Tip & How-To about Computers & Internet
How to fix a computer which is infected with viruses, malwares, spywares
In order to remove viruses, malwares, trojans, from the computer, follow the instructions given below.
1. Delete all of the temporary files.
a. Click Start, Click Run(Window XP) and type temp(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required), Click Edit at the top in the menu bar, click Select All, Right Click on Mouse and hit Delete. This would delete all of the temporary files.Note:in Window Vista and Window 7, Menu bar would appear by hitting Alt key.
b. Click Start, Click Run(Window XP) and type %temp%(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner, once you click Start), hit Enter, (hit Continue if required), Click Edit at the top in the menu bar, click Select All, Right Click on Mouse and hit Delete. This would delete all of the temporary files.
c.Click Start, Click Run(Window XP) and type prefetch(Window Vista and Window 7-type in the Start Search box which appears at the botton left hand side corner,once you click Start), hit Enter, (hit Continue if required), Click Edit at the top in the menu bar, click Select All, Right Click on Mouse and hit Delete. This would delete all of the temporary files.
2.Run Disk Cleanup to free up wasted space.Click Start, click My Computer, right click C drive and click Properties. Now, click Disk Cleanup. It will delete all of the useless temporary files.If it ask to click Next, click Next.
3.Scan your computer by using one of the antimalware, antispywares.Restart your computer in safe mode with networking.(As soon as you restart the computer, start tapping F8 and choose Safe mode with networking and hit Enter.)Use the link below to install antimalwares, antispywares .
http://siri.geekstogo.com/SmitfraudFix.php
http://malwarebytes.org/
http://superantispyware.com
http://www.simplysup.com/tremover/download.html
4.Stop Programs from running at the startup.As soon as you restart the computer a number of programs load themselves at the startup and you will be able to see them at the bottom right-hand side corner. In order to stop some of the programs (except security software and programs which you use immediately after starting up your computer) to load itself automatically, please follow these steps.Click Start, Click Run(Window XP) and type msconfig(Window Vista and Window 7-type in the Start Search box which appears at the botton once you click Start),hit Enter, (hit Continue if required)
You will see System Configuration Utility. Click Startup at the top right hand side corner.
Now,uncheck the items which you want to stop to load automatically.Now, click Apply and then click OK or Close. Click 'Exit without restart'Now, you have to delete the startup from registry.Click Start, Click Run(Window XP) and type regedit(Window Vista and Window 7-type in the Start Search box
if required),.Now, scroll up to the top and click Computer, rigth-click it and click Export and save it as file name say backup on the desktop.In order to remove startup from the registry go the followinglocations:
HKEY_LOCAL_MACHINESOFTWAREMicrosoftSharedToolsMSConfigstartupfolderRight
click startupfolder and click Delete.
HKEY_LOCAL_MACHINESOFTWAREMicrosoftShared ToolsMSConfigstartupreg
Right click startupreg and click Delete.Restart your computer.
5.Uninstall the useless programs(unnecessary toolbars like my web search,smileys,myfreeze toolbar). Click Start, click Control Panel, Click Add or Remove programs(Programs and Features or Programs in
Window Vista and Window 7),you will see a list of the programs. Click on the programs, you want to uninstall and click Remove(Uninstall in Window Vista and Window 7).
6. optiize and reset internet explorer.Close all of the window, click Start, click Internet explorer, click Tools, Click Internet Options.Now,on the Internet Explorer properties window under General Tab, click Delete and then click Delete All. Now,click Advanced on the top right hand corner.click reset. click Apply and OK.
7.Update your antivirus, antimalware, antispyware program.
8.Update WindowsWindows XP:Click Start, click Control Panel,Click Performance and Maintenance, Click System, click
Automatic Updates tabclick Turn automatic updating on and click install updates.Windows Vista:Click Start, click Control Panel, click System and Maintenance,click Windows
Update,click Turn automatic updating on and click install updates.
Computers & Internet Logo
my loptop is so slow and how can i fix the error
Hi aljon toyo
Your computer running slow could be indicating a virus,trojan,worm,or other malware and also just too many old program and files.
To speed up your computer do the following in order.
1...Clean up your Disk: Click on Start>All Programs>Accessories>System Tools>Disk Cleanup.Click on the files you want to get rid of here.
2...Defragment your Hard drive: Start>All Programs>Accessories>System Tools>Disk Defragmenter
3...Delete old files, programs,pictures, etc that you don't use anymore...this will free up hard disk space.
4...Install and Run Microsoft Safety Scanner...
Go to the following website and download,install and run the FREE Microsoft Safety Scanner.
It will remove the virus,trojans,worms,etc from your computer.
It may take quite a while to finish, it all depends on the size of your hard drive.
Once the Microsoft Safety Scanner is completed running, it should have removed the virus,trojan,worm,etc. from you computer, but if it didn't remove the virus,trojan,worm,etc from your computer then it will give you an option to connect (real time) with a Microsoft professional (FREE) and he will take over control of your computer (with you permission) and finish the removal process.
Please take time to rate me thumbs up
http://www.microsoft.com/security/scanner/en-ca/default.aspx
Sep 24, 2011 | IBM ThinkPad T30 2366 Notebook
trojan virus promblem after open *** webside
Follow the given instructions to remove Trojan Virus from your PC.
1. Launch an antivirus program that you should have installed on your computer, such as Symantec's Norton or McAfee. Wait for the program's window to appear, then go to "Disk View." Highlight your computer, then select "Scan/Repair" so that the antivirus can detect the Trojan and trash it.
2. Exit the antivirus program on your Mac. Restart your computer again to ensure that the Trojan has been deleted. Empty the trash can on your computer once it is back up and running.
3. Disable the System Restore feature if you're a Windows user. Go to "Start" at the bottom of your screen, then right-click the "My Computer" icon to go to "Properties." Check "Turn off System Restore" under the System Restore tab in the "Properties" window, then select "Apply." Confirm that you want to disable System Restore by clicking "Yes" and "OK."
4. Update your virus definitions in your antivirus program. Open the program, or go to the website, to download the latest definitions so that you can receive the most recent alerts and keep your computer protected.
5. Scan your files to detect the Trojan file. Follow the instructions in your antivirus program to delete any suspicious files. You may want to write down the path and file name of the Trojan, which is usually found in the "C:\" hard drive. Then, edit your computer's backup registry by choosing "Start," then "Run." Type "regedit" in the window that appears and click "OK."
6. Search for the registry entry from which the Trojan derived, which may begin with "HKEY" followed by the file path. Delete the registry entry to ensure that the Trojan is removed. Exit the registry entry, and restart your computer so that the changes can take effect.
Dec 24, 2010 | Webroot AntiVirus with AntiSpyware &...
How can i removed trojan virus plz help..............wat can i use???plz help
First try cleaning all your temporary internet files and temp files. This is the place where most of viruses and trojens unpack themselfs.
To clean temporary internet files follow below instructions
1) Open Internet Explorer and click on Tools
2) Click on Internet Options
3) On the General Tab, in the middle of the screen, click on Delete Files
4) You may also want to check the box "Delete all offline content"
5) Click on OK and wait for the hourglass icon to stop after it deletes the temporary internet files
6) You can now click on Delete Cookies and click OK to delete cookies that websites have placed on your hard drive
To clean temp files follow below instructions
http://pcsupport.about.com/od/maintenance/ht/manualtempxp.htm
After cleaning all temp clean up virus and trojans
Try virus scaning of your system with Trend micro Free scanning
http://housecall.trendmicro.com/
Also try rootkit buster
http://free.antivirus.com/rootkit-buster/
Make sure your system has most updated antivirus. If no antivirus you can also try free antivirus available
http://www.free-av.de/en/trialpay_download/1/avira_antivir_personal__free_antivirus.html
Hope this helps
May 16, 2010 | Computers & Internet
when it scans and finds a virus it won't let me delete
Then if you can quarantine that in a folder. Quarantine it. If pccillin have a reporting log with its path. Then copy in a piece of paper the name and path. Then delete that in DOS mode if you are familiar with that only be sure that it is a legit viral file.
Apr 12, 2009 | Trend Micro PC-cillin Internet Security...
trojan
you will need an anti virus software or spyware remover software. there is alot of it that can be downloaded from the net. just use your search engine. or if you want, just download a new different browser like mozilla and use that as your default browser, but still, the best way is spyware remover.
Feb 21, 2008 | Computers & Internet
192 people viewed this tip
David Payne
David Payne
