning to your Printer.......
also check for any stuck in the printer
Mar 19, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Eror code 3-380 System Fault problem
Whenever switchon my Dc12 The mahinc ready within 5 minutes and final stage it shows the eror like "System Fault" error code 3 -380 Switch of your printer and on. How can I solve it.
Oct 15, 2008 | Xerox DocuColor 12 Color Copier
System Error
That is an X axis pivot fault of the print head. You have a 1 year on site warranty with that machine.
Call 1-800-835-6100 have your serial number available.
That is not something you can take care of easily.
Sep 23, 2008 | Xerox Phaser 8560MFP Laser Printer
187 people viewed this tip
jasbo
jasbo
