Tip & How-To about Cell Phones
LG KE850 Prada Unlock Code
Does your LG KE850 Prada work only with your current service provider or, when you insert a SIM card from another network, do you see any of the following messages?
  • Enter Subsidy Code
  • Enter Subsidy Password
  • Enter SIM Unlock Code (Simlock)
  • Contact Service Provider
  • Insert Correct SIM Card
  • Wrong SIM Card
  • Incorrect SIM Card
  • Phone Restricted
  • Can't Undo Restriction
  • Locked Return For Service
  • Enter Unlock Code
  • Enter Special Code
If so, your LG KE850 Prada is LOCKED and we can help you remove this lock on your LG KE850 Prada in a few simple steps, allowing you to use your phone on any GSM wireless network anywhere in the world.
You will not have to mail in your LG KE850 Prada. No Hardware or Software required. No technical knowledge required at all. Simply provide us your LG KE850 Prada’s IMEI number and we do all the rest.
Three Simple Steps
  1. Simply provide us your LG KE850 Prada’s IMEI (which can be found by typing *#06# into your phone), during check out.
  2. After order placement, the Unlock CODES together with easy to follow instructions guides will be sent to your email address within the time frame given.
  3. Follow the unlocking instructions provided by
    Reasons to remote unlock your cell phone
    • Save a fortune abroad, by using cheap local SIM Cards rather than expensive roaming tariffs.
    • As usually subsidize the cost of the phone, by unlocking it you are increasing the resale value of your LG KE850 Prada by up to 300%.
    • Use your work and personal SIM Card in your unlocked LG KE850 Prada - no need to carry two phones again.
    • Get the best value tariffs by swapping SIM Cards to take advantage of the latest offers.
    • You never send your phone to anybody.
    • Fast and easy. You receive the instructions within hours; unlocking itself takes 1-3 minutes.
    • No opening your LG KE850 Prada and risk of damage to your device.
    • Very easy, no technical experience necessary.
    • No complicated software or hardware just enters Unlock CODE, and your LG KE850 Prada is PERMANENTLY unlocked.
    • Is safe and does not void cell phone's warranty.
    • Unlocking is a one-time event. It works for the life of your LG KE850 Prada.
    Warranty
    All our Unlock CODES are 100% genuine and guaranteed, if for any reason your unlock codes are not found in our database then we will issue a full refund.
Instructions Unlocking Instructions for LG KE850 Prada
How to insert the Unlock CODE into your LG KE850 Prada
  1. Insert a not accepted SIM Card and turn ON your LG KE850 Prada.
  2. Your LG KE850 Prada will display "phone restricted".
  3. Select Cancel
  4. Your LG KE850 Prada will display "phone restriction code".
  5. Enter the Unlock CODE you received from UnlockallCellular.com
  6. Select OK
  7. Your LG KE850 Prada is now unlocked!
Cell Phones Logo
unlock my Lg Ke850
When you place a new or a existing SIM card from another phone provider into your mobile phone and it asks for a Security code then :-
This phone is locked to the original mobile phone provider. You need to contact this mobile provider to ask for the unlock code (security code) for this phone. You need to provide proof of ownership etc and the phone's unique IMEI number which is located inside the phone under the battery. They use this number to generate the unlock code for your phone.
They should provide you with instructions on how to enter this code into the phone.
Once you unlock the phone, then you can insert a new SIM card in this phone or sign up with another phone provider using this phone.
You could ring the phone provider and ask for the unlock security code because you are going overseas and wish to use your phone with a prepaid SIM card from another country. This maybe a free service.
The other way to get your phone unlock is to use a phone unlocking company on the Internet, they usually charge a couple of Dollars for their services. Use Google and search for "Security unlocking code” companies in your area.
You can also try this WEB site :-
http://www.mobileunlockguide.com/mobile-phone/
Jan 18, 2010 | LG Prada KE850 Cellular Phone
bought a LG Prada ke850 and it suppose to be unlocked but can't use my sim card in it why?
It means your phone still locked and you must have lg prada ke850 unlock code to unlock your phone network so you can use your sim card. FYI, lg unlock code can you get from your provider or buy from online unlock code retailer.
Nov 24, 2009 | LG Prada KE850 Cellular Phone
unlock prada phone
i have lg prada ke850. 'unlocked' cell phone, and just received in mail and activated. as soon as i turn it on, it shows 'locked'. i hit the unlock side key but nothing changes. pls send me a solution. lg manual is here but so poorly written i cant understand. even it does not show cervice center in usa nor it has index page in the back. worst manual i ever seen.
Oct 02, 2008 | LG Prada KE850 Cellular Phone
LG Prada phone
you need to have a unlocking code so that you can use it into another phone provider..
thank you
May 21, 2008 | LG Prada KE850 Cellular Phone
LG KE850 Prada network Block simcard
LG KE850 states sim card is not supported...what do i do?
Feb 13, 2008 | LG Prada KE850 Cellular Phone
347 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
