Tip & How-To about Computers & Internet
Enhncing your computer Performance
Hi guys,
There are several ways b ding which one can enhance the computer speed without any cost.
Some of the ways are:-
1.Emptying the tmp directory.
Just go to run Start button and type %temp%
Now select all files and press SHIFT+DELETE button to remove the files. This will increase your computer speed.
2.defragmenting the hard disk.
ime to time defragmenting the hard disk will improve the computer performance.
Just right click on any hard disk partition like C or drive and click on the Proprties and go to Tools. Now click on the defragment Now button to defragment that partition.
It wll surely improve the performance of your computer.
3 Creating a Restore Point
Whenever you feel that the computer is working very nicely, just create a restore point from Control Panel meu and later when you feel that the computer speed is not upto the mark then restore your computer to that particular earlier restore point.
4.Wallpapers: They slow your whole system down, so if you're willing to compromise, have a basic plain one instead
5.Minimizing: If you want to use several programs at the same time then minimize those you are not using. This helps reduce the overload on RAM
Thease are the some tricks which can improve the performance of your PC without costing a penny on any hardware.
Regards,
polysandy
Computers & Internet Logo
p0770 CEL. What is the issue and how much will it cost for repair?
Toyota has a tech service bulletin on this issue But this is how the system works the car electrical system applies 12 volts to solenoid and the computer supplies the ground to operate the shift solenoid. once the command has been sent and the computer see no change in the input speed verses output speed it sets the po770 several things can cause this problem from bad torque converter to sticky valve body control valves and wiring issues. This can be diagnosed with a enhanced scanner without taking anything apart.
Aug 31, 2014 | 2003 Toyota Corolla
hi guys, my notebook 0xc00000e9 this problem and how I want to save or return all my program really work? I need to go back but I do not want to format? need to save my back as folders? I hope you thank you hugs
This error indicates a corrupt registry. Luckily, when Windows is installed, a pristine copy of the registry hives is also installed and it remains untouched...replacing your corrupt registry hives with these ones will allow you to boot your operating system again. You may have to reinstall a few programs and drivers but all of your data will remain intact and you really won't lose anything. I will describe the process to you. I will also include instructions on how to back up the current registry in case you want to go back to it for any reason.
First you will need to locate the Windows install disc. If you don't have one you can borrow one as you will not need a key to perform the steps.
Put in the disc and perform the steps necessary to get your computer to boot to it.
Once you are the "Welcome to Setup" screen, press R to go into the Recovery Console.
Enter the administrator password when prompted
Tell the program what installation of Windows you would like to recover.
Now for the commands
md tmp (this creates a directory labeled tmp)
These 5 commands will make a copy of your current registry hives and back them up to the tmp directory. Type these in first. ENSURE you back them all up.
copy c:\windows\system32\config\system c:\windows\tmp\system.bak
copy c:\windows\system32\config\software c:\windows\tmp\software.bak
copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
copy c:\windows\system32\config\security c:\windows\tmp\security.bak
copy c:\windows\system32\config\default c:\windows\tmp\default.bak
These 5 commands will delete the current, corrupt registry hives.
delete c:\windows\system32\config\system
delete c:\windows\system32\config\software
delete c:\windows\system32\config\sam
delete c:\windows\system32\config\security
delete c:\windows\system32\config\default
These 5 commands will copy the pristine, uncorrupted hives into your system.
copy c:\windows\repair\system c:\windows\system32\config\system
copy c:\windows\repair\software c:\windows\system32\config\software
copy c:\windows\repair\sam c:\windows\system32\config\sam
copy c:\windows\repair\security c:\windows\system32\config\security
copy c:\windows\repair\default c:\windows\system32\config\default
Once you have entered your last command type exit to leave the recovery console and your computer should restart.
If you want to put the old registry back for any reason, simply follow the same steps but instead delete the current registry and replace it with the files that you placed in the tmp directory. Ensure that you remove the .bak extension from the file when you copy them over.
Really, other than this, the only other known working option is to reformat your computer.
Hope this helps.
Jun 27, 2011 | Computers & Internet
i dont have the disc how do i download brother lc61
I lost my cd for my Brother LC61 printer. I recently had Ubuntu put on my laptop by a co-worker because I having slow processing issues. I have clicked on download from the Brother site, but keep getting the following message:
Archive: /tmp/DriverDetective-3.exe
[/tmp/DriverDetective-3.exe]
End-of-central-directory signature not found. Either this file is not
a zipfile, or it constitutes one disk of a multi-part archive. In the
latter case the central directory and zipfile comment will be found on
the last disk(s) of this archive.
zipinfo: cannot find zipfile directory in one of /tmp/DriverDetective-3.exe or
/tmp/DriverDetective-3.exe.zip, and cannot find /tmp/DriverDetective-3.exe.ZIP, period.
Can this software be downloaded to my laptop?
May 12, 2011 | Brother Compatible LC41 (3 Color Ink) -...
Microsoft Outlook 2003 sycn with yahoo email
Windows 95, 98, and ME syntax
Deletes one or more files.
DEL [drive:][path]filename [/P]
ERASE [drive:][path]filename [/P]
[drive:][path]filenameSpecifies the file(s) to delete. Specify multiple files by using wildcards./PPrompts for confirmation before deleting each file.Windows 2000 and Windows XP syntax
DEL [/P] [/F] [/S] [/Q] [/A[[:]attributes]] names
ERASE [/P] [/F] [/S] [/Q] [/A[[:]attributes]] names
namesSpecifies a list of one or more files or directories. Wildcards may be used to delete multiple files. If a directory is specified, all files within the directory will be deleted./PPrompts for confirmation before deleting each file./FForce deleting of read-only files./SDelete specified files from all subdirectories./QQuiet mode, do not ask if ok to delete on global wildcard/ASelects files to delete based on attributesattributesR Read-only files S System filesH Hidden files A Files ready for archiving- Prefix meaning notIf Command Extensions are enabled DEL and ERASE change as follows:
The display semantics of the /S switch are reversed in that it shows you only the files that are deleted, not the ones it could not find.
Windows 2000 and Windows XP recovery console syntax
Deletes one file.
del [drive:][path]filename
delete [drive:][path]filename
[drive:][path]filenameSpecifies the file to delete.
Delete only operates within the system directories of the current Windows installation, removable media, the root directory of any hard disk partition, or the local installation sources.
Del and delete do not support replaceable parameters (wild cards).
Examples
Notice: Users who are running Microsoft Windows 95 and are used to deleted items going to the recycle bin need to keep in mind that deleting files from MS-DOS does not send files to the recycle bin. del test.tmp = Deletes the test.tmp in the directory that you currently are in, if the file exists.
del c:windows est.tmp = Delete the c:windows est.tmp in the windows directory if it exists.
del c:windows emp*.* = (* is for wild character(s)) *.* indicates that you would like to delete all files in the c:windows emp directory.
del c:windows emp?est.tmp = (? is a single wild character for one letter) This command would delete any file ending with est.tmp such as pest.tmp or zest.tmp...
You may also configure your outlook express to auto delete Emails by creating a rule for them.
Illustration.
If you can not see the illustrations properly , youtube has excellent tutorials.
http://www.youtube.com/watch?v=wcb7x7ErtO4
Thank you for choosing FixYa!
Az.
Sep 19, 2008 | Microsoft Office Outlook 2003 for PC
231 people viewed this tip
David Payne
David Payne
